| Film Forum The Film Forum is about everything regarding non-digital 35mm photography - films, dark room and slide projection |
#22 (permalink) |
Erfahrener Benutzer
On my screen the image is looks good as far as tonality and composition are concerned. Seems to be some sharpening done and that has created some slightly unnatural edges.
Any film can look great scanned as long as there is not too much contrast. Resist the urge to run for the sharpening tools as they do little to improve 90% of images. Best wishes Dan |
#23 (permalink) | |
Erfahrener Benutzer
Quote:
#24 (permalink) |
Benutzer
One of the reasons cited for TriX, HP5 etc having great latitude is that one can over expose them with less grief than modern films. Neopan 400 is the same. Overexposed Tmax and Delta is more likely to result in bullet proof highlights. The reduced EI and development used by many ensure that you have the best possible chance of a printable neg with both shadows and highlights. Higher contrast printing in the darkroom is no problem and the reduced density of highlights assists scanning.
If you are having problems with grain, consider changing developer if you like TriX otherwise. Xtol 1+1 yields appreciably finer grain than D76 and one gets a bit of a shoulder too so more controlled highlights. Images do however lose some acutance, but still remain fine to me. Xtol is also great with D400 and will also help control highlights there. Sounds like an overexpose and under decvelop routine could be ideal for you. i regularly print at G4 but never lose a neg due to excessive contrast. mind you my 10x8 colour head is super diffuse. |
#25 (permalink) |
Erfahrener Benutzer
Use stock D76 for 5 1/2 min at 68. Keep all solutions the same temp including wash. No rinse or ss between dev and fix. 68 means 68. Not 75 and reduced time
All the nasty grain will go away. Shoot at EI 200 and reduce time 20% for finer grain. The new PLus X has a similar look to Tri X 7 min @ 68 1:1 dilution The negs will print on #2 paper witha condenser Focomat IC or 2.75 on a V35. |
#26 (permalink) |
Neuer Benutzer
Presuming you scan all your negatives, Photoshop (or Gimp) then machine print, is there any advantage of using C41 B&W films over simply using color films and your favorite B&W conversion?
#27 (permalink) | |
Erfahrener Benutzer
Quote:
If you do decide to change film then the latitude is similar for most 400 rated films today, no big deal within a stop. good luck andy
__________________
http://andym.zenfolio.com/ |
#28 (permalink) | |
Erfahrener Benutzer
Quote:
#29 (permalink) |
Erfahrener Benutzer
Dan,
thanks so much for your comments... I have had a few 'heated' threads over the last year regarding B&W shot with the M8, as an example.I own an M8 but gave up on getting pleasing black and whites from it. Regardless of which PP method I chose the results were unsatisfactory to me. I went back to film and got what I think is good for me. Since moving to digital I have never shot so much film I envy those who can achieve great B&W with digital. I have seen one or two good examples on the web, but really 1 or 2 from thousands of images. Film remains for me the medium for black and white... thanks again for your feedback andy
__________________
| Thread Tools | |
| Display Modes | |
