Leica User Forum
Go Back   Leica User Forum > International User Forum > Leica Collectors & Historica
090909 Promo
Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants!
Register now
Old 05.07.2009, 18:43   #1 (permalink)
Benutzer
Default Macro the hard way...
Hi there,
I've just been and bought myself a Visoflex I, with bellows and lens shade to tack onto my 1937 Leica II for macro work.
The Visoflex and bellows are in really good condition and I was fortunate to get a stack of adapters for it as well. I've just shot a couple of rolls of Velvia 100 using my pre-war 9cm f4 Elmar lens.
As for exposure - well I did that the hard way too Out came 'The Leica Way', several formulas and a calculator. Now I've to wait and see what the results are when the film comes back from the lab (if I'd have been clever, I'd have shot B&W and processed it myself!).
Anyhow, here's the setup...
I'm also going to start a blog based on the trials, tribulations and success(?) with using this setup at Leica Macro
Cheers,
David.
vickersdc is offline   Reply With Quote
Old 05.07.2009, 19:30   #2 (permalink)
Erfahrener Benutzer
Default Re: Macro the hard way...
David,
If you want to make macrophotography it will be on the contrary a pleasure and it will not be hard
I have a group M7 macroadapter 90mm and I really like it
Your Visoflex looks like new
http://www.l-camera-forum.com/leica-...acro-fuji.html
Best regards
Henry
Doc Henry is offline   Reply With Quote
Old 05.07.2009, 19:56   #3 (permalink)
Moderator
jc_braconi's Avatar
Dear sir,
if you use only the head from your Elmar 4/90 you can focus from infinity to 1:1 ratio.
__________________
Best regards
JC
jc_braconi @ LFI Gallery
jc_braconi is offline   Reply With Quote
Old 05.07.2009, 20:24   #4 (permalink)
Benutzer
Quote:
Originally Posted by jc_braconi View Post
Dear sir,
Funnily enough I was using just the 90 head on the bellows today to photograph an orchid. Unfortunately, I don't have the adapter to mount the 90 head directly on to the Visoflex I housing (actually, I'm not sure what adapter I need to look out for!).
Am I right in thinking that you can achieve the same thing (infinity focus) using the 13.5cm Hektor head and bellows? That's likely to be the next lens purchase...
__________________
Interested in macro photography using vintage Leica gear? So am I, and that's why I've just started a blog about my exploits with a Visoflex and Bellows... http://leicamacro.blogspot.com
Old 06.07.2009, 06:36   #5 (permalink)
Erfahrener Benutzer
storybrown's Avatar
A spectacular setup that looks like a lot of fun. Good luck with it!
storybrown is offline   Reply With Quote
Old 06.07.2009, 08:42   #6 (permalink)
Erfahrener Benutzer
doubice's Avatar
Dear sir,
JC,
If I may, I will respectfully disagree. The combined thickness of the Visoflex I and the Bellows I is more than the focal distance needed to obtain ininity focus with the 90mm Elmar. The lens heads with the shortest focal length that allowed infinity focus on the Bellows I were the 125mm and 135mm Hektors.
Only the Visoflex II and III, combined with the Bellows II and the 16558 adapter, will allow infinity to 1:1 focusing with the 90mm Elmar's head.
All the best,
Jan
doubice is offline   Reply With Quote
Old 06.07.2009, 08:51   #7 (permalink)
Erfahrener Benutzer
doubice's Avatar
David,
The adapter needed for the 90mm Elmar head has code 16575 (old code UOOTG). It will however, not allow infinity focus. You will be able to achieve that with the lens head of the 4.5/135mm Hektor. Your Bellows I was originally delivered from the factory with an adapter that allowed this - code 16570 (or UOOST).
Best,
Jan
Old 06.07.2009, 10:00   #8 (permalink)
Moderator
jc_braconi's Avatar
Quote:
Originally Posted by doubice View Post
JC,
All the best,
Jan
Jan, you are surely right, I am too far from my gear at the moment to check about, but if I remember well the rules sidind the base of the bellow are for the 125 and 135 heads.
__________________
Best regards
JC
Old 06.07.2009, 10:12   #9 (permalink)
Benutzer
The markings on the base of my bellows are definitely for the 12.5cm and 13.5cm heads.
__________________
Old 10.07.2009, 12:13   #10 (permalink)
Benutzer
Can anyone provide suggestions / advice on cleaning the mirror in the Visoflex unit? Mine has a couple of 'smudges' that look as if they'll wipe off using lens tissues - but I don't want to do it and completely ruin the mirror!
