| Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants! |
| Tags: help |
#1 (permalink) |
Neuer Benutzer
Hi I have just obtained A VISOFLEX I in cosmetically good condition, with angled adjustable eyepiece, which full of dust, however, when I look through eyepiece when not attached to anything and no lens attached, I can only see small slit not full frame, is this normal, does anyone know, or does it need correct lens adapter and lens fitted to show anything like a picture. It is the M baynet to body version but sm for lens. What would be the correct adaptor and lens to get just for close ups?
#2 (permalink) | |
Erfahrener Benutzer
Quote:
Enjioy the device, and , when accustomed, buy also a Viso II or III with OUBIO (eh eh, guess what is it...) and a bellows, and an Elmar 65 mm: You can then say to be a real Leica macro amateur old-style |
#3 (permalink) |
Erfahrener Benutzer
Raymond,
Luigi just about covered your lens choices, so I won't go there. What I think needs to be addressed is the why you only see "a small slit". The Visoflex I has a mirror (as you probably know) and this mirror should normally stay in its 'down' position. On the right side of the Visoflex body is a release, which should bring the mirror up and when let go, the mirror should fall down by itself. I think your problem is that either the mirror hinge or the release mechanisms are dirty, not allowing the mirror to swing freely. The mirror is probably stuck in the 'up' position and that is why you only see a small slit of light. The Visoflex I is a fairly simple device and depending on how technically adept you are, shopuld not be so difficult to clean. First check if the mirror is moving freely by simply pushing it up and down with the tip of your finger. You should not feel any resistance. Secondly, check the shutter release on the side of the unit. It should also move freely, particularly the outside locking collar. If you feel any binding or resistance while raising the mirror with the release or, if the mirror does not come down by itself, cleaning is what the doctor prescribed...... To help you with the plethora of adapters and usable lenses, try to find an old Leica Manual by Morgan and Morgan - one published in the early to late 1950's. They are quite often found on eBay for less than US$10.00. All the best, Jan |
#4 (permalink) |
Neuer Benutzer
hi guys, many thanks Luigi and Jan, you have indeed been very helpful and information has helped a lot. However it seem that I may have an angled unit that is broken or misaligned. If I take viewing unit off, I see opaque glass with 35mm oblong, mirror i have cleaned and also it moves up and down ok with no problems. Now problem is narrowed down to eyepiece unit, if i look through this, I can only see small slit, the condenser lens? which u can see on baynet fitting end is dusty on inside, I think maybe this unit is damaged and needs attention, does this help better for your advice, regards ray
#5 (permalink) |
Erfahrener Benutzer
Raymond,
It does indeed look as if your finder is defective. I assume that you have the 45 degree finder with a rubber finder occular. This finder has a series of prisms inside and it is possible that it was dropped and some of the prisms are out of alignment. The worst case scenario would be if one of the prisms became de-cemented...... You can access the innards by removing the plate which holds the finder occular. All the best, Jan Last edited by doubice : 02/23/07 at 07:12 PM. |
#6 (permalink) |
Neuer Benutzer
Hi guys, I have spoken to Malcolm Taylor, Herefordshire, U.K. and he has suggested I send it to him to look at, as he is already attending to a 50mm Summitar for me, will let you all know result, when he returns it. Many thanks again to all who treid to help me.
#8 (permalink) |
Neuer Benutzer
hi guys, Malcolm Taylor sorted the visoflex, it would appear some one had tried to clear dust in it previously and not reassembled prisms correctly. Malcolm cleaned and reassembled correctly now unit works fine, also he did great job on a Summitar same time(elements hazy) he did service on lens and that now like new again.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Visoflex lenses on Leica R cameras | gvaliquette | Customer Forum | 2 | 12/09/06 02:11 PM |
| Visoflex und Blitz | esser | Digitalforum | 14 | 12/05/06 07:18 PM |
| M8 with Visoflex | ejd | Digital Forum | 7 | 09/22/06 09:38 AM |
| Gebrauchsanleitung visoflex III | schleswig | Leica Kundenforum | 39 | 09/17/06 11:31 PM |
| Frage zu Visoflex III | harald_ludwig | Leica Kundenforum | 18 | 07/10/06 12:08 PM |
