Vintage lenses on the M - Post your images here!
bideford
M (Type 240) and cheap lenses....there I've said it. Love my battered Elmar 50mm /f3.5 and Elmar135mm f/4, and lets not forget a couple of excellent Voigtlander's (CV 75 f/2.5 and 50 f 1.5 being prime examples). But just lowered the bar somewhat and purchased a Jupiter 8. And it is good - sharp (enough) and luckily seems to nail focus.
Somehow getting results from cheap lenses is a tad more enjoyable than from spending (a very considerable) amount more on the usual suspects (of which I have to confess I am a ready participant).
Yes it is harder - but (for a hobbyist) very satisfying!
James
James,
I couldn't agree more and the M is the ideal platform for trying inexpensive lenses owing to the EVF that opens up a world of newly compatible lenses. As long as you can find an adaptor then virtually any lens is compatible because of the M-series's 27.8 mm register. For example I bought a cheap Contax/Yashica to M adaptor from that online auction site and I'm using very inexpensive but very good C/Y Sonnar zoom lenses. I've also got my eye on a 42 mm screwmount to M adaptor that will open up an enormous range of very inexpensive lenses. There's no lens snobbery here although expensive lenses are great when there's a particular need.:)
Pete.
I have an old 135 f4 Elmar that I bought for $40 before Leica had a digital M and it is great. Consensus is: lenses wider than 50 can be problematic... some great, some OK, some not so much. Shoot and enjoy.
Maybe I should take that lens, re-brand it as a re-issue and cover it with alligator hide and auction it. Nah.
George
Now you know what to think of those who try to convince each other that old lenses can't be used successfully on the latest digital high-megapixel cameras ... :rolleyes:
On a side note, I've seen online some fairly nasty smearing examples of images with old & new lens designs shot wide open on the recently released A7/A7r. Also very evident is vignetting & red-edge with wide-angles. I haven't noticed this on my M with old & new lens designs..
On a side note, I've seen online some fairly nasty smearing examples of images with old & new lens designs shot wide open on the recently released Sony A7/A7R.
Uh, yes ... the Sony A7. I've seen those examples, too. So, exceptions to the rule exist.
I was having the resolution issue in mind, basically. People often believe that higher-resolving digital cameras also require higher-resolving lenses, or the pictures will look bad. Which is nonsense ... some other possible technical issues notwithstanding.
I'm a big fan of the Minolta 40 rokkor cle version. No need for a 35 pre king of Bokeh!
+1
It has a really interesting bokeh character - not great on foliage, but if you shoot something with lines the impression comes through, while still blurring out.
what? didn't everyone buy a Leica to take pictures of their cat?
Lets kick it off with my macro dog's dinner:
Leica M, pimped Olympus EVF, Nikon flash bracket, Hama LED light, Corfield Lumax 45/1.9 LTMlens
Made in England ca 1949, no RF coupling (The Corfield Periscop camera had a weird focusing thing built in) , focuses down to less than 15 cm.
Quality: surprisingly good, maybe as good as Zeiss and Leica lenses of the time. :)
Edited by jaapv
Yes, older lenses are fine, just had my pre-ASPH 50mm Summilux serviced for almost as much as it cost new and it's working well.
The M allows you to put all manner of old lenses on it of course and I restrict myself to Nikon and M42.
It's interesting to compare the Meyer Optik Goerlitz Domiplan 50mm f2.8 which I bought on eBay for (IIRC) £1.35 with the Leica APO 50mm Summicron ASPH which cost 4000 times as much. Not so different, really. At least I haven't had to return the Domiplan to have central veiling flare fixed, it comes as standard, and besides, when I tried to track down the Meyer Optik factory a couple of years ago, not surprisingly, it's long gone. Probably an Audi showroom now.
More seriously, I enjoy the Carl Zeiss Jena Pancolar 50mm f1.8, the Flektogon 20mm f4 - huge compared to the Leica 21mm f3.4 - and the Pentax Super Takumar 55mm f1.8.
Edited by marknorton
Jaques,
How have you managed to mount the wonderful Biotar on your M? Did you find an Exakta to M mount?
Pete.
It took me a while to find a solution- I ended up getting an Exakta to Canon ring- then a Canon to M ring- and stacked them. There are several types of Exakta to Canon- I had to get a very thin one for it to work. Works like a charm with infinity focus spot on.
Exakta Exa Mount Lens to Canon EOS EF Adapter 550D 600D 1100D 7D 5D Mark II Cap | eBay
