Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Film Forum
Film Forum The Film Forum is about everything regarding non-digital 35mm photography - films, dark room and slide projection
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old May 10th, 2008, 06:40 PM   #1 (permalink)
Benutzer
Default Wide angle lenses... Implications for printing?
I suppose this question is in the "dumb question" department, but I don't know how shots taken via wide angle lenses (<35mm) appear when printed...
Are there black bands above and below the print?
Is "special" printing required with "panoramic" paper required?
I don't get it... Please help.
John
Learner is offline   Reply With Quote
Old May 10th, 2008, 07:56 PM   #2 (permalink)
Benutzer
asota's Avatar
Default Re: Wide angle lenses... Implications for printing?
John
John, the only truly dumb questions are the ones that are not asked . Firstly, is your question related to film or digital photography in particular?
asota is offline   Reply With Quote
Old May 10th, 2008, 08:35 PM   #3 (permalink)
Benutzer
Thank you Asota.
In the near future, I'm thinking of hitching a Zeiss 25mm or an Elmarit 24mm to my M7.
Down the road, I may buy an M8 (M9?) and hope to use the 24mm or 25mm lens on it.
John
Old May 10th, 2008, 09:12 PM   #4 (permalink)
Benutzer
asota's Avatar
Thank you Asota.
John
John, I can only comfortably comment on film (analogue) photography.
Printing images in a wet darkroom from negatives or positives shot with <35mm wide angles is as straightforward as with any other focal length. If you want the black "panoramic" bands as part of your image, you can either use a specific mask or your enlarger's masking blades (if available) to achieve this effect at the printing stage.
I hope I am not succeeding in making this sound complicated, because it simply isn't. Contact your darkroom supplier and explain what you wish to achieve - they should be able to provide the correct mask for this purpose.
Re: digital printing, type "panoramic" into the search field of this forum. You should come up with some interesting and informative options.
Hope this helps.
Old May 10th, 2008, 09:43 PM   #5 (permalink)
Benutzer
Thank you again.
What I was getting at is how picture ratio fit onto standard size prints at the local printshhop.
I would imagine that much of a landscape (wideangle) shot would be have to cropped to fit onto a 6X4 or even 7X5 paper.
Cropping the picture negates much of the point of using a wide-angle lens, no?
John
Old May 10th, 2008, 10:50 PM   #6 (permalink)
Benutzer
asota's Avatar
Thank you again.
John
Sorry, I misunderstood the thrust of your question, John.
Wide angles lenses in 35mm film photography give you a broader view in 3:2 format which can then be printed (more or less full-frame) at your local printshop.
To get the full-frame image onto paper, the print size would have to correspond exactly with the 35mm's 3:2 aspect ratio. Yes, you are right, 7X5 prints do result in a slight degree of cropping (7.5X5 would be the ideal). 6X4 corresponds perfectly.
But then again, I doubt that any local printshops offer a true full-frame service, even with 6X4 prints that match the 35mm format. There is always some slight cropping.
Home or pro labs are a better option if you want true full-frame prints.
Old May 10th, 2008, 11:21 PM   #7 (permalink)
Erfahrener Benutzer
rob_x2004's Avatar
John are you confusing "wide angle" with "panoramic"? Whether the lens is wide angle or not, it still has the same coverage aspect ratio (governed by the film gate or the sensor dimensions) and will print the same format as any other lens on that camera.
rob_x2004 is offline   Reply With Quote
Old May 11th, 2008, 05:19 PM   #8 (permalink)
Erfahrener Benutzer
Wide lenses make a little bigger image by a few mm on the film that you can capture if home printing, not commercially.
tobey bilek is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
