Leica User Forum
Go Back   Leica User Forum > International User Forum > Leica Products > Film Forum
Film Forum The Film Forum is about everything regarding non-digital 35mm photography - films, dark room and slide projection
Old 24/01/09, 00:09   #1 (permalink)
Neuer Benutzer
Default How do I flatten film before scanning?
Ad
I have recently started developing and scanning my own film. I am now comfortable doing both, but my issue lies at the step in between.
My negatives are very curved after drying, and I am certain that some of the scratches that I am seeing in the scans are a result of feeding excessively curled film into the scanner.
Also, I am going to modify my 5000ed to scan entire rolls of film at once, using the instructions here:
Nikon Coolscan Roll-Feeder Conversion
So, how can I flatten the entire roll (without cutting into smaller pieces)? Also, does the humidity affect the curling of the film when it dries (my house is currently quite dry).
scotteci is offline   Reply With Quote
Old 24/01/09, 00:23   #2 (permalink)
Neuer Benutzer
Default Re: How do I flatten film before scanning?
After the final wash before you leave the film to dry, roll the film back onto the reel but with the emulsion pointing outwards so it negates the original curl of the film, then leave it on the reel to dry that way.
wontonny is offline   Reply With Quote
Old 24/01/09, 00:30   #3 (permalink)
Neuer Benutzer
My negatives are curled from the edges in, if that makes sense...if you put them flat on a table, they stand on edge and look like a upside down "U".
Would re-reeling cure that ?
Old 24/01/09, 00:44   #4 (permalink)
Sponsoring Member
stunsworth's Avatar
It takes time - or the gentle pressure of a book. Looking at negatives that I shot a few years ago, many were curled just after development. Non are curled now.
Try putting the negatives in negative sleeves and then placing the sleeve between two heavy books overnight.
I always found C41 negative the worst just after development.
__________________
Steve
Flickr
Twitter
stunsworth is online now   Reply With Quote
Old 24/01/09, 00:50   #5 (permalink)
Neuer Benutzer
Steve,
Thanks, but with the scanner modded to scan the entire roll at once, I want to able to flatten the entire roll at once, without cutting and putting into sleeves, etc.
Old 24/01/09, 00:51   #6 (permalink)
Sponsoring Member
stunsworth's Avatar
Buy long thin books with lots of pages.
__________________
Steve
Flickr
Twitter
Old 24/01/09, 00:53   #7 (permalink)
Neuer Benutzer
LOL!
Comicbooks would probably be appropriate for me!
Old 24/01/09, 01:55   #8 (permalink)
Erfahrener Benutzer
rob_x2004's Avatar
Im not sure you will ever get the curl out. With the memory the emulsion has, as soon as the humidity changes all bets are off anyway.
One thing you might look at if you have excessive curl is your development time. Since scanning I develop a little less chunky which seems to allow the scanner to see it a bit better too.
Probably worth a few test strips, see how much you have to reduce the development to get perfectly flat negs. In my situation with my film, water, chemicals, concentrations, agitation routines, weather, I used to get unusable negs at twelve minutes and perfectly flat shiny negs at eleven.
rob_x2004 is offline   Reply With Quote
Old 24/01/09, 02:32   #9 (permalink)
Neuer Benutzer
Yes. When you roll it onto a reel it doesnt have the edge to edge U anymore. Just make sure you let the roll dry completely.
Old 24/01/09, 04:50   #10 (permalink)
Neuer Benutzer
For my negs, hanging the strip over-night with weight gives me fairly flat negs on both axes. Occasionally when needed I do the reverse-roll method and plop it in a cup for a couple hours.
mikel is offline   Reply With Quote
Old 25/01/09, 01:26   #11 (permalink)
Neuer Benutzer
Ad
Thanks for the advice everyone. I just tried the reverse-roll method, and after an hour the negs are much better for scanning.
Old 25/01/09, 13:13   #12 (permalink)
Benutzer
The best advice I've had was to do the above, but rather than putting it in a cup, place the roll back into the plastic film canister..... works like a charm.
I've never had problems with curled negs ever since.
hunghang is offline   Reply With Quote
Old 25/01/09, 13:34   #13 (permalink)
Benutzer
magd0328's Avatar
Good advice above. In some extreme cases where I absolutely cannot flatten the negs I cut out the individual frame and mount it in a Gepe 40x40 slide mount. This slide mount is two pieces of glass with a 40x40mm aperture. It holds the neg perfectly flat. One piece of glass is frosted to prevent Newton rings. The frosted glass goes against the film back, not against the emulsion.
magd0328 is offline   Reply With Quote
Reply
Current eBay Ads
Current bid:
450 USD
(1 bids)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.6.0
