ayewing Posted November 19, 2014 Share #1 Posted November 19, 2014 Advertisement (gone after registration) The newly released update of Lightroon v5.7 adds support for the new Digilux typ 109 camera and also now has profiles for Voigtlander M lenses. I have briefly tried it with my Voiglander 15mm and while it corrects vignetting it does not completely eliminate colour shift at the edges. My lens is an old screw mount fitted with a codable M adapter. Possibly the newer M mounted lenses might give better results. Quote Link to post Share on other sites More sharing options...
Advertisement Posted November 19, 2014 Posted November 19, 2014 Hi ayewing, Take a look here New Lightroom 5.7 supports Voigtlander M lenses. I'm sure you'll find what you were looking for!
Jim-St Posted November 20, 2014 Share #2 Posted November 20, 2014 I've just given it a spin with some old shots from my M8 and the LTM version of the CV15 - first impression was it gives a boost to corner illumination that blows out highlights quite alarmingly, but the vignetting slider in the Profile tab seems to be able to recover the highlights quite nicely. So I think this could be a bit of a breakthrough for these lenses on digital M's, albeit with a learning curve, and you maybe need to go back to orignal import file without any prior working in LR, Cornerfix or Flat Field corrections to get the best out of the new profiles Interesting comment from Head Bartender at RFF: "In my discussions with Adobe, apparently the best technique is shooting the CV lenses with no bar coding or Leica lens corrections, and then using the Adobe corrections afterward." So just maybe a better-than-average incremental upgrade to LR for M-users, all in all... Jim Quote Link to post Share on other sites More sharing options...
terrycym Posted November 20, 2014 Share #3 Posted November 20, 2014 I presume the Adobe Camera Raw 8.7 update available this week has the same Voigtlander additions? I downloaded it last night without looking forVoigtlander as I didn't know there might be there Quote Link to post Share on other sites More sharing options...
terrycym Posted November 20, 2014 Share #4 Posted November 20, 2014 I presume the Adobe Camera Raw 8.7 update available this week has the same Voigtlander additions?I downloaded it last night without looking forVoigtlander as I didn't know there might be there Just tried it in ACR/PS CC2014 on some.ME / CV 21mm F4 DNG's and it works a treat. Well done Adobe! Quote Link to post Share on other sites More sharing options...
ayewing Posted November 21, 2014 Author Share #5 Posted November 21, 2014 I've just given it a spin with some old shots from my M8 and the LTM version of the CV15 - first impression was it gives a boost to corner illumination that blows out highlights quite alarmingly, but the vignetting slider in the Profile tab seems to be able to recover the highlights quite nicely. So I think this could be a bit of a breakthrough for these lenses on digital M's, albeit with a learning curve, and you maybe need to go back to orignal import file without any prior working in LR, Cornerfix or Flat Field corrections to get the best out of the new profiles Interesting comment from Head Bartender at RFF: "In my discussions with Adobe, apparently the best technique is shooting the CV lenses with no bar coding or Leica lens corrections, and then using the Adobe corrections afterward." So just maybe a better-than-average incremental upgrade to LR for M-users, all in all... Jim Yes I noticed that the new profile gave best results when I switched off lens recognition (my Voigtlander 15mm is coded as a 21mm f3.4) otherwise vignetting is over corrected. Unfortunately the colour shift at the edges of the image is not completely eliminated when using a full frame camera, the M240 in my case. When I use the Voigt 15mm on my Ricoh GXR with M mount there are few problems due to the crop factor. Quote Link to post Share on other sites More sharing options...
