Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Digital Post Processing Forum
090909 Promo
Digital Post Processing Forum This forum is about digitally processing your Leica photos: B&W conversion, enhancing contrast, sharpening, printing, etc.
Register now
Old 17.10.2009, 06:02   #1 (permalink)
Erfahrener Benutzer
Default How to use Lightroom both on a laptop and a home desktop
I suspect many people have this same need, and I'm hoping for a good answer, but I'm not sure it's even possible.
I've got a Toshiba laptop, and I've been using it with my Nikon cameras up until recently. Seeing that my new M8.2 needed either Camera One or Lightroom, and having gotten quite lost in the former, I started out with a trial version of Lightroom. This led to going through video after video, trying to learn the functions. By now, I know how to do some things, but I have to keep looking things up to be sure. Anyway, I've successfully gathered up all the images on my laptop into a Lightroom gallery, and both the folder with images, and the gallery, get backed up to a USB hard drive.
But, here's the question. At home, I've got a PC with several USB drives, and photos and back-up photos stored all over the place. I need to get them all into one place, then work on editing and arranging them. Lightroom seems like as good an answer as anything I've yet seen.
So, for those of you who've already done it, when you get home with a few weeks (or month's) worth of photos on your laptop, all inside a catalog on the laptop, how do you integrate all this into your "home system"? Is there a way for a folder and a catalog on the large home system to "swallow up" all the new stuff you've done on the laptop?
There are still several things that Lightroom doesn't do, but overall it seems like a wonderful tool.
MikeMyers is offline   Reply With Quote
Old 17.10.2009, 08:56   #2 (permalink)
Erfahrener Benutzer
hoppyman's Avatar
Default Re: How to use Lightroom both on a laptop and a home desktop
Yes you can. Keep in mind that Lightroom uses a catalog which remembers the location of the files. It does not copy the actual files. If you have your master files in one location, for example one physical drive that is accessible from your network, then you can have a copy of the catalog on your laptop as well as your main machine. The function you want is catalog export and import. You might like to search help for the actions needed. You can also export only a subset of the catalog. Say you had a particular project you were travelling with, for example. If you are working with that copy of the catalog but have not put copies of the master files on the same machine then you can do less with them, obviously. You can edit metadata though. Whatever you changed on your laptop catalog can be re-exported to the main machine later to synchronise the info. You can make a merged catalog from different versions.
If you have not looked at it already, I highly recommend the excellent LR2 book by Martin Evening as a resource.
By the way, I think you said that you were just using a trial version of LR currently? If you acquire a full version either by purchase or along with a new Leica (!), the licence allows you to have a second copy on your laptop. The only restriction is that you can only use one of the machines at any one time in order to comply to the licence.
__________________
Geoff
Leica already has a CEO & business plan.
May we see your photographs?
http://www.pbase.com/hoppyman
hoppyman is offline   Reply With Quote
Old 17.10.2009, 14:14   #3 (permalink)
Erfahrener Benutzer
Photon42's Avatar
Mike
you might find reading this article useful: Working with Database Catalogs
Regards
Ivo
__________________
My Gallery
Photon42 is online now   Reply With Quote
Old 18.10.2009, 00:50   #4 (permalink)
Erfahrener Benutzer
The problem with LR is the catalog system. If you want to have access to all your images from either your notebook or your desktop you need to have the images in one place/hard drive and then access those images from either the NB or DT.
This sounds fine except when you are away from your central image storage place.
The best thing to do is to do all your real editing on one PC/Mac only and if you use the other, like the notebook when away from home, just have a catalog for the images you are taking at that time.
You can have a catalog to use on the notebook that points to the network drive where all your images are stored but only use that catalog when you are at home (where the main computer is) and when you are networked together. Otherwise that catalog will show all images missing.
I have given up on LR and have removed it from all but one computer, my main home workstation. I use PS CS4 with Bridge on my notebook to view and do minor editing when I'm traveling. Once I get back home I copy all the travel images over to my main workstation and then add them to the LR catalog for that year.
I still do use LR to search for a image or images so I can then find them easier in Bridge and edit them with ACR & PS.
Shootist is offline   Reply With Quote
Old 20.10.2009, 08:40   #5 (permalink)
Erfahrener Benutzer
My solution to this problem was simple, expedient but not necessarily tidy. I use an external WD 500GB portable drive with a Firewire cable (it also works with USB). It's compact, light and I just take it along with whichever computer I'm using. I use it at my dek at home (where I also back up to a Drobo disk set) and when I'm travelling I just unplug it and take it along with me. My catalogue and image files are all on this drive with only Lightroom on the computers' internal drives.
vikasmg is offline   Reply With Quote
Old 20.10.2009, 10:18   #6 (permalink)
Erfahrener Benutzer
chris_tribble's Avatar
Hi - I've been using LR since it came out, running it on a PC in our London base, a second PC in Cheshire and on a laptop for field work.
