Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Leica Collectors & Historica
Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants!
Register now
Tags: ,
Old 03/08/08, 12:52 AM   #1 (permalink)
ejd
Erfahrener Benutzer
Default Flash at low speeds on IIIF or IIIG
Can you use a flash on a IIIF or IIIG at low speeds? As you can on most cameras. E.g., with a IIIF R/D you are told to set the flash timing ring to 20 if you use 1/50 sec exposure or 0 if you use 1/25. But what do you do if you want a slower speed? 1/8, for example? Does the flash still work OK? The IIIG just offers you flash sync at what looks like 1/50 and 1/25.
ejd is offline   Reply With Quote
Old 03/09/08, 10:45 AM   #2 (permalink)
Erfahrener Benutzer
Default Re: Flash at low speeds on IIIF or IIIG
Quote:
IIIg: set the main dial to the red lightning flash next to 1/30 sec and then set the slow speed dial to whatever you want.
IIIf: if the 0 setting works at 1/25 it will probably work at all slower speeds. The IIIf manuals included a table showing the sync settings for different kinds of flash at different speeds; there's sure to be a copy on the internet somewhere. Or you can test it yourself: Take the lens off, dial the flash to its lowest power, and look at the film gate as you fire the camera. If you see the entire pressure plate or film surface, that's good; if you see all or part of a shutter blind, you've got the wrong setting.
__________________
John
http://jn.smugmug.com
giordano is online now   Reply With Quote
Old 03/09/08, 03:39 PM   #3 (permalink)
ejd
Erfahrener Benutzer
Thanks for this. You're right -- I should try it out and see what happens.
Rgds, John
Old 03/11/08, 03:21 AM   #4 (permalink)
Erfahrener Benutzer
earleygallery's Avatar
John - in short it will work at slower speeds, but of course you need to bear in mind the ambient light and effect on exposure as well as movement (unless using a tripod).
__________________
Regards,
James
www.earleygallery.com
earleygallery is online now   Reply With Quote
Old 03/11/08, 09:22 AM   #5 (permalink)
ejd
Erfahrener Benutzer
James -- thanks. I will try it out. All the best, John
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
