| Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants! |
#1 (permalink) |
Erfahrener Benutzer
Dear all,
after just acquiring my IIf and Elmar 3,5 I wanted to ask if there are filters available for this lens and if so is there a specific accessory number? Am particularly interested in Orange filter and UV. Appreciate any advice. regards andy
__________________
“No man hath given his child anything better than good manners.” - Prophet Muhammad (570-632) |
| Advertisement (gone after free registration) |
#2 (permalink) |
Erfahrener Benutzer
The typical - original Leitz filter for Elmar (and many other old Leitz lenses) was the A36 type, with a retaining screw: lot of type-colors available (for instance, different level of yellow, IR and polarizing too). Is rather easy to find them on marketplaces, at reasonable prices. Besides this, there is also an adapter to fit E39 filters on Elmar (SOOGZ, not difficult to find, too) and of course there is no problem to find E39s, original or not: in this case, one must keep in mind that with such adapter the standard hoods for Elmar 5 cm (FISON, FIKUS) CANNOT be mounted, and, for instance,Summicron 50 hoods like IROOA must be used.
For completness, there were also small diameter filters for the Elmar 5 cm only, to be mounted just over the front lens (as the near focusing lenses ELPRO etc) but they are rarer, older, often not clean, and with less colors available. Last edited by luigi bertolotti : 06/22/08 at 03:06 PM. |
#3 (permalink) |
Erfahrener Benutzer
Luigi,
that is perfect information..just what I wanted.many thanks, I will look for the adapter to allow 39mm filters as I have those already. cheers andy
__________________
#4 (permalink) |
Erfahrener Benutzer
Also- Look for WALZ filters made for the Argus C3. They are 19mm threads that fit the Elmar. Advantage: they leave the aperture lever where you can get to it. Other filters must be removed to change the F-Stop. (Dumb luck on my part in discovering this, my C3 misses its filter)
The M-Mount Elmar 5cm F3.5 changed the design, "modern" aperture ring. |
#5 (permalink) | |
Erfahrener Benutzer
Quote:
#6 (permalink) |
Erfahrener Benutzer
Actually there is a way around the f stop adjustment while using the 39mm filters. I use a regular 39mm filter fitted to a Leica SOOGZ 36/39mm filter adapter, then inside that I have a Leica VOOLA ring that allows you to set the aperture without taking the filter off. You just loosen the SOOGZ screw and rotate the SOOGZ then tighten the screw again. Works very well.
__________________
~Peter |
#7 (permalink) |
Erfahrener Benutzer
BRILLIANT, PETER !!! Don't know if the VOOLA is easy to find... but a rapid search detected one at Leica Accessories - Manfred Schmidt Collectibles Cameras & Accessories and another at Willkommen im LeicaShop - Startseite de.
#8 (permalink) |
Erfahrener Benutzer
peter and luigi,
thanks for these details...am scanning in germany for a SOOGZ but no luck yet...will keep my eyes open...thanks so much andy
__________________
#9 (permalink) | |
Erfahrener Benutzer
Quote:
I am contemplating getting a UV for my lens. Gerry |
| Thread Tools | |
| Display Modes | |
