Leica User Forum
Go Back   Leica User Forum > International User Forum > Leica Products > Film Forum
Film Forum The Film Forum is about everything regarding non-digital 35mm photography - films, dark room and slide projection
 Leica Products
Leica M silver Leica M-E Leica M Monochrom Leica S LEICA D-LUX 6 LEICA X2
Leica M
» eBay | Adorama | B+H | Dale
Leica M-E
Leica M Monochrom
Leica S
» eBay | B+H | Dale
LEICA D-LUX 6
LEICA X2
Amazon | » eBay | Adorama | B+H | Dale
Old 14/01/13, 17:04   #1 (permalink)
Erfahrener Benutzer
Default High contrast 35mm focal length lenses
I'm new to film and I've been trying to research online which M mount or screw mount classic or modern lenses of 35mm focal length give a HIGH contrast look. I was getting confused and lazy so I wrote this thread just to see what are some favorites preferred by the esteemed forum members. Thank you!
sksaito is offline   Reply With Quote
Old 14/01/13, 20:22   #2 (permalink)
Erfahrener Benutzer
kokoshawnuff's Avatar
Default Re: High contrast 35mm focal length lenses
Modern lenses with aspheric elements will typically give the most contrast...so the Summicron 35 asph and the Summilux asph would be a place to start looking, but the Summarit 35 which isn't aspherical gives good contrast and is a lot cheaper.
But if you're shooting film, and you experiment with processing and emulsions, you can get good contrast using almost any lens
kokoshawnuff is offline   Reply With Quote
Thank You says
sksaito (15/01/13)
Old 15/01/13, 09:03   #3 (permalink)
Sponsoring Member
High contrast when referred to in lenses is a relative term because contrast is mainly determined by choice of film or during post processing, not the lens itself.
A low contrast lens can produce a high contrast print just as much as a higher contrast lens can produce a lower contrast image (although it is more difficult going in that direction). And the reference to 'higher contrast' in a lens is usually about the mid tone or micro contrast in more modern lenses with more efficient coatings and corrections, not necessarilly the overall contrast.
So rather than search for lenses to give you a 'HIGH' contrast look, instead search for film and processing options because these are the deciding factors.
Steve
__________________
"The greater the artist, the greater the doubt. Perfect confidence is given to the less talented as a consolation prize." - Robert Hughes, art critic.
http://www.flickr.com/photos/steve_barnett/
250swb is online now   Reply With Quote
Thank You say...
dave_d (16/01/13), sksaito (15/01/13)
Old 15/01/13, 10:49   #4 (permalink)
Erfahrener Benutzer
Thank you all for the education. I'm slowly using film more than digital and learning.
Old 15/01/13, 22:06   #5 (permalink)
Erfahrener Benutzer
Just to add to what's already been said, there's this adage that's been around since day one: "exposure controls density and development controls contrast."
You also should take into consideration your own workflow. If you are scanning B+W film then you will normally be better off with a lower contrast negative to start with. You can change the contrast in PS. This also gives you the advantage of having a lower contrast negative with a smoother tonal range to use. You can set your black and white points as you see fit. A high contrast negative tends to be more difficult to work with.
Even if your workflow is 100% analog, you might want to be careful of too much contrast in the negative and instead rely on using filters with multigraded papers (or select a higher contrast graded paper.)
With color film it's a bit different since C-41 and E6 processing is not the same as B+W, but you can choose to use color films that possess different contrasts (like Ektar versus Portra, or Provia versus Velvia, etc..)
CalArts 99 is offline   Reply With Quote
Thank You says
sksaito (17/01/13)
Reply
Bookmarks
Current eBay Ads
Current bid:
510 USD
(12 bids)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.6.0
