Guest D-Lux 6 Posted February 23, 2013 Share #1 Posted February 23, 2013 Advertisement (gone after registration) I have a couple of questions for any D-Lux 6 users out there who may have tried to put filters on their cameras using the Panasonic LX-7 filter adaptor ring (part # DMW-FA1). I wrote to the Leica support staff who responded back saying that the ring around the lens on the D-Lux 6 is indeed designed to unscrew and accept the Panasonic LX-7 filter adaptor ring. As Leica themselves don't market their own adaptor for filter use, they said that that the Panasonic was the recommended option. Has anyone tried to remove the ring and found it so difficult that they felt that they might damage the camera/lens in the process? I'm bound and determined to at least use a UV filter to protect the Summilux lens. Any tips for removal?? Also, when searching for polarizing filters (there aren't all that many options in 37mm) the two most likely to produce decent results are a B+W 37mm circular polarizer "with single coating" and the Panasonic Lumix PL filter (DMW-LPLA37). Does anyone have any experience with either of these? Does anyone have an opinion from side by side comparison?? I generally think that B+W produce good products, but the phrase "with single coating" makes it sound...compromised on quality. Quote Link to post Share on other sites More sharing options...
Advertisement Posted February 23, 2013 Posted February 23, 2013 Hi Guest D-Lux 6, Take a look here Filters for D-Lux 6. I'm sure you'll find what you were looking for!
C Lei Lux Posted February 24, 2013 Share #2 Posted February 24, 2013 once I have the lens filter I'll be able to say more. 1) the neutral glass filter I use only for protection of the front lens. 2) I rarely use the polarizing filter, only disturbing reflex or in hazy weather. 3) a gray filter is in the D-Lux6 no longer required. my flickr account: Flickr: kmhb2011's Photostream Quote Link to post Share on other sites More sharing options...
oho Posted February 25, 2013 Share #3 Posted February 25, 2013 (edited) Just use this one: B+W Pol Circular Käsemann MRC F-PRO 37 mm and (for wide angle lens protection) this one: B+W 010 UV-Filter 37mm XS-Pro Digital ... and you´re done - after having removed the lens ring using FOUR fingers with only little pressure... Add the adaptor and it´ll work fine. PS: All these filters come with multi resistance coating (MRC) - not just single coating. Edited February 25, 2013 by oho Quote Link to post Share on other sites More sharing options...
C Lei Lux Posted February 25, 2013 Share #4 Posted February 25, 2013 Just use this one:B+W Pol Circular Käsemann MRC F-PRO 37 mm and (for wide angle lens protection) this one: B+W 010 UV-Filter 37mm XS-Pro Digital ... and you´re done - after having removed the lens ring using FOUR fingers with only little pressure... Add the adaptor and it´ll work fine. PS: All these filters come with multi resistance coating (MRC) - not just single coating. hallo oho da mein englisch mehr oder weniger unterbelichtet ist, my answer in german: wie wirkt das polfilter im 24/28/35mm bereich, gibt es da nicht große flächen ohne die gewünschte filterwirkung? ist bei anderen polfiltern sicher genau gleich, oder? das vorgeschlagene UV-filter habe ich mit der D-Lux6 bestellt, das ist sicher top. mbg klaus-michael Quote Link to post Share on other sites More sharing options...
oho Posted February 25, 2013 Share #5 Posted February 25, 2013 (edited) hallo ohoda mein englisch mehr oder weniger unterbelichtet ist, my answer in german: wie wirkt das polfilter im 24/28/35mm bereich, gibt es da nicht große flächen ohne die gewünschte filterwirkung? ist bei anderen polfiltern sicher genau gleich, oder? das vorgeschlagene UV-filter habe ich mit der D-Lux6 bestellt, das ist sicher top. mbg klaus-michael Hi, although your answers are questions ;-) - hier meine Beobachtungen: Im Weitwinkelbereich wirkt das Polfilter schon auch, aber der Wirkungsbereich ist tatsächlich eingegrenzt: Selbst die 90 Grad zur Lichtquelle ändern daran nichts. Als viel wichtiger erachte ich die Tatsache, dass das Polfilter auf Grund seiner Bauhöhe zu Abschattungen im Weitwinkelbereich führt - ab 50mm ist es dann okay und das Polfilter arbeitet dann ohne diese Einschränkungen bezügl. der Filterwirkung. Ob da jetzt ein Step-up-Adapter auf z. B. 49mm-Filter, um wieder den vollen Weitwinkelbereich nutzen zu können, Abhilfe schafft, keine Erfahrungen diesbezüglich. (Außerdem würde das aus einer kleinen Kompakten wiederum ein Ungetüm machen...) Jap, das UV-Filterchen ist super: Kamera in der kleinen braunen Tasche MIT aufgeschraubtem Filter OHNE Objektivdeckel: Objektiv ist geschützt und die kleine 6 ohne nerviges "Deckel entfernen" sofort schussbereit... Schöne Grüße :)tt:) PS: Beim KIWI-Adapter "frisst" sich der Polfilter fest, der Siolex-Adapter funktioniert bestens... Edited February 25, 2013 by oho Quote Link to post Share on other sites More sharing options...
