wjkotze Posted August 26, 2013 Share #1 Posted August 26, 2013 Advertisement (gone after registration) A few questions to 21mm Summilux owners : 1. When you look at product shots of this lens, a fair percentage shows a distinct gap between the lens hood and the lens body. The gap is filled by what appears to be a red o-ring. Other shots, including the one on the Leica site shows no gap and no o-ring. Has there been a design change at some stage ? 2.Some reviewers reported and showed samples of vignetting caused by the lens-hood, whilst other reviewers reported no problem. Could this be sample related or has there been a small design change on the hood ? Link to post Share on other sites More sharing options...
Advertisement Posted August 26, 2013 Posted August 26, 2013 Hi wjkotze, Take a look here Leica 21mm Summilux. I'm sure you'll find what you were looking for!
LuxM9 Posted August 26, 2013 Share #2 Posted August 26, 2013 I have this lens for one year now and I did not discover any vignetting by the hood; btw: it is a dream to work with that Leica glass ! Link to post Share on other sites More sharing options...
wjkotze Posted August 26, 2013 Author Share #3 Posted August 26, 2013 I have this lens for one year now and I did not discover any vignetting by the hood; btw: it is a dream to work with that Leica glass ! Does your copy have the red o-ring ? Link to post Share on other sites More sharing options...
FrozenInTime Posted August 26, 2013 Share #4 Posted August 26, 2013 I've had the 21mm Summilux since 2009 and used it for a couple of years with film only; where there is significant and obvious light fall off towards the edges. On digital it's easier to correct this out under the lens profile tab. It has the red band which seems to be a hard plastic and is still visible with the lens hood fully on. The red band is there only to remind you not to put the lens face down with the hood off - to prevent front element damage. Link to post Share on other sites More sharing options...
wjkotze Posted August 26, 2013 Author Share #5 Posted August 26, 2013 I've had the 21mm Summilux since 2009 and used it for a couple of years with film only; where there is significant and obvious light fall off towards the edges.On digital it's easier to correct this out under the lens profile tab. It has the red band which seems to be a hard plastic and is still visible with the lens hood fully on. The red band is there only to remind you not to put the lens face down with the hood off - to prevent front element damage. The vignetting that I am referring to is over and above the light fall off. It also disappears when you remove the hood. See this link : 21mm 1.4 Leica Summilux lens review ; None of the latest product shots including the one on the Leica site shows the red band which means there must have been a redesign along the way. Link to post Share on other sites More sharing options...
algrove Posted August 26, 2013 Share #6 Posted August 26, 2013 I bought mine in Dec 2011 and just love everything about the lens. No vignetting I am aware of. Works founder fully on the M with EVF. With hood attached there is a red band visible from the side and as was mentioned it is a reminder that the lens element protrudes further out than the front edge of the lens. I keep a series 8 UV filter on mine for protection since it can be considered a WA Noctilux. Link to post Share on other sites More sharing options...
01af Posted August 26, 2013 Share #7 Posted August 26, 2013 Advertisement (gone after registration) When you look at product shots of this lens, a fair percentage shows a distinct gap between the lens hood and the lens body. The gap is filled by what appears to be a red o-ring. Other shots, including the one on the Leica site, show no gap and no o-ring. Has there been a design change at some stage? I am not aware of any design change—which of course means nothing. Anyway, my sample, with a 409XXXX serial number, clearly shows the gap and the slightly recessed red ring which indeed is a red o-ring. In pictures of the lens, the red ring may be more or less apparent, depending on the perspective of the view at the lens and the lighting conditions. Some reviewers reported and showed samples of vignetting caused by the lens hood, whilst other reviewers reported no problem. Could this be sample-related, or has there been a small design change on the hood? Gosh! I already noticed the stong vignetting in the corners even at smaller apertures ... yet it never occurred to me that the hood might contribute to this undesirable effect. Now I tried it, and lo and behold—the hood indeed aggravates the already strong vignetting, at all apertures. Without the hood, the corners are dark; with the hood, they're almost black. This clearly is a faulty design. I cannot believe that Leica Camera creates and sells such a dreck! I am seriously annoyed ... :mad: Again, I am not aware of any design changes. I searched the Internet for pictures of the 21 mm Summilux's hood, and they all look the same to me. As to some reviewers reporting no problem with the hood—I'd be seriously surprised if this was due to sample variation. I rather believe some reviewers don't see vignetting when they're directly looking at it. But then, I was seriously surprised before ... Link to post Share on other sites More sharing options...
