Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Leica Collectors & Historica
Startseite Register FAQ Members List Calendar Mark Forums Read
Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants!
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old October 24th, 2007, 12:50 AM   #1 (permalink)
Erfahrener Benutzer
jc_braconi's Avatar
Default UVa Filter E43 for Summarit
Hello,
I just found this filter, complete with box and keeper, as you know Summarit 1.5/50 are E41, this let may thinking of the first Summilux(es) 1.4/50 which are E43 and were first called Summarit(s)
note the double engraving E. Leitz N Y SL and GERMANY
(the diameter is exactly E43)
comments welcome
Cheers
JC
jc_braconi is offline   Reply With Quote
Old October 24th, 2007, 04:21 PM   #2 (permalink)
Erfahrener Benutzer
Default Re: UVa Filter E43 for Summarit
XOOYL is listed as an E41 filter in the Hove accessory pamphlet. In the Hove lens pamphlet the Summarit is listed as accepting an "E41 or slip-on 43mm" filter.
tummydoc is offline   Reply With Quote
Old October 24th, 2007, 10:25 PM   #3 (permalink)
Erfahrener Benutzer
jc_braconi's Avatar
You can see on the box the picture illustrate shows a threaded filter
James Lager book II : Lenses depict on page 235 a Summarit 5cm 1.4:50 which is a prototype Summilux
Cheers
JC
Old October 25th, 2007, 07:27 AM   #4 (permalink)
Erfahrener Benutzer
luigi bertolotti's Avatar
Thanks for sharing, JC, ... even in small accessories one can find rare and unusual items... the engraving is intriguing, and for the diameter... who knows ? One can speculate something about the first batches of Summiluxes or "Summarits 1,4"... with the regular E43 UV filter not yet in production...
I have a XOOYL, with its box, but it's a standard E41, and my E43 UV for Summilux is completely different from the item you post : chrome mount is thinner, and with the standard engraving (and had a different code, of course, 13206 or YMZOO if I remember right)
luigi bertolotti is offline   Reply With Quote
Old October 25th, 2007, 07:13 PM   #5 (permalink)
Erfahrener Benutzer
Ivar B's Avatar
These filters are nice, but for a user they often leave something to be desired. New filters often have much better coating.
Regarding 43mm filters, you need Leica as all other filters I have seen are too thick and one cannot mount the hood with the filter in place. The solution has been to remove the glass from the Leica mount (easy), cut open the rim of a modern filter like B + W MRC, and mount the glass back in the Leica mount. This gives you a "modern" filter but with the classic Leica look.
Ivar B is offline   Reply With Quote
Old October 26th, 2007, 03:32 PM   #6 (permalink)
Erfahrener Benutzer
Quote:
Actually the picture doesn't show all that clearly that the filter has threads. Neither do female threads on the out-side rear preclude the inside-rear from slipping on over the front-piece of a Summarit.
However the filter is an EL NY and could well have been a small run contracted by them for a specific purpose, such as fitting to early Summilux lenses prior to production of the Leitz filters which permit fitting of the hood. It is highly doubtful that EL NY issued filters for a hand-ful of prototype lenses.
Old October 26th, 2007, 04:20 PM   #7 (permalink)
Erfahrener Benutzer
jc_braconi's Avatar
I do not use this filter for taking picture,(I am collecting for 42 year), this filter thread on the Summilux 1.4:50 and the original hood slip on to the groove easily.
Old October 26th, 2007, 06:32 PM   #8 (permalink)
Erfahrener Benutzer
jc_braconi's Avatar
May be you can see from l to r the differences between a slip-on #1 and a threaded one E41 #2 on this picts.
#3 is the E43 for Summarit (little steped)and #4 is the E43 for the Summilux.
Thanks for the interest.
Old October 26th, 2007, 07:03 PM   #9 (permalink)
Erfahrener Benutzer
doubice's Avatar
Actually, between the 1940's, 1950's, 1960's and probably even later, Leitz Wetzlar never made Skylight filters. All Skylight filters I have ever seen came from Leitz New York and were marked as such. Most were in mounts supplied by Wetzlar, which explains the 'Germany' engraving.
Best,
Jan
doubice is offline   Reply With Quote
Old October 29th, 2007, 02:43 PM   #10 (permalink)
Erfahrener Benutzer
However #3 (starting from left) lens in your photo appears to be a Taylor, Taylor & Hobson Xenon rather than a Summarit, and that Xenon uses a 40.5mm filter, not a 43mm.
Old October 29th, 2007, 06:39 PM   #11 (permalink)
Erfahrener Benutzer
doubice's Avatar
Vinay,
I would have assumed that a person of your stature and immense knowledge would be aware of the fact that the Summarit 1.5/50mm was also available with the Taylor & Hobson engraving....
Best,
Jan
Old October 29th, 2007, 06:54 PM   #12 (permalink)
Erfahrener Benutzer
jc_braconi's Avatar
This a Summarit Taylor, Taylor & Hobson, Sir, not a Xenon.
Old October 29th, 2007, 08:55 PM   #13 (permalink)
Erfahrener Benutzer
And I have one like this, too ! for the record, it's 822.174, scale in feet as is (I suppose) for all the "Taylor & Hobson" Summarits...
Old October 31st, 2007, 01:19 PM   #14 (permalink)
Erfahrener Benutzer
Some very early Summarits had the Taylor #. At the time, whilst the British patent had expired the US Patent had not yet. These and the late Xenons are almost identical, and even harder to differentiate if the clarity of the photo leaves something to be desired as in this case. Aside from the obvious ring marking which is obliterated in this photo, the aperture scale isn't visible either. That, and to add even more confusion I've seen many examples of Frankenstein cobbling-together of these two series. My Xenon and Summarit are more easily distinguished because my (one and only) Summarit is a Canadian. I have a more extensive array of Summicrons, including a Summitar* (early Cron prototype), and Summiluxes. Lenses of lesser repute such as the Summar and Xenon/Summarit occupy less of my interest.
Old October 31st, 2007, 05:48 PM   #15 (permalink)
Erfahrener Benutzer
jc_braconi's Avatar
Default AW: Re: UVa Filter E43 for Summarit
Thank you Sir for your invaluable help in this post !
jc
Old October 31st, 2007, 09:15 PM   #16 (permalink)
Erfahrener Benutzer
mmmhhh... I can understand, but anyway I sometime regret to have not a non rectractable Summar... years ago I passed away to buy a nice one for less then 400 Euros... now is hard to find at such a price...
Old November 1st, 2007, 03:11 PM   #17 (permalink)
Erfahrener Benutzer
Quote:
I call that being dead serious about Leica-collecting
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