C Lei Lux Posted February 25, 2013 Share #6 Posted February 25, 2013 Hi, although your answers are questions ;-) - hier meine Beobachtungen: Im Weitwinkelbereich wirkt das Polfilter schon auch, aber der Wirkungsbereich ist tatsächlich eingegrenzt: Selbst die 90 Grad zur Lichtquelle ändern daran nichts. Als viel wichtiger erachte ich die Tatsache, dass das Polfilter auf Grund seiner Bauhöhe zu Abschattungen im Weitwinkelbereich führt - ab 50mm ist es dann okay und das Polfilter arbeitet dann ohne diese Einschränkungen bezügl. der Filterwirkung. Ob da jetzt ein Step-up-Adapter auf z. B. 49mm-Filter, um wieder den vollen Weitwinkelbereich nutzen zu können, Abhilfe schafft, keine Erfahrungen diesbezüglich. (Außerdem würde das aus einer kleinen Kompakten wiederum ein Ungetüm machen...) Jap, das UV-Filterchen ist super: Kamera in der kleinen braunen Tasche MIT aufgeschraubtem Filter OHNE Objektivdeckel: Objektiv ist geschützt und die kleine 6 ohne nerviges "Deckel entfernen" sofort schussbereit... Schöne Grüße :)tt:) PS: Beim KIWI-Adapter "frisst" sich der Polfilter fest, der Siolex-Adapter funktioniert bestens... ok, danke für den tipp zum siolex-adapter, muß mal suchen er wird zu finden sein. als alternative habe ich ja bereits alles mit 52mm gewinde. lumix tubus auf meiner D-Lux 5 fest installiert, dazu noch eine gummifaltblende, trotzdem keinerlei beeinträchtigung auch nicht bei 24mm. die generell vorhandene einschränkung des polfilters bleibt. Du hast recht, die größe leidet darunter, doch mich hat das nie gestört, da ich von den DSLR's ohnehin nicht verwöhnt war und so gesehen empfinde ich die größe noch heute als komfortabel. mbg klaus-michael Quote Link to post Share on other sites More sharing options...
Guest D-Lux 6 Posted February 26, 2013 Share #7 Posted February 26, 2013 Advertisement (gone after registration) Just use this one:B+W Pol Circular Käsemann MRC F-PRO 37 mm and (for wide angle lens protection) this one: B+W 010 UV-Filter 37mm XS-Pro Digital ... and you´re done - after having removed the lens ring using FOUR fingers with only little pressure... Add the adaptor and it´ll work fine. PS: All these filters come with multi resistance coating (MRC) - not just single coating. Four fingers is all, huh? My camera's seems to be on there pretty good. Well thanks for the tip, I'll keep trying to ease this ring off, and order the B+W filters. Quote Link to post Share on other sites More sharing options...
Guest D-Lux 6 Posted February 26, 2013 Share #8 Posted February 26, 2013 Hi, although your answers are questions ;-) - hier meine Beobachtungen: Im Weitwinkelbereich wirkt das Polfilter schon auch, aber der Wirkungsbereich ist tatsächlich eingegrenzt: Selbst die 90 Grad zur Lichtquelle ändern daran nichts. Als viel wichtiger erachte ich die Tatsache, dass das Polfilter auf Grund seiner Bauhöhe zu Abschattungen im Weitwinkelbereich führt - ab 50mm ist es dann okay und das Polfilter arbeitet dann ohne diese Einschränkungen bezügl. der Filterwirkung. Ob da jetzt ein Step-up-Adapter auf z. B. 49mm-Filter, um wieder den vollen Weitwinkelbereich nutzen zu können, Abhilfe schafft, keine Erfahrungen diesbezüglich. (Außerdem würde das aus einer kleinen Kompakten wiederum ein Ungetüm machen...) Jap, das UV-Filterchen ist super: Kamera in der kleinen braunen Tasche MIT aufgeschraubtem Filter OHNE Objektivdeckel: Objektiv ist geschützt und die kleine 6 ohne nerviges "Deckel entfernen" sofort schussbereit... Schöne Grüße :)tt:) PS: Beim KIWI-Adapter "frisst" sich der Polfilter fest, der Siolex-Adapter funktioniert bestens... Is there an issue with the Panasonic filter adaptors? Or just a preference for Siolex adaptors? Quote Link to post Share on other sites More sharing options...
