Leica User Forum B+H The Professional's Source - Leica
Go Back   Leica User Forum > International User Forum > Leica Collectors & Historica
Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants!
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old 09/02/07, 05:47 PM   #21 (permalink)
Erfahrener Benutzer
Photoskeptic's Avatar
Default Re: Leica m4, some questions about filter and manteniance
Charlie, i just sold my M4. Hated to see it go but I prefer my M3 because I only shoot film with a 50 cron and I decided to get down to just one film body. I use a yellow filter when there are clouds present. And that's it. I looked into the polarizer setup that Robert White sells in England, but rejected it because it seemed to soften the image. Your experience may be different as different film and lenses seem to react differently. Anyway, enjoy your camera.
Photoskeptic is offline   Reply With Quote
Old 09/15/07, 03:59 PM   #22 (permalink)
Neuer Benutzer
Solved the problem of the revision: about 170€! And now I am a lot more sure of the camera "good state"..
For the filter I have found a new leica filter with the right diameter (43) but it is not a simply uv filter, it is an uv/ir filter designed for the m8.. It would be a bad idea to use it on my summilux?
thank-you!
ziofanale is offline   Reply With Quote
Old 09/15/07, 05:47 PM   #23 (permalink)
Erfahrener Benutzer
luigi bertolotti's Avatar
thank-you!
... e adesso GODITI la tua M4 fresca fresca !!!! Non so bene come si comporti l'UVIR con la pellicola... qualcuno ci avrà di certo provato... in teoria, non credo che faccia danni... dovrebbe fare il lavoro di un UV e in più bloccare certe frequenze di infrarosso, a cui peraltro le pellicole non sono sensibili. Però con i grandangolari potrebbe dare lo strano problemino cosidetto "cyan drift" ... sulla M8 viene corretto dal software, non so però se sulle pellicole si presenti, però non c'entra con il sensore digitale... ha a che fare con il filtro in se' per via di riflessioni interne dovute ai due strati filtranti (qui nel forum si impara di tutto ... )
Saluti Luigi
PS : hai degli altri obiettivi ?
luigi bertolotti is offline   Reply With Quote
Old 11/13/07, 10:11 PM   #24 (permalink)
Neuer Benutzer
josephgalilee's Avatar
Daumen hoch Re: Leica m4, some questions about filter and manteniance
I confirm that the best CLA for Leica camera in Italy you can get to SAM.CA (Sammartino e Casanova) from Genova, historical Leitz Service. They got experience to Leitz Wetzlar training service. A CLA for your M4 (for example) cost about € 250. To the end of well job they apply seal "G" on your camera. So your advance lever will be silk smooth "horse pair", neither Solmser Service will tend with this results. When i move the advance lever of my M2-R with care CLA of SAM.CA it look like the silent and sweetness smooth of the first M3. Theys still use the famous six Leitz special greases for the correct lube of ancient Leitz camera.
Buona serata a tutti fratelli, tra poco tornerà il mitico marchio Leitz Wetzlar sui prodotti grazie al Dr. Kaufmann che sta preparando un ritorno a Wetzlar in grande stile con il Leitz Park.
Vielehn dank Dr. Kaufmann.... for the next return to the great classic brand Leitz Wetzlar Gmbh. Wundebar!
Ciao
giuseppe
josephgalilee is offline   Reply With Quote
Old 11/14/07, 09:50 PM   #25 (permalink)
Erfahrener Benutzer
jc_braconi's Avatar
Ciao Charlie
ti ho lasciato un messagio personale.
Auguri
JC
jc_braconi is offline   Reply With Quote
Old 11/14/07, 10:31 PM   #26 (permalink)
Erfahrener Benutzer
Charlie, I had an M4 for about the same time as you. Incredibly sturdy bodies, won't need a CLA unless you really get something out of whack. I reluctantly let it go as I was reducing my film body collection to just an M3 which I prefer because I only use a 50 cron for film
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
