| Film Forum The Film Forum is about everything regarding non-digital 35mm photography - films, dark room and slide projection |
Leica Products
Leica M » eBay | Adorama | B+H | Dale |
Leica M-E » eBay | Adorama | B+H | Dale |
Leica M Monochrom » eBay | Adorama | B+H | Dale |
Leica S » eBay | B+H | Dale |
LEICA D-LUX 6 » eBay | Adorama | B+H | Dale |
LEICA X2 Amazon | » eBay | Adorama | B+H | Dale |
#21 (permalink) |
Moderator
Larcomb, I am writing as a (trained) engineer and a long time practicing photographer. I don't know your background or expertise in the area of 'silver in film and paper' so I must approach your claims/assertions with some scepicism, albeit also some acceptance.
In my distant past there was a sudden rise in the price of silver (maybe somewhere in the 1960's?) and there was an instant response from sensitized media manufacturers to increase the price of products and then to reduce the silver content of films and papers. Similarly, there was a parallel response from photographers bemoaning the 'ruining' of same! So where is the truth? Do you have it? Can you share it? On another path, your skepticism of the relevant advertising is sensible. Skepticism of any advertising is healthy IMO. As far as the Silvermax film is concerned, only use will render the answer, maybe. Dependent on the skills of the consumer, for a start! Personally, I will probably stick to what I know and understand in the selection of films, but am occasionally willing to be seduced by a new excitement. Often, that is all it is. ![]()
__________________
My vision is unique. My Leica makes it remarkable! Cheers, Erl Inventor of the StreetShooter for Leica M's Available at: johnamietphotographer Published Books (10) - latest book - EYE OF THE STORM |
| Thank You say... |
#25 (permalink) |
Erfahrener Benutzer
It could be UN54 from OrWo Filmotec, available in 35mm only, cinefilm, so very suitable for the claimed reverse processing and when you want a good negative from this film you have to adapt your type developer a bit. So an optimized negative developer for this film is not too bad.
Adox/Impex can spool 35mm and 120 roll film since a short time themselves so why not introducing a temporary film themselves to fill the gap of Efke 100/Adox CHS 100. Advertizing with high Silver content is rubbish and indeed the micro films like ATP1.1 and CMS 20 (all from Agfa Gevaert in Belgium) are just containing a minimum of Silver. One of the reason you can dilute your fixer for ATP 1.1 to 1+7 and your regular fixing time is about 1-2 minutes then. And of course for these micro films you need a special low contrast document developer. All made by SPUR because they have a larger experience in this field. And for sure sold under different names. But not unusual: Bergger is using OrWo Filmotec N74+ for their own brand Bergger 400+ film now, also available in 135-36 only. But of course you can order your own bulk film 400ft/122m at OrWo Filmotec and do it yourself. Alternative: Kodak Double-X, it's about the same results. And when you want to go for really cheap options: TSF (Traffic Surveillance Film) Polypan 90m for Eur. 30,- or so. Cheap crap, very thin layer, curling like hell but hé, it's cheap! If you want better and still cheaper material try the improved Fomapan films: Especially the iso 100 and 200 are very nice. Available in all formats: 35mm, 120 roll film, sheet film and their new 120 roll film layer is now on Clear Polyester layer with an improved non-curling layer and smoother backing paper. The new data sheets are available on the Foma website: FOMA BOHEMIA + sp And you can use all regular developers on it. Tip: Fomapan 100 E.I. 80 in Rodinal 1+50. Tip: Fomapan 200 E.I. 160 in Xtol/Fomadon Excel W27 1+1
__________________
"De enige beperking in je fotografie ben je zelf" http://www.FotohuisRoVo.nl http://Gallery.FotohuisRoVo.nl/ http://www.flickr.com/photos/fotohuisrovo/ |
#26 (permalink) | |
Erfahrener Benutzer
Quote:
| Thank You says | erl (15/09/12) |
#27 (permalink) |
Moderator
Thanks for your reply Larcomb. I an sure you may right about the 'health cost' but I am still not fully cognizant of the level of importance of silver in conventional films. My limited understanding is that it is vital, but as to the actual quantity and the effect of that quantity, I am unsure. (My) logic tells me that varying the quantity of silver will impact the nature of the film. The same for sensitized paper.
Again my understanding is that when papers moved largely from only fiber based to resin coated, the amount of silver also dropped. Certainly, and with no doubt whatever, the quality of paper 'richness' in tones was proven to drop. This was attributed to 'less silver'.
__________________
#28 (permalink) |
Sponsoring Member
There is a lengthy thread here about the varying content of silver in emulsions, and scientists are present in the discussion. It also leads on to a discussion about silver recovery, something labs have been doing for a long time considering there apparently isn't any silver to speak of in films
![]() Any Hard Data On Silver Quantity? Steve
__________________
"The greater the artist, the greater the doubt. Perfect confidence is given to the less talented as a consolation prize." - Robert Hughes, art critic. http://www.flickr.com/photos/steve_barnett/ |
#29 (permalink) | |
Erfahrener Benutzer
Quote:
| Thank You says | erl (18/09/12) |
#30 (permalink) |
Moderator
Picked up 10 rolls at PK for €20 including developer. Will try out as soon as I can.
__________________
Andy Any comment here is just my opinion. Yours may differ. Any comment posted in a dark red bold font is posted as a Moderator Website: 1st April 2013 Blog: "Still My Turn This Year": 30th April 2013 __________________________________________________ Leica User Forum Book 2012 for AICR Charity still available |
#31 (permalink) |
Moderator
Curious to hear of the results. Also, thanks Andy for being a 'proxy' with posting info as you moved around PK. Most of all, your Leica M comments.
Maybe my R glass will shine again, soon! ![]()
__________________
#32 (permalink) |
Moderator
No problem. I have had a great time here as my post in Customer Section stated.
Hotel Cristall is too close to a main road and the station, but I can sleep through Belgium so that's no big deal! ![]()
__________________
#33 (permalink) | |
Erfahrener Benutzer
Quote:
Regards Charles
__________________
#34 (permalink) |
Moderator
It's a small glass bottle with Adox on the label
![]() My bag is in the basement in the hotel so I will be able to tell you tomorrow.
__________________
| Thank You says | Bateleur (19/09/12) |
#35 (permalink) |
Erfahrener Benutzer
Is it this?
or this? Oh, I think it must be this stuff Silvermax Developer In the AGPhotographic ADOX section there is a warning about ADOX emulsions being easily damaged. Take care. Pete
__________________
http://www.flickr.com/photos/mrchombee67/ Last edited by Stealth3kpl; 19/09/12 at 20:07. |
#36 (permalink) |
Moderator
It is the Silvermax developer.
Film works in HC110B too. 7 minutes. I will use the special stuff first though.
__________________
#38 (permalink) |
Moderator
That's the deal I got. They won't have any left by the end of the week
__________________
#40 (permalink) | |
Moderator
Quote:
I will try to run a roll or two through the camera over there weekend.
__________________
| Thank You say... | Olimatt (21/09/12), Stealth3kpl (22/09/12) |
| Bookmarks |
| Current eBay Ads |
Current bid:
7894.3 USD (0 bids)
Current bid:
34.99 USD (0 bids)
Current bid:
281 USD (6 bids)
Current bid:
720 GBP (26 bids) |
| Thread Tools | |
| Display Modes | |