oho Posted February 26, 2013 Share #9 Posted February 26, 2013 I first tried the Kiwi adaptor and the B+W-circular polarizer blocked while turning. So I ordered the Siolex - ev´rything okay. Hope the Panasonic - was not available the time I bought the adaptor- will be more Siolex-like... Quote Link to post Share on other sites More sharing options...
C Lei Lux Posted February 27, 2013 Share #10 Posted February 27, 2013 I first tried the Kiwi adaptor and the B+W-circular polarizer blocked while turning. So I ordered the Siolex - ev´rything okay. Hope the Panasonic - was not available the time I bought the adaptor- will be more Siolex-like... heute meine D-Lux 6 bekommen + kiwifoto-adaptertubus für 52mm zubehör. AT direkt vor dem blendenring nach entfernen der vor dem blendenring sitzenden bajonettverschlussabdeckung angedockt, passt. der objektivtubus bleibt frei, so wie bisher bei der D-Lux5. deren zubehör: faltblende, polfilter und weitwinkelvorsatzlinse* ist somit weiter verwendbar. meine so modifizierte D-Lux6 bietet einen zoombereich von 18mm mit WWK bis 180mm mit aktiviertem i.zoom. (*WWKx0,75 // bei 24mm = 18mm und // bei 28mm = 21mm - brennweitenangaben jeweils auf KB bezogen) mbg klaus-michael Quote Link to post Share on other sites More sharing options...
msche Posted February 27, 2013 Share #11 Posted February 27, 2013 ich bin neu hier und hätte eine frage, habe mir eine D-Lux6 mit Sucher geleistet und bin auf Filtersuche, ist der Durchmesser schon 37 mm? ich habe nichts gefunden wo ich es genau nachlesen kann und ich möchte keinen falschen Filter bestellen, bin bei B+W fündig geworden, Danke für die Hilfe Quote Link to post Share on other sites More sharing options...
C Lei Lux Posted February 28, 2013 Share #12 Posted February 28, 2013 ich bin neu hier und hätte eine frage, habe mir eine D-Lux6 mit Sucher geleistet und bin auf Filtersuche, ist der Durchmesser schon 37 mm? ich habe nichts gefunden wo ich es genau nachlesen kann und ich möchte keinen falschen Filter bestellen, bin bei B+W fündig geworden, Danke für die Hilfe B+W = absolut ok. für alle filter 37mm ist zu beachten, dass ohne den optional erhältlichen filteradapter DMW FA1* die filter nicht angeschraubt werden können. (*original adapter derzeit nicht verfügbar) empfehlung eines users adapter von siolex 14,95 EUR ist besser als kiwifoto adapter 9,95 EUR, kann ich bestätigen. neutral oder UV filter von B+W möglichst in slim-ausführung, F-Pro oder XS-version, wählen. vermeidung von vignettierung im WW-bereich. die 37mm polfilter sind konstruktionsbedingt zumindest bei 24/28mm nicht vignettierungsfrei, ist aber aufgrund der eingeschränkten polfilterwirkung im WW-bereich eh nicht so relevant. ich selbst habe den kiwifoto adaptertubus mit 52mm gewindeanschluss, u.a. auch für den WW-konverter DMW-LA52, vignettierungen bei keiner brennweite. mbg klaus-michael Quote Link to post Share on other sites More sharing options...
grohde Posted March 15, 2013 Share #13 Posted March 15, 2013 Four fingers is all, huh? My camera's seems to be on there pretty good. Well thanks for the tip, I'll keep trying to ease this ring off, and order the B+W filters. I have a problem in easing the lens ring off.... is there a solution other than using the fingers, since it seems to sit pretty tight... Were you eventually successful, how did you come around I want to attach a JJC self retaining lens cap (ALC-LX7B) which is also compatible for the D-LUX 6, but I need to unscrew the front lens ring of course... Lookinfg forward to get some solution tips. anticipated thanks, Quote Link to post Share on other sites More sharing options...
