Leica User Forum 5% Discount for Forum Members
Go Back   Leica User Forum > International User Forum > Film Forum
Film Forum The Film Forum is about everything regarding non-digital 35mm photography - films, dark room and slide projection
Register now
Old 06/21/08, 06:21 PM   #1 (permalink)
Neuer Benutzer
Default focometer
Hello
I have bought a focomat v35 and focometer with it
I am note sure what model,it has a slide from 1-10 and graduations on the very left hand side,the Hove manual states that you should slide a tool looks like a screwdriver into a slot,but mine has no slots just the slide.I am trying to figure out how to work the focometer to take readings of the loaded negative but cant work it out.Does anyone have a manual or any idea how to do this?
Thanks for any help
Andrew
blaz is offline   Reply With Quote
Old 06/22/08, 01:03 AM   #2 (permalink)
Benutzer
Default Re: focometer
Hi,
Mine is black and does have smallslots to calibrate with a smal screwdriver that sits in the back. It is used to calirbate the measurments for youre enlarger and paper.
I should have the manual somewhere here or in my darkroom. But my main computer with the scanner attached isn't working at the moment. I'll see what I can do for you.
Could you post a picture of your focometer so we can see which version it is?
Cheers,
Michiel Fokkema
michiel_fokkema is offline   Reply With Quote
Old 06/23/08, 05:12 PM   #3 (permalink)
Neuer Benutzer
Thanks for your reply
I have taken a photo ,as you can see these is a slider which is different to the model in the Hove manual.Is this a mark 2 model?
Thanks again
Andrew
Old 06/23/08, 11:16 PM   #4 (permalink)
Benutzer
Hi,
I'm not sure if it is mark 2. It is different from mine. I have the black one with the slots.
Sorry, can't help you here.
cheers,
Michiel Fokkema
Old 06/24/08, 12:13 AM   #5 (permalink)
Erfahrener Benutzer
Andrew,
I have a Focometer 2 like yours. Plug the enlarger into the focometer and the FC into the mains.
The left hand slide is to allow to set the paper speed, as some are faster than others. The three central slider sets minutes and seconds if you are timing manually. Do you have the small pale grey sensor on a lead which plugs into the focometer on the back? If you do, this is what you do.
Turn the enlarger on by pressing the middle rectangular button (with light bulb on it). Place the sensor on a zone VI area under the projected image. then press the left hand button (arrow in circle). You should then get a reading on the display. then place the paper on the easel and press the right hand button (with the dot). This should turn the enlarger on for the preset time that you've metered for.
Good luck
Charlie
topoxforddoc is offline   Reply With Quote
Old 06/24/08, 05:07 PM   #6 (permalink)
Neuer Benutzer
Thanks
I know how to manually use it no problems
Have tried with the diffusion disc in place and probe on the centre of picture on the easel,but when I get a reading and repeat the process the readings are not the same.perhaps its broke!!??
Will try again as you suggest
Where does the slider come into play?
Do you have a manual or have you learned by trial and error
Thanks
Old 06/24/08, 11:28 PM   #7 (permalink)
Erfahrener Benutzer
Blaz,
I haven't got a manual. I may have read it in the Leica darkroom handbook. This shows a later Focometer Quartz, but one just adapts that.
As for changing readings on the sensor - the sensor diameter is quite small. The readings will change depending on where you put the disc. I normally put it on skintones and work from there.
The slider allows you to adjust for different paper speeds. You'll have to do a test print with a piece of paper usig different slider settings for a given exposure seen on the disc. You then pick the best one and use that setting whenever you sue that paper.
Charlie
Old 06/25/08, 10:15 AM   #8 (permalink)
Benutzer
For best results you shouldn't use the darkroom light when metering.
My focometer clearly picks up some of the darkroom light. It causes different readings when I move and the sensor is more ore less in the shade I cause on the easel.
Cheers,
Michiel Fokkema
Old 06/26/08, 06:24 PM   #9 (permalink)
Neuer Benutzer
Hi everyone
I emailed Leica in the UK
got pretty much an immediate reply with scanned manual for focometer 2.What service.problem is mine is not a focometer 2 ,I have emailed them a photo of meter and hopefully they will email me with an other manual
will let you know
I have been metering with safe light off so maybe it is not working properly
do yours take a reading and is this displayed instantly on the LED display?mine sometimes does not.Unfortunately Leica dont repair /service them anymore
Anyone know who might have this expertise?
Perhaps an leica/leitz engineer out there somewhere?
Regards
Andrew
Old 06/27/08, 07:50 AM   #10 (permalink)
Erfahrener Benutzer
Andrew,
When my focometer broke, I took it to an old guy running an old fashioned TV.hi-fi repair shop and asked him to have a look. He took it apart and fixed a capacitor (they often blow in old electronics) and hey presto.
Charlie
Old 06/27/08, 12:51 PM   #11 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by blaz View Post
Thanks
First, you calibrated meter for paper you use, right?
You can not use enlarger meter (any meter) straight out of box, you must calibrate meter first for paper type you will use. Meters are calibrated for paper, not enlarger, that is why different meters can work with different enlargers...
I have 2 Jobo enlarger exposure meters. They work in 2 ways:
1. With diffuser in place, that is diffuser is between image and meter sensor. With difusser you must make new calibration every time you change film size, print size (enlarger head height), bulb type and/or power, everything.
2. Without diffuser, that is meters sensor is used like spot meter under image, nothing is between sensor and image. In that case, you calibrate meter only once, and if you change negative size, print size, enlarger bulb... you do not have to calibrate meter again, it is once calibrated for paper you use. Only if you change paper type, then you need to calibrate it again.
So, could it be that your different readings is because of something like that. So, maybe your meter is not broken, but because you work with diffuser, you allways get different results?
It would help when you get manual, I would wait if I was you to get manual and then to see if meter is broken or metering method you use is wrong.
Regards.
__________________
Bosnia... You don't have to be crazy to live here, but it helps...
haris is offline   Reply With Quote
Old 06/27/08, 01:36 PM   #12 (permalink)
Erfahrener Benutzer
Thanks
So, could it be that your different readin is because of somethink like that. So, maybe your meter is not broken, but because you work with diffuser, you allways get different results?
Regards.
__________________
Old 06/27/08, 04:33 PM   #13 (permalink)
Neuer Benutzer
Cheers guys
Leica are sending me a spare manual,will report back once I have this, and played around a bit more
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
