james.liam Posted August 14, 2013 Share #1 Posted August 14, 2013 Advertisement (gone after registration) Might have a chance at getting one or the other at about the same price (~€1600). I'm shooting film only (unless I rent a Monochrome or other digital M). Obviously the older version has lower contrast and such but those of you who have or have used both, any insight and recommendation is appreciated. Quote Link to post Share on other sites More sharing options...
Advertisement Posted August 14, 2013 Posted August 14, 2013 Hi james.liam, Take a look here 35 Summicron 8-element vs ASPH. I'm sure you'll find what you were looking for!
elgenper Posted August 15, 2013 Share #2 Posted August 15, 2013 I have both. The 8-element (aka ´V1´) was used with my old M2, the Asph was acquired at the same time as my M9 (now I use only digital, so haven´t tried the Asph with film). I feel the old V1 is a beauty, and noticeably smaller and lighter than the Asph. Only thing is, using V1 wide open is just too soft for my taste; the Asph is very good even at f/2. From 2.8 - 4 or so, while the old one is somewhat ´gentler´, there is really not much difference in detail (contrast is lower, of course, which can be an asset in contrasty light). In short, I bought the Asph for its superior performance wide open. If I hadn´t needed the speed, there would have been no reason to get the new one, really. That said, if I had had neither and been offered both at about the same price, I would certainly have chosen the Asph. 1 Quote Link to post Share on other sites More sharing options...
james.liam Posted August 16, 2013 Author Share #3 Posted August 16, 2013 (edited) Appreciate the detailed response. Your arguments are compelling. I think I will opt for the ASPH, focus shift and all Edited August 16, 2013 by james.liam Quote Link to post Share on other sites More sharing options...
tobey bilek Posted August 16, 2013 Share #4 Posted August 16, 2013 Appreciate the detailed response. I think I will opt for the ASPH, focus shift and all Good decision. 8 element is mostly hype Quote Link to post Share on other sites More sharing options...
Ivar B Posted August 16, 2013 Share #5 Posted August 16, 2013 The 8-element high pricing is determined by its relative rarity and collector interest. I have one in my collection but unless you are interested in "special effects" such as a bit of flare at the wider f stops and generally soft rendering, this lens is hardly a user lens any more, at the very least not digital. The 8-element and the ASPH lenses are so different they are hardly relevant candidates if you need to chose a 35mm lens. 1 Quote Link to post Share on other sites More sharing options...
biglou Posted August 16, 2013 Share #6 Posted August 16, 2013 Could happen you have a sub par one Ivar. I own about all the 35mm made by Leica and this one is at the top for definition of details. What it lacks a very little bit comparing with modern glass is some " sparkle " and clarity of colours, some contrast. This explains why the prices are still high for a not so rare lens. Quote Link to post Share on other sites More sharing options...
lct Posted August 16, 2013 Share #7 Posted August 16, 2013 Advertisement (gone after registration) ...I think I will opt for the ASPH, focus shift and all Focus shift? Never seen this with the 35/2 asph so far. Quote Link to post Share on other sites More sharing options...
james.liam Posted August 16, 2013 Author Share #8 Posted August 16, 2013 Focus shift? Never seen this with the 35/2 asph so far. So is the word from both Sean Reid and Lloyd Chambers. Slight rearward shift stopped down beyond f/2.8. Negated by f/8 because of DOF but allegedly making focus at f/5.6 unreliable. Quote Link to post Share on other sites More sharing options...
lct Posted August 16, 2013 Share #9 Posted August 16, 2013 I repect all those good people but it is not my experience, that's all i can say. Quote Link to post Share on other sites More sharing options...
james.liam Posted August 16, 2013 Author Share #10 Posted August 16, 2013 I repect all those good people but it is not my experience, that's all i can say. Fair enough. Quote Link to post Share on other sites More sharing options...
Jon Pop Posted August 16, 2013 Share #11 Posted August 16, 2013 Although Ken Rockwell is highly opinionated (I'd argue Sean Reid and others are too...I think they had a bad sample b/c I've never seen or heard of shift in the 35 Cron), he has a very good technical comparison of all versions of the 35 Summicron. This was an attempt, useful I thought, to cut through the various mythologies and legends about the various models. He has test shots taken with each version. Check it out, may be helpful. Quote Link to post Share on other sites More sharing options...
Jean-Michel Posted August 16, 2013 Share #12 Posted August 16, 2013 Hi, I use a 1962 Canadian-made Summicron with goggles on my M9. I originally purchased this lens to go on my M4 and used it on my M3 and M6. I wanted the goggles so that I could use the M4's 50 mm frame since I wear glasses. I am more than happy with the results with my M9 -- note that there is a marked difference in rendering between f/2 and f/2.8 or smaller, the difference with the M9 is much more pronounced than the difference seen when using film. At f/2, images tend to require a bit more adjusting in Lightroom for contrast and clarity. Jean-Michel Quote Link to post Share on other sites More sharing options...
