Leica User Forum Robert White
Go Back   Leica User Forum > International User Forum > Leica Collectors & Historica
Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants!
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Tags: , , ,
Old January 30th, 2007, 08:08 PM   #1 (permalink)
Erfahrener Benutzer
bill's Avatar
Default VIDOM help wanted - apply within.
So.
My VIDOM arrived today.
Some questions to those with more experience.
1. There's a small lump of cack inside. Is it easy to take it apart and clean it out?
1a.If so, where do I start?
2. I understand how the parallax correction works, but why is there a leetle line on the focal length selector beside the main line? When should I use that?
3. I know the image is inverted, and that's not a problem, but why can I turn it upside down - what advantage does that give me?
Thanks chaps!
Regards,
Bill
bill is offline   Reply With Quote
Old January 30th, 2007, 10:26 PM   #2 (permalink)
Erfahrener Benutzer
Default Re: VIDOM help wanted - apply within.
Bill, I have also aquired a VIDOM recently, mine also has dirt inside, the image is not inverted but reversed laterally. there were several versions of this finder, mine has a removable collar on the nose with two holes for a pin spanner which I will make in the next few weeks.
I havent tried to dismantle it yet but I will. Keep in touch, I will let you know of progress.
Regards, Stuart
stumac is offline   Reply With Quote
Old January 30th, 2007, 11:08 PM   #3 (permalink)
Erfahrener Benutzer
bill's Avatar
Hi Stuart,
I've been busy since my first post...
First of all, I tried from the back. I undid the tiny grub-screw on the milled bit. That milled bit then unscrews. Under it are three more screws, one grub and two slightly larger. I undid them all, but couldn't get any further. I reassembled that bit, and turned my attention to the front. Although I don't have circlip pliers, I was able to shift the front collar using two jeweller's screwdrivers in tandem. Underneath are three more grubscrews set equidistant around the nose. If you uncrew these, the whole nose drops out easily into your hand.
I carefully cleaned the glass at the back of the nose with a microfibre cloth, then used a can of compressed air to give the rest of the assembly a good blasting. While there, admire the quality of the internal construction; you can see that the different focal length views are achieved by two L-shaped pieces of metal that move in unison when you rotate the selector ring.
I put it all back together, and voila! The original bit of cack has gone...
...to be replaced by a tiny shred of fluff...
C'est la vie. When I have time I'll "field strip" the bugger again and get that out too! At least now I know how.
Regards,
Bill
Old January 31st, 2007, 01:20 AM   #4 (permalink)
Erfahrener Benutzer
doubice's Avatar
Quote:
Originally Posted by bill
So.
1. I understand how the parallax correction works, but why is there a leetle line on the focal length selector beside the main line? When should I use that?
2. I know the image is inverted, and that's not a problem, but why can I turn it upside down - what advantage does that give me?
Bill
Bill,
Sorry - I was off line and could not help with the disassembly instructions. I see however, that you did quite well. Fluff sounds better than cack......
1) The short line on the focal length selector allows for the lens' narrower field of view at short distances: the two L-shaped plates will show less when the dial is set to the short line.
2) Due to the optical design of the VIDOM, not only is the image lateraly reversed, but it will also turn upside down when viewing vertically. That is when you will turn the milled ring at the ocular...... est voilà - the image is right side up again.
All the best,
Jan
doubice is offline   Reply With Quote
Old January 31st, 2007, 07:02 AM   #5 (permalink)
Erfahrener Benutzer
Thanks for the info Bill, I wont have to tread so carefully when I start.
Regards, Stuart.
Old January 31st, 2007, 12:01 PM   #6 (permalink)
Erfahrener Benutzer
flatfour's Avatar
Jan - I always understood that the little short line was the infra red setting for any distance.
flatfour is offline   Reply With Quote
Old January 31st, 2007, 03:54 PM   #7 (permalink)
Erfahrener Benutzer
doubice's Avatar
Quote:
Anthony,
Only lenses have a separate IR focusing index, as it is needed for correctly focusing IR films. Viewfinders do not need this - all you are doing is sighting through them.
Cheers,
Jan
Old January 31st, 2007, 04:33 PM   #8 (permalink)
Erfahrener Benutzer
bill's Avatar
Thanks Jan, much appreciated. Thought it might be something like that.
Roll on the weekend when I can try this baby out...
Regards,
Bill
Old February 1st, 2007, 05:52 PM   #9 (permalink)
Erfahrener Benutzer
jc_braconi's Avatar
Parallaxe setting is on the foot and in the viewfinder too.
you have a long index and a short one : easy to understand the frame is different at short instead at long distance.
you can see this on fixed focal outside viewfinders with the interupted line in the brilliant frame for short distances.
cheers
jc
jc_braconi is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
St Paul's... digital help wanted. elansprint72 Architecture 7 November 17th, 2006 08:57 AM
