| Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants! |
Leica Products
Leica M240 Amazon US | B&H | Dale | Adorama | eBay |
Leica M Monochrom B&H | Dale | Adorama | eBay |
Leica M-E Amazon US | B&H | Dale | Adorama | eBay |
Leica X Vario B&H | Adorama | Dale | Amazon | eBay |
Leica M9-P Amazon US | B&H | Dale | eBay |
#1 (permalink) |
Erfahrener Benutzer
Ad
OUFRO : Large Knob : Large Red Pin : Ernst Leitz Wetzlar Germany16469Y : Small Knob : Large Red Pin : Ernst Leitz Wetzlar Germany 16469 : Small Knob : Small Red Pin : Leitz Wetzlar Germany 2011-05-09_22-18-52-•-M9-Viso_III-65mm-f3.jpg 2011-05-09_22-29-05-•-M9-Viso_III-65mm-f3.jpg M9 + Visoflex III + Elmar 65/3.5 Provided these are indeed original items, when were the different versions made? Best, K-H. |
#2 (permalink) |
Erfahrener Benutzer
A fine multistrate extension tube...
... I think in the right time order - oldest at the top and all the weight on the shoulders of the youngest : I am not 100% sure, but by logic the 5 letters code were the first, then the 5 digits with letter (whose significance, btw, has been always unclear to me... I have never seen 2 identical set of digits with a different letter), then the "modern" (still used) 5 digits-only code... imho, the obliteration of the name "Ernst" is also a sign of a later build.
| Thank You says | k-hawinkler (10/05/11) |
#3 (permalink) |
Erfahrener Benutzer
Luigi,
You are quite right. That's how I sometimes use them. DSC_2633.jpg Here coupled with some Kenko extension tubes for Nikon mounts and Leica to Nikon and Nikon to Leica adapters on M9, Viso, and 400/5.6. Some images obtained with this rig: 2011-05-10_10-23-03 • M9 Viso III extension rings 400mm f5.6 - Bees_00_small.jpg 2011-05-10_10-39-43 • M9 Viso III extension rings 400mm f5.6 - Bees_00_small.jpg 2011-05-10_10-49-52 • M9 Viso III extension rings 400mm f5.6 - Bees_00_small.jpg 2011-05-10_09-40-54 • M9 Viso III extension rings 400mm f5.6 - Bees_00_small.jpg A couple more images are posted here: http://www.l-camera-forum.com/leica-...-3-images.html Bees need water too. Best, K-H. |
| Thank You say... |
#4 (permalink) |
Moderator
Impressive results ! Congratulations !
__________________
Best regards JCBraconi Leica Ambassador LEICA HISTORICA web site jc_braconi @ LFI Gallery |
#6 (permalink) |
Erfahrener Benutzer
Hello K-H.,
thank you for the pictures of the stacked rings and the bees. The rings have a small shift in the position of the locking mechanism. Does somebody now the reason why the rings have a misalignment of about 0.5mm / circa ~1.5° in the same direction? Greeting Thorsten Last edited by Leica Dao; 28/08/11 at 23:41. Reason: ___ |
#7 (permalink) |
Erfahrener Benutzer
I'm not sure is like you say... can be a "taking effect"... imho, if one takes a precisely composed picture (stacked knobs along the vertical axis of the frame, center of the frame at 1/2 of the height of the stack) they probably result perfectly aligned... the tolerancing of the bayonet engagement must be very strict... of course, is not like this for the position of the red dot, which can have a rather rough tolerancing.
#8 (permalink) |
Erfahrener Benutzer
Thank you L.B.,
my first thoughts were the same - but my small stack is rotating the lock a little. Greeting Thorsten Last edited by Leica Dao; 28/08/11 at 23:59. Reason: . |
#9 (permalink) |
Erfahrener Benutzer
Well I have stacked up my 10 rings, namely 3 OUFRO, 5 16469Y, and 2 16469.
The only rings that stack up without a shift are the two 16469. ![]() The other eight seem to be shifted by about the same amount and line up at a slight angle with little variation. One of the 16469Y rings seems to be shifted hardly at all. Of course, there is some play. However, even if I force the rings to line up as much as possible the slight shift remains. ![]() Could it just be a slight misalignment in the manufacturing setup from batch to batch? Funny but unimportant in using the rings. ![]() K-H. |
#12 (permalink) |
Erfahrener Benutzer
Well... indeed, thinking well of it, my considerations about tolerancing were not 100% correct...
: strict tolerancing is needed in the angular positioning of the slot towards the male bayonet (bottom part of the ring) and, same way, the knob towards the female bayonet (top part of the ring) , but the two parts, in itselves, can afford a certain misalignement of some degree, one to each other: as noted above, this does not compromise the functionality of the device... the only inconvenient with a std. lens mounted onto is to have, say, the focus datum line not exactly at 12 o'clock... minor issue.
| Bookmarks |
| Current eBay Ads |
Current bid:
400 USD (25 bids)
Current bid:
297.64 GBP (0 bids) |
| Thread Tools | |
| Display Modes | |