1/ there's no problem with the license - LR doesn't seem to mind the same copy being installed on 3 machines
2/ Shootist's strategy of using the laptop as a temporary repository makes sense. My approach is to have a Catalog called TEMP_RAW on my laptop. Whenever I'm doing a field shoot I transfer to this at the end of the day - remembering to keyword on each dump from the SD card so that you have maximum information available for images when you return to base. I will often do some quick edits on this systems (rating / colour code / crop). As I'm not worried about keeping a history of these edits when I'm ready to transfer to the main system I select all, hit control + S to update the metadata, and then IMPORT all the images to my main PC where I also have a TEMP_RAW folder. I simply stick to the file names generated by the camera and import to eg /2009/10-19.
3/ Once images are transferred and backed up I delete them from the laptop and from the SD cards..
4/ On my main machine I do final edits / corrections etc and generate JPEGS / web shows etc for the client.
5/ I run an automatic daily backup to a mirror drive so that all data is protected, and once I've got 100 GB or so of images on the drive I transfer the images to DVD AND to an external hard drive for archive (I've been using stacked 250 GB firewire HDs but will be upgrading to stacked 1 TB drives). I'll eventually transfer to a new write-only media when the replacement for DVD is stable.
6/ I create a NEW catalog for each Hard Drive, with all the images stored chronologically. If I now need to find a photo for the period 2007 I fire up the archive HD and open the appropriate LR catalog (hold down the ctrl key on a windows machine while starting the program). I then search on keywords / dates.
7/ I have a portable 1TB drive and on a regular basis make copies to this so that I keep a parallel archive in both homes. This is important so that I can give clients access to images where ever I'm based + it gives me belt and braces backup!
This works really well for me - and I've found LR 2.5 stable and reliable.
Hope it helps....
__________________
Chris Tribble
www.ctribble.co.uk // http://ctribble.blogspot.com/
chris_tribble is online now   Reply With Quote
Old 20.10.2009, 12:11   #7 (permalink)
Erfahrener Benutzer
Robert67's Avatar
Default AW: How to use Lightroom both on a laptop and a home desktop
Quick and dirty
Here an easy way too go.
Put your Katalog on the notebook in a shared Folder.
From desktop via Network "import from katalog" at LR
Option with data.
Thats all
Robert
sorry for my bad english
__________________
M8 immer noch Spass!!
Robert67 is offline   Reply With Quote
Old 20.10.2009, 14:46   #8 (permalink)
Erfahrener Benutzer
Default Re: AW: How to use Lightroom both on a laptop and a home desktop
Ihr Englisch ist viel besser als mein Deutsch!!
Robert - you're right about the quick and dirty... I suppose the problem many face is what to do about long term archiving - and accessing/searching these archives.
__________________
Chris Tribble
Old 20.10.2009, 17:22   #9 (permalink)
Erfahrener Benutzer
Robert67's Avatar
Default AW: Re: AW: How to use Lightroom both on a laptop and a home desktop
Quote:
This is my way.
Always import pics from my camera to the notebook.
At home then sync with the PC
Extra partition only for LR index and pics
Monthly full backup on external drive
Robert
__________________
Old 27.10.2009, 12:46   #10 (permalink)
Erfahrener Benutzer
When putting the photos into the notebook, place them in folders titled according to date of capture and short description.
2009 09 06 London
indent original raw
indent photoshop
indent finished JPEG
2009 09 12 Paris
2009 09 20 Madrid
Keeep the exact same format and the folders will always stay in dare order.
Use a sub folder system of originals, photoshop, and final JPEGS. Set it one time and duplicate the main folder Then move the copy to the photofolder and make a new copy. of course you can always make them up by hand each time a drive yourself crazy.
Final JPEGS have size and resolution as part of the file name, img xyz 300 8x10.JPEG
I know it is 300 ppi and 8x10 inches without opening it.
I worked this out around a year into digital and it has worked for me.
I would not do any serious editing on a trip with a laptop. Make two back up CD before erasing the card. I don`t reformat a card until I get home and all backups are made.
I never erase an image. Reformat the card.
Program will not leave spaces. I had to put indents in as place holders.
tobey bilek is offline   Reply With Quote
Old 28.10.2009, 03:55   #11 (permalink)
Erfahrener Benutzer
Tobey--
By "indent" do you mean what I would call "tab" (key just above the "caps lock" key on US keyboards)?
Thanks!
__________________
Best,
Howard Cornelsen
ho_co is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
