Leica User Forum B+H The Professional's Source - Leica
Go Back   Leica User Forum > International User Forum > Leica Collectors & Historica
Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants!
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old November 8th, 2007, 05:58 PM   #1 (permalink)
Neuer Benutzer
Default Leica M6 rewind mechanism stiff
While rewinding film on my Leica M6 i exprience resistance which makes the rewinding crank very stiff. Though i succeed to have the film back in the cassette, still it seems that it is to much of ressistance and on long run may result even in damage. I do all as need to be done as i used leica M3 , M2 and M4 without such problem.
Could be my camera has foult - yet it was inspected by repairman, said no problem.
onogawa is offline   Reply With Quote
Old November 9th, 2007, 08:48 AM   #2 (permalink)
Erfahrener Benutzer
Default AW: Leica M6 rewind mechanism stiff
Josef,
I use a M6TTL, M2 and M3 for years now. I too notice that rewinding the M6TTL is remarkable stiffer than rewinding the M2/ M3. Never had problems of damaged film.
Regards
Oliver
kodaktrix is offline   Reply With Quote
Old November 10th, 2007, 03:43 AM   #3 (permalink)
Erfahrener Benutzer
doubice's Avatar
Default Re: Leica M6 rewind mechanism stiff
Josef,
The spindle that is attached to the base plate of your M6 (not sure exactly what it might be called - the one that pushes the film down onto the M6's take-up spool), adds resistance to the whole rewind process.
Make sure that this spindle is not binding and providing more resistance than usual. I have had this happen to me - switched baseplates from an M4 to an M6, the spindles did not match just right, et voilà - rewind got much stiffer.
Best,
Jan
doubice is offline   Reply With Quote
Old November 10th, 2007, 03:36 PM   #4 (permalink)
Neuer Benutzer
thanks so much for response. in that case i will go along with my leica m6 as it is,though i wonder how it will be when i'll attach the m6 motordrive which i consider to purchase in the future.
Old November 11th, 2007, 11:40 PM   #5 (permalink)
Erfahrener Benutzer
Did you drop the camera on its end. I did once with my M4 and the RW knob bent into the body. The knob had to be replaced.
leitz_not_leica is offline   Reply With Quote
Old November 12th, 2007, 09:23 PM   #6 (permalink)
Erfahrener Benutzer
Quote:
Same thing happened to me on M6ttl, the knob/crank assembly bent and was catching on the top housing. Malcolm Taylor straightened it whilst checking the camera over and adjusting the rangefinder. I thought the shaft had bent but he says that is very strong, he has never seen one bent.
Gerry
gyoung is offline   Reply With Quote
Old November 13th, 2007, 05:49 PM   #7 (permalink)
Neuer Benutzer
it did not fell down but it is second hand body so i do not know before. it was send to Don Goldberg but he returned it saying it is ok, but still the rewinding remains very stiff, contrary to my previous body - much older but very easy rewind, also my m3 is so easy to rewind.
Old November 14th, 2007, 01:01 AM   #8 (permalink)
Erfahrener Benutzer
doubice's Avatar
Quote:
Josef,
If Don Golberg says it's OK, than it must be OK. There are not too many better Leica technicians on this side of the Atlantic.......
Best,
Jan
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