Comments / advice / helpful hints and tips?...
Thanks,
David.
__________________
Old 10.07.2009, 13:06   #11 (permalink)
Erfahrener Benutzer
Hi there,
Cheers,
David.
Cool, and please show us the pictures! It would be great to see!
__________________
Best
Håkan Dennersten
My Leica Gallery http://www.hd.pp.se/gallery/
dennersten is offline   Reply With Quote
Old 10.07.2009, 16:18   #12 (permalink)
Benutzer
...and I've just managed to get hold of a 1937 13.5cm Hektor lens to go with this setup too!
The two rolls of Velvia have been sent off and I'm awaiting the results...
__________________
Old 10.07.2009, 18:47   #13 (permalink)
Erfahrener Benutzer
doubice's Avatar
Thanks,
David.
David,
Should be quite simple - the Visoflex mirror is no different from any other in-camera mirror. It is silvered on the front surface, you don't want to scratch it by cleaning it too vogorously.
A cotton swab moistened with lens or glass cleaning solution will do fine. I have also used a soft chamois leather - just be careful and wipe very gently. If it is just a surface 'smudge', you should not have any problems.
You'll enjoy using the head of the 135mm Hektor - continuous focusing from infinity to 1:1! I do recommend a steady tripod though.......
Best,
Jan
Old 10.07.2009, 23:33   #14 (permalink)
Benutzer
Thanks Jan, the steady tripod is no problem - I've got a Manfrotto 058 with an Arca-Swiss Monoball on it. It's one heavy piece of kit, and for ages I didn't use it because it was just too heavy to lug around; anyway, I refused to part with it and now I'm glad I didn't
I did ponder on which 13.5cm to get (later or earlier), the later ones generally seem to be in better condition and have coated glass (and the lens shade fits them properly), but I really wanted something that was contemporary with the camera (and the 9cm is an uncoated 1934 model), so to getone made in the same year as the camera is, for me, the right choice. And yes, I realise that the Viso 1 came much later!
Can't wait to try it out and see what these old lenses do...
Thank you,
David.
__________________
Old 17.07.2009, 19:28   #15 (permalink)
Erfahrener Benutzer
Thanks,
David.
Try the edges of the mirror first using a microfibre lens cloth after breathing on the mirror ... and if it cleans the edges ok without damage then gently wipe the centre. But make sure the mark is actually on the mirror and not a reflection from the prism. The Manfrotto and ball head is a substantial support but you might be better off using a copystand with the camera in vertical position - this would ensure the subject on the baseboard is parallel to the film plane. Also, if you are attempting high magnification you could add a focusing rack to the copystand but use it horizontally to enable horizontal movement of the camera across the subject.
This is my setup using a Viso 1 on a copystand . The Manfrotto focus slide has a very fine thread (1 screw turn = 1 mm travel) . There are two slides piggy backed together here to give 'X' and 'Y' movements
Here the Leitz Bellows I and Visoflex with 5 x viewfinder magnifier are mounted but without camera.
Here's the older Elicar focusing slide ... this also has 'X' and 'Y' movements but the adjustment is not so fine as on the Manfrotto slides.
The Elicar is in use with a G1 and Leica bellows on a copystand . Copystand is a basic Krokus model.
Cheers
dunk
__________________
Faith is the bird that feels the light when the dawn is still dark. ... Rabindranath Tagore
dkpeterborough is offline   Reply With Quote
Old 17.07.2009, 21:41   #16 (permalink)
Benutzer
Blimey Dunk, I thought my setup consisted of enough doodads and gadget... quite clearly I could learn a lot from you
Here's the first image posted (of a Carnation) from my setup...
Details:
Camera: 1937 Leica II, 1934 90mm f4 Elmar (uncoated lens), Viso I.
Film: Fuji Velvia 100
__________________
Old 17.07.2009, 22:23   #17 (permalink)
Erfahrener Benutzer
Lotw's Avatar
Wonderfull artistic image, worth the effort!
Lotw is offline   Reply With Quote
Old 17.07.2009, 22:28   #18 (permalink)
Benutzer
Thanks for that, here's another one that I shot with the same setup, although I'm not as taken with this one...
__________________
Old 17.07.2009, 23:02   #19 (permalink)
Erfahrener Benutzer
Lotw's Avatar
Quite surgical this last one! Do I sense some hunger for magenta in Velvia 100? I think Provia 100 would give even more beautiful results here
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