Falstaff Posted August 16, 2013 Share #13 Posted August 16, 2013 Focus shift? Never seen this with the 35/2 asph so far. My experience also. Falstaff Quote Link to post Share on other sites More sharing options...
Simey Posted September 30, 2013 Share #14 Posted September 30, 2013 I have both. The 8-element (aka ´V1´) was used with my old M2, the Asph was acquired at the same time as my M9 (now I use only digital, so haven´t tried the Asph with film). I feel the old V1 is a beauty, and noticeably smaller and lighter than the Asph. Only thing is, using V1 wide open is just too soft for my taste; the Asph is very good even at f/2. From 2.8 - 4 or so, while the old one is somewhat ´gentler´, there is really not much difference in detail (contrast is lower, of course, which can be an asset in contrasty light). In short, I bought the Asph for its superior performance wide open. If I hadn´t needed the speed, there would have been no reason to get the new one, really. That said, if I had had neither and been offered both at about the same price, I would certainly have chosen the Asph. I'll second this. I had a v1 8 element 35mm for my first 10 years of shooting Leicas. It was sharp in terms of resolution but a bit soft and wide open it flared like crazy at any aperture. In the early 2000s I sold it (for quite a nice price) and picked up an asph. IMHO it's a much better lens, especially wide open. The bokeh is probably better on the older lens but a 35 isn't really a bokeh kind of lens. The bottom line is that I don't see the point of a rangefinder lens with a maximum aperture that I am reluctant to use - it's not like I need it for focusing. 1 Quote Link to post Share on other sites More sharing options...
james.liam Posted December 24, 2014 Author Share #15 Posted December 24, 2014 I've resurrected this moribund thread to re-pose the question. I have recently shifted over to an M Monochrom from film and am collecting experienced-based opinions on the 8 element vs ASPH. Hype? Quote Link to post Share on other sites More sharing options...
IWC Doppel Posted December 25, 2014 Share #16 Posted December 25, 2014 There was an interesting comparison shown recently and the colouring of the 8 element was very appealing, it's on my want list. I'd look at the 35 MkIV as the resolution is remarkable and can surprise if stopped down a little it also has incredible depth (that Leica 3D) at f2.8,4 particularly f4. I bet this would be stellar on the MM Quote Link to post Share on other sites More sharing options...
Stein K S Posted December 25, 2014 Share #17 Posted December 25, 2014 Although Ken Rockwell is highly opinionated (I'd argue Sean Reid and others are too...I think they had a bad sample b/c I've never seen or heard of shift in the 35 Cron), he has a very good technical comparison of all versions of the 35 Summicron. This was an attempt, useful I thought, to cut through the various mythologies and legends about the various models. He has test shots taken with each version. Check it out, may be helpful. Hi I too found the Ken Rockwell comparison (35 crons v1 through asph) very interesting. In short it confirms my only (but also major) complaint about my 35 cron v4... the corner sharpness, which in my opinion can "ruin" the wrong picture... All previous 35 crons seems to show the same behaviour while asph (obviously) show a giant sharpness improvement in the corners from wide open and also when stopped down. One other observation can be that the 8-element v1 could appear to be the sharpest in the centre at f2,8 and at f4,0... even sharper than the asph...? Probably nothing new to you guys, but anyway PS: I own the 35 cron v4 and the 35 lux asph pre-fle and think I have the best from "both worlds"... Comments? Regards, Stein Quote Link to post Share on other sites More sharing options...
james.liam Posted December 25, 2014 Author Share #18 Posted December 25, 2014 It seems to me that there is a penalty to the latest designs that feature much improved wide-open performance compared to their elders, similarly seen in the latest non-APO 50 Summicron and that is focus shift at the mid-apertures. Quote Link to post Share on other sites More sharing options...
lct Posted December 25, 2014 Share #19 Posted December 25, 2014 As far as my samples are concerned, the 35/2 asph has no significant focus shift whilst the 35/2 v4 has some but perhaps the reviewers you trust say otherwise, i don't know. Quote Link to post Share on other sites More sharing options...
gyoung Posted December 25, 2014 Share #20 Posted December 25, 2014 I bought a goggled 35 Summicron with my M3, in '68 it was by far the best 35mm lens available for any 35mm camera and any others as fast as f/2 were very few and far between. I bought an asph 35 Summicron for my M6ttl about 10 years ago. Both on film and on my Nex 6 its much sharper than the v1 8 element at the larger apertures, such is progress! Gerry Quote Link to post Share on other sites More sharing options...
