Leica User Forum 5% Discount for Forum Members
Go Back   Leica User Forum > International User Forum > Film Forum
Film Forum The Film Forum is about everything regarding non-digital 35mm photography - films, dark room and slide projection
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old 07/14/08, 11:01 PM   #1 (permalink)
Benutzer
Default Polarizing filter on the VE R 35-70mm
See this thread on this Forum:Adapter ring (60mm) for VER 35-70mm lens.
Any one with on-hand experience how and what type filter other then Leica can be used on this lens.
Thanks.
santila is offline   Reply With Quote
Old 07/29/08, 12:22 AM   #2 (permalink)
Benutzer
Cool Re: Polarizing filter on the VE R 35-70mm
Yes, the Heliopan #706039 will fit and work flowlessly on this lens with the Heliopan #701060 60MM rubber lens hood. The lens hood is vignetting at the near end but since it can be folded back the vignetting can be easly corrected. By mistake I did order the linear polarizer (it is about $30 less then the circular) but it will work fine on the entire range.
Old 07/31/08, 04:24 PM   #3 (permalink)
Benutzer
Default Re: Polarizing filter on the VE R 35-70mm
I just found out that linear polarizing filter will not work correctly on R bodies. It will polarizes great but the light meter will not respond properly, so I am exchanging for the Helio circular polarizer # 706041.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
