| Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants! |
#1 (permalink) |
Erfahrener Benutzer
Some months ago i bought myself a leica MD at ebay, wanted to do some macro and i wanted one for the collection It ended up on the shelf without looking at it. Had a tough spring.
So it was resting there until today when i investigated it. Very much to my surprise it is M39 screwthreads .... It seems to be a rebuild. The M type lens release button is there. The really boring part is that the threads are fitted to deep into the body so i can't use it with my Elmar and Summarit. I can't screw it on all the way. So the question to you guys are: Have you ever heard about such a conversion? Can you understand why? Seems like a really big thing to do. Must have been cheaper to buy a screwmount camera? And do you think i can use it with Visoflex? (I really hope so ....) which parts do i need? |
| Advertisement (gone after free registration) |
#2 (permalink) |
Erfahrener Benutzer
Håkan,
Are you sure that you don't have a thread mount to M mount adapter attached to the camera? Best would be to post a picture of the camera's lens mount here.... regards, Jan |
#3 (permalink) | |
Erfahrener Benutzer
Quote:
I have taken pictures, i've forgot my cable at home, i am out in my summerhouse now. There will be some pictures on monday. regards Håkan |
#4 (permalink) | |
Erfahrener Benutzer
Quote:
Best Håkan |
#5 (permalink) |
Erfahrener Benutzer
Hi everybody. Finally back in town and here are the pictures of the MD. I have tried extremly much brute force, but i can't make the plausable inner ring to move. So what do you say guys? Are we looking at a stuck M adapter here?
#7 (permalink) |
Erfahrener Benutzer
Håkan,
The mount looks just like the one used on 'convertible' 35mm Summicrons and Summarons. The red dot just about confirms it too. I am sure that it can be removed but, a special tool will have to be used; the adapter is very difficult to grasp with bare hands. I would try , in the following order:
Good luck, Jan |
#8 (permalink) |
Erfahrener Benutzer
No, that must be an adapter. What is the mount release button doing there otherwise? You can even see where the lug engages the adapter on the photograph.
#9 (permalink) |
Erfahrener Benutzer
Agree it must be an adaptor, why would it have the red positioning dot if not? Also there would be screws visible to secure it to the body.
You could also try the tiniest drop or two of WD40 applied to the join between the mount and adaptor. |
#10 (permalink) | |
Erfahrener Benutzer
Hi,
Quote:
Try not to destroy it by removing, it's valuable. ![]() You can try with this kind of oil filter clip http://pagesperso-orange.fr/oslad/Public/pince.jpg Or, if you see the little screw 1/3 right of the red dot, and if you have a screw lens. Put the lens in, screw tight and remove the whole. Last edited by Philippe D.; 11.08.2008 at 22:39. |
#11 (permalink) |
Erfahrener Benutzer
For me it resembles a lot the adapter of my Super Angulon f4... pity I haven't it here (I am on vacation in my mountains...) but really I seem to remember that the look (dot, thickness, height) is very similar. But MDs were mainly sold for scientific use... could be also an adapter from some specific LTM gear of this kind.
#13 (permalink) | |
Erfahrener Benutzer
Quote:
Best /HD |
#14 (permalink) | |
Erfahrener Benutzer
Quote:
#15 (permalink) | |
Erfahrener Benutzer
Quote:
What is the adapter called? |
#16 (permalink) | |
Erfahrener Benutzer
Quote:
I am on suggestion 2 now thanks I have a camera repairshop close to work so i will try that on thursday. |
#17 (permalink) | |
Erfahrener Benutzer
Quote:
Yes, this is an adapter which used to come with the 4/21mm Super Angulon, 2.8/35mm Summaron and 2/35mm Summicron. The early versions of these lenses were made with screw mount and Wetzlar used these adapters to convert the lenses to M mount before shipping. Screwing a lens into the adapter may be a good idea but, you have to be careful that you do not damage the mount or the lock button. I have seen this in the past, where too much force shaved a bit of the mount and lenses would not lock properly. Do you have an old rubber tube at home? Or anything with fair amount of grip? Cut it to size, get a similarly sized block of wood and press the combination onto the mount. While pressing, push the lens lock button and turn with all your might. The rubber will prevent slippage, the wood block will give you leverage. Best, Jan |
#19 (permalink) | |
Erfahrener Benutzer
Hi,
Quote:
(Summaron 35mm f/2.8 with M39 > M adapter) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
