Photographing thunderstorms and lightning
philipus
My iPhone app tells me that we might have a level 3 thunderstorm tonight in which case I might venture out to check if I am waterproof and take a few photos.
I am seeking guidance on how to photograph lightning using film. In terms of colour film my selection is limited to Velvia 100 (both F and non-F), CT Precisa 100, Kodak Gold 200, Fuji Superia 200.
In terms of Leicas, I have available an M6TTL, an M4 and a Leica II (I also have an EOS 1N). I also have a few tripods.
Any thoughts on how to meter and any other suggestions most gratefully received.
Philip
Tripod, wide angle lens, shutter on B, ISO 100 or 200, aperture perhaps between f/5.6 and f/11. It's rather random: you have to compose for the skyline and/or foreground, and hope that the bolts of lighting come in the right places while the shutter is open.
Use the DSLR for experimentation. In a way you're exposing for the skyline and foreground and letting the lightning take care of itself.
And please report back on whether the tripod makes a good lightning conductor:eek:. (Seriously, take care.)
You can use the old hat trick.
Camera mounted on tripod, frame composed, lens focused, base ISO, f/8-11, 30 sec exposure. Cover the lens with your hat, start the exposure, when lightening's about to strike, remove hat, replace hat after lightening, repeat.
And if the foreground is a cityscape?
What's the problem? Lightning always overexposes. You want the foreground diminished a bit, then underexpose. It is not rocket science. That ring on the lens is called an aperture. Look it up if you have to.
Time to heed some of your own advice.
Edited by CaptZoom
old wording too offensive
Russian Roulette rules. Watch for awhile to see if there is any sort of pattern in the frequency of the flashes. Then guess when the next flash is coming and openthe shutter and wait for the flash. It is literally 'open flash' technique. The following shot was done this way. I only waited 3 seconds to get the exposure. Aperture was f4 @ ISO 640 using 50mm Summicron. Hand held, which blurred the environs to some degree, which doesn't bother me. The flash and clouds are what I wanted.
Thanks everybody. I realise individual techniques may vary. You've given me plenty to try.
Erl, that's a cracking shot :) very nice.
The thunderstorm seems unfortunately to have been delayed but once it decides to come my way I will be ready.
Philip
Thanks Philip. Thought you might like this one as well. Same occasion.
David, that is curious, but how many pics of lightning do you really want/need?
Excite yourself. Try and guess it.
It works.
Next someone will invent the 'Smilometer'. It trips your shutter when the baby smiles!!! :eek::D
Smile mode already exists! No idea if it works.
Whenever I see lightning I haven't got my camera. I think at a distance would be best rather than directly in the middle of it. We had a huge early autumn thunderstorm this year that blew in from the south at a great rate of knots and we hurried inside before the heavens opened. Didn't want to get caught outside. Saw one over Santorini which would have been impressive but didn't think it would have been a good idea to shoot outside while holding an umbrella.
It works for the most part but its pattern recognition used a primitive formula which is totally stymied when confronted with a full frontal female nude. It recognizes 'eyes' then complains that the area below the button 'nose' is not smiling.
I see a market for a new smiley tattoo.
Edited by pico
