Leica User Forum Robert White
Go Back   Leica User Forum > International User Forum > Leica Collectors & Historica
Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants!
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old 06/22/08, 11:07 AM   #1 (permalink)
Erfahrener Benutzer
Default Elmar 50/3,5 filters
Dear all,
after just acquiring my IIf and Elmar 3,5 I wanted to ask if there are filters available for this lens and if so is there a specific accessory number?
Am particularly interested in Orange filter and UV.
Appreciate any advice.
regards
andy
__________________
“No man hath given his child anything better than good manners.”
- Prophet Muhammad (570-632)
andym911 is offline   Reply With Quote
Old 06/22/08, 01:57 PM   #2 (permalink)
Erfahrener Benutzer
luigi bertolotti's Avatar
Default Re: Elmar 50/3,5 filters
The typical - original Leitz filter for Elmar (and many other old Leitz lenses) was the A36 type, with a retaining screw: lot of type-colors available (for instance, different level of yellow, IR and polarizing too). Is rather easy to find them on marketplaces, at reasonable prices. Besides this, there is also an adapter to fit E39 filters on Elmar (SOOGZ, not difficult to find, too) and of course there is no problem to find E39s, original or not: in this case, one must keep in mind that with such adapter the standard hoods for Elmar 5 cm (FISON, FIKUS) CANNOT be mounted, and, for instance,Summicron 50 hoods like IROOA must be used.
For completness, there were also small diameter filters for the Elmar 5 cm only, to be mounted just over the front lens (as the near focusing lenses ELPRO etc) but they are rarer, older, often not clean, and with less colors available.
luigi bertolotti is offline   Reply With Quote
Old 06/22/08, 02:59 PM   #3 (permalink)
Erfahrener Benutzer
Luigi,
that is perfect information..just what I wanted.many thanks, I will look for the adapter to allow 39mm filters as I have those already.
cheers
andy
__________________
Old 06/22/08, 03:05 PM   #4 (permalink)
Erfahrener Benutzer
Also- Look for WALZ filters made for the Argus C3. They are 19mm threads that fit the Elmar. Advantage: they leave the aperture lever where you can get to it. Other filters must be removed to change the F-Stop. (Dumb luck on my part in discovering this, my C3 misses its filter)
The M-Mount Elmar 5cm F3.5 changed the design, "modern" aperture ring.
brianv is offline   Reply With Quote
Old 06/22/08, 03:10 PM   #5 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by andym911 View Post
Luigi,
cheers
andy
Thanks for the appreciation but... I forgot the warning well described by Brian... dismount a filter to adjust f stop can be really a little annoying....
Old 06/22/08, 04:24 PM   #6 (permalink)
Erfahrener Benutzer
peter_n's Avatar
Actually there is a way around the f stop adjustment while using the 39mm filters. I use a regular 39mm filter fitted to a Leica SOOGZ 36/39mm filter adapter, then inside that I have a Leica VOOLA ring that allows you to set the aperture without taking the filter off. You just loosen the SOOGZ screw and rotate the SOOGZ then tighten the screw again. Works very well.
__________________
~Peter
peter_n is offline   Reply With Quote
Old 06/22/08, 07:19 PM   #7 (permalink)
Erfahrener Benutzer
BRILLIANT, PETER !!! Don't know if the VOOLA is easy to find... but a rapid search detected one at Leica Accessories - Manfred Schmidt Collectibles Cameras & Accessories and another at Willkommen im LeicaShop - Startseite de.
Old 06/22/08, 07:39 PM   #8 (permalink)
Erfahrener Benutzer
peter and luigi,
thanks for these details...am scanning in germany for a SOOGZ but no luck yet...will keep my eyes open...thanks so much
andy
__________________
Old 06/22/08, 09:07 PM   #9 (permalink)
Erfahrener Benutzer
I checked with a B&W rep a couple of weeks ago at a trade do, they still list 19mm filters which I think fit the inner thread of the 3.5 Elmar/50 mm. They would have to order them (in UK), they are not a stock item, but they sre in the catalogue.
I am contemplating getting a UV for my lens.
Gerry
gyoung is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