Guest D-Lux 6 Posted March 21, 2013 Share #14 Posted March 21, 2013 I have a problem in easing the lens ring off.... is there a solution other than using the fingers, since it seems to sit pretty tight...Were you eventually successful, how did you come around I want to attach a JJC self retaining lens cap (ALC-LX7B) which is also compatible for the D-LUX 6, but I need to unscrew the front lens ring of course... Lookinfg forward to get some solution tips. anticipated thanks, !@#$%&* The ring will not come off!! I'm beginning to think that it was never meant to on my US version. I wound up bending the outer ring a bit, and took a couple of nicks out of the surface coating of the lens in the process, despite my best efforts to protect it. I wrote to Leica and got a response from them saying that it does come off, so I'm not quite sure what is going on. I'm now going to inquire about sending it in to get the ring off and perhaps get the lens resurfaced. I'll let you know what they say about it. Wish me luck! Quote Link to post Share on other sites More sharing options...
C Lei Lux Posted March 22, 2013 Share #15 Posted March 22, 2013 !@#$%&* The ring will not come off!! I'm beginning to think that it was never meant to on my US version. I wound up bending the outer ring a bit, and took a couple of nicks out of the surface coating of the lens in the process, despite my best efforts to protect it. I wrote to Leica and got a response from them saying that it does come off, so I'm not quite sure what is going on. I'm now going to inquire about sending it in to get the ring off and perhaps get the lens resurfaced. I'll let you know what they say about it. Wish me luck! look: Flickr: kmhb2011's Photostream, sample images D-Lux6*/V-Lux3 (*inkl. accessories) best regards klaus-michael Quote Link to post Share on other sites More sharing options...
Guest D-Lux 6 Posted March 26, 2013 Share #16 Posted March 26, 2013 look: Flickr: kmhb2011's Photostream, sample images D-Lux6*/V-Lux3 (*inkl. accessories) best regards klaus-michael[/quote Okay, so how does one obtain this lens system with the "bayonet lug" type apparatus? Though I've already purchased a couple of nice 37mm filters (B+W UV/IR, and a Polarizer) and the Panasonic Filter Adaptor Kit DMW-FA1, I may have to look into this other setup that you've pointed out. Thanks for the link and the look, by the way. Although I don't necessarily have to think of the d-lux 6 as a compact pocket camera, the advantage to the 37mm lenses is that it would still maintain a more compact profile. Are their any distinct advantages to using the system (with larger filters) that you've depicted? Thanks for the reply. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites More sharing options...
Guest D-Lux 6 Posted March 26, 2013 Share #17 Posted March 26, 2013 Has anyone else had trouble unscrewing the filter adaptor ring on their D-Lux 6 cameras? Mine is a US version, but that shouldn't seem to matter. I will write Leica customer service and report back with their reply. Thanks for any more input that someone may have. Quote Link to post Share on other sites More sharing options...
C Lei Lux Posted March 29, 2013 Share #18 Posted March 29, 2013 @ D-Lux6 and all D-Lux6 user, for the compact variants use the 37mm accessories. there is a matching WWK, see lumix X-pancake objective. tip: use two adapter rings. to get one for UV-protection filter, the other for the converter-lens to no vignetting. disadvantage of this variant: the converter-lens to be screwed directly on to the lens*. (*camera objective) for my existing 52mm adapter supplies the vignetting-tubus solution is ideal. the converter-lens is screwed to the tubus and therefore no load for the objective. best regards klaus-michael Quote Link to post Share on other sites More sharing options...
spylaw4 Posted April 5, 2013 Share #19 Posted April 5, 2013 Removing the OEM adapter ring on the DL6 lens can be a bit of an art! The more pressure you apply the less likely it is that the ring will rotate. But it will come off - eventually! Quote Link to post Share on other sites More sharing options...
Guest D-Lux 6 Posted April 19, 2013 Share #20 Posted April 19, 2013 Finally got the ring off, but not without very minor damage. It seems that the two finger method, unscrewing while applying pressure towards the camera did the trick. The threads are rough, and the process doesn't seem to get much easier as you go along. Under no uncertain terms use any tools, no matter what sort of soft material you put between the tool and the lens barrel. A rubber jar opener scratched the nano-surface coating, despite my very best efforts. Oh, what will a trip to New Jersey cost? Quote Link to post Share on other sites More sharing options...