darylgo Posted August 26, 2013 Share #8 Posted August 26, 2013 A few questions to 21mm Summilux owners : 1. When you look at product shots of this lens, a fair percentage shows a distinct gap between the lens hood and the lens body. The gap is filled by what appears to be a red o-ring. Other shots, including the one on the Leica site shows no gap and no o-ring. Has there been a design change at some stage ? When purchasing my 21mm the lens' hood fit the lens perfectly, I can not remember if it showed or hid the red band. The lens had a few issues and was returned. My second copy had improved image quality with a slightly skewed hood. On one side the hood covers the red band and the opposite side the red band is exposed. On the red band (exposed) side the gap is approximately 1/2mm. Exchanging hoods made no difference the red bands appearance was the same on each lens independent of which hood was placed. 2.Some reviewers reported and showed samples of vignetting caused by the lens-hood, whilst other reviewers reported no problem. Could this be sample related or has there been a small design change on the hood ? The above skewing of the hood and it's inexactness may contribute to vignetting however I think one side would show more effect than the other. I haven't looked critically at the vignetting, some is expected and the M9 software reduces it with the lens profile. Link to post Share on other sites More sharing options...
FrozenInTime Posted August 27, 2013 Share #9 Posted August 27, 2013 Had to wait for it to get dark enough No profile correction applied f/1.4 Hood f/1.4 No Hood f/4 Hood f/4 No Hood The hood does indeed add some mechanical vignetting Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/211455-leica-21mm-summilux/?do=findComment&comment=2406294'>More sharing options...
wjkotze Posted August 27, 2013 Author Share #10 Posted August 27, 2013 See attached product shots. The one on the left do not have the red band. The gap also appears to be marginally smaller. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/211455-leica-21mm-summilux/?do=findComment&comment=2406400'>More sharing options...
algrove Posted August 27, 2013 Share #11 Posted August 27, 2013 Good thread. OK, so what damn hood should we get for these WA Noctiluxs? Mine will not screw in any further. Then there is the series 8 filter which I often use. Link to post Share on other sites More sharing options...
MarkP Posted August 27, 2013 Share #12 Posted August 27, 2013 Hmmm. I'll have to check this out on mine. Not impressed Link to post Share on other sites More sharing options...
wjkotze Posted August 27, 2013 Author Share #13 Posted August 27, 2013 There also appears to be a design change in this area. Note the gap between the aperture and focus rings. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/211455-leica-21mm-summilux/?do=findComment&comment=2406432'>More sharing options...
MarkP Posted August 27, 2013 Share #14 Posted August 27, 2013 There also appears to be a design change in this area. Note the gap between the aperture and focus rings. I wonder whether it's an artefact of lighting. The illumination of the lens is very different in the two photographs with the second lens illuminated from below and behind leaving strong shadow lines. Link to post Share on other sites More sharing options...
MarkP Posted August 27, 2013 Share #15 Posted August 27, 2013 I've found similar differences in vignetting with and without the hood and have emailed Leica for an opinion. Link to post Share on other sites More sharing options...
jankap Posted August 27, 2013 Share #16 Posted August 27, 2013 The hood seems to fit the light angle in a very narrow way. Has the hood design changed since the introduction? Jan Link to post Share on other sites More sharing options...
MarkP Posted August 27, 2013 Share #17 Posted August 27, 2013 The hood seems to fit the light angle in a very narrow way. Has the hood design changed since the introduction?Jan One of my questions to Leica. Link to post Share on other sites More sharing options...
wjkotze Posted August 27, 2013 Author Share #18 Posted August 27, 2013 I wonder whether it's an artefact of lighting. The illumination of the lens is very different in the two photographs with the second lens illuminated from below and behind leaving strong shadow lines. I take your point. There is also a small perspective difference. I am however not sure that it can account for what appears to be a difference in gap. Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted August 27, 2013 Share #19 Posted August 27, 2013 My 21 lux has the red ring and with a ND series 8 filter installed it rattles, I wonder if these filters rattle without the red ring. I also just noticed that I bought a new series 8 ND filter from B&W and now I have two (WTF) I thought I had a 10 stop series 8 so that is why I ordered the 0.6 ND...........never mind I have mislead filters before...lol Link to post Share on other sites More sharing options...
rramesh Posted August 27, 2013 Share #20 Posted August 27, 2013 See these 2 videos. The one by Steve Huff (2009) has no red ring. Link to post Share on other sites More sharing options...
