Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Leica Collectors & Historica
Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants!
Register now
Tags: , ,
Old 10/14/07, 06:49 PM   #1 (permalink)
Benutzer
Default Hektor 28mm 6.3
Would anyone know off-hand the filter size for this lens? I already performed a search on it and it barely registers a blip. Thanks.
-grant
__________________
bedetermined.com
grantray is offline   Reply With Quote
Old 10/14/07, 07:10 PM   #2 (permalink)
str
Erfahrener Benutzer
str's Avatar
Default AW: Hektor 28mm 6.3
34mm srew in an 36mm slip on, if I remember right.
str.
str is offline   Reply With Quote
Old 10/14/07, 07:24 PM   #3 (permalink)
Benutzer
Default Re: AW: Hektor 28mm 6.3
Pardon my asking, but what exactly is a "36mm slip on," so that I know what to look for when I'm at my dealer? I'm new to using the older Leitz lenses.
-grant
__________________
bedetermined.com
Old 10/14/07, 08:42 PM   #4 (permalink)
Erfahrener Benutzer
Default Re: Hektor 28mm 6.3
It's a clamp on filter.
leitz_not_leica is offline   Reply With Quote
Old 10/14/07, 10:06 PM   #5 (permalink)
Erfahrener Benutzer
luigi bertolotti's Avatar
A36 filters (with clamping screw) are the standard for almost all old Leitz lenses of prewar age : apart "specials" like Thambar/ Xenon/Telyt, the lens line 28 - 35 - 50 Elmar - 90 Elmar - 135 Hektor is all A36; is not difficult to find them (I have 5 or 6 included the polarizing and the UV). The problem is if you think of M8 and the perennial UVIR... no one seems to produce such an old style mount... But old Leitz solved this issue about 50 years ago... there is a ring (SOOGZ - 13154, have it too... ) which clamps on A36 mounts with the usual screw, and has an E39 thread at the other side, so you can find all the filters you like, UVIR included: it's a simple ring, and I do not think is difficult to find one for about 50 Euros (I bought mine more than 20 years ago...)
Just a collector curios... is your item pre or postwar ? The postwars with number on front and interational f/ scale to f/22 are very rare .... I'd like to have one...
luigi bertolotti is offline   Reply With Quote
Old 10/14/07, 10:09 PM   #6 (permalink)
str
Erfahrener Benutzer
str's Avatar
thanks, leitz_not_leica.
The left one ist an old original Leitz filter 34mm screw in (not coated), the right one a
Heliopan 34mm screw in filter (coated, made on request), the middle one an original Leica
slip on (36mm). You may hardly find screw in filters, very often a slip on, they are very
fine. (Please excuse my English.)
str.
Old 10/14/07, 10:18 PM   #7 (permalink)
Erfahrener Benutzer
Wow Stjefan !!! I never saw an original 34 screw in !!! We collectors give the right weight also to these little items, and yours is surely a rarity... have you also some of the "super large size" like the E58 (Summarex - Hektor 125) or E85 for 400 ? I have 2 or 3... they are BIG and fine...
Old 10/14/07, 11:29 PM   #8 (permalink)
str
Erfahrener Benutzer
str's Avatar
My father bought this filter with a IIIa and a Summar in 1936. I later found a 58
and use it with the Hector 12,5 cm. Once I saw a new 85, if I remember right, in
a store in Swizerland. There it was since about 50 years
str.
Old 10/16/07, 01:55 AM   #9 (permalink)
Benutzer
Thanks for the information, Luigi. As I am using this on my M8, I'd love to see that ring you write of that allows for an E39 ir/cut filter. That way I know what to keep an eye out for!
Also, my lens is pre-war. I'm not interested in rare variations at the moment unless they have coatings or formulas that produce special qualities. The post-war is the same lens formula and coating, correct?
-grant
__________________
bedetermined.com
Old 10/16/07, 12:13 PM   #10 (permalink)
str
Erfahrener Benutzer
str's Avatar
Yes, it is.
str.
Old 10/27/07, 01:32 AM   #11 (permalink)
Benutzer
If all goes well, Craig from Tamarkin will be snagging a clamp for me from the CT store tomorrow. And if that isn't good enough, that one clamp will do triple duty for the 28mm Hektor, freshly acquired 1935 Summar (damn you again Tamarkin!), as well as the 1951 90mm Elmar.
Thanks for the help.
-grant
__________________
bedetermined.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
