Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum
Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras.
Register now
Tags: ,
Old 11/15/06, 08:04 PM   #1 (permalink)
Neuer Benutzer
Default Camera gamuts and the M8
I have been reading through the technical information at International Color Consortium (the home page of the International Color Consorium, which sets the standards for profiles used in color management), describing the contents of camera profiles, and I have been inspecting some camera profiles with the ICC Profile Inspector available at Profile viewing and testing resources.
My conclusion is that you cannot tell anything about how a camera responds to the spectrum of light from looking at a "camera gamut" which is derived from a camera profile. For a graphical example of such a "camera gamut" look at:
Leica M8 Review
(See Figure 1 on that page.) This diagram shows a "camera gamut" for the Leica M8 which extends outside of the gamut of CIE LAB space.
Here's the problem with camera gamuts. A profile for the camera describes a function which maps camera device R,G, B values (the ones you would encounter in a linear RAW file) to CIE Lab values. The profile can define this mapping in (roughly) two ways. The first way is by giving the entries of a 3 x 3 matrix which you would multiply times the column vector of (R, G, B) values to get CIE X, Y, Z values, (which then can easily converted to CIE Lab). The second method is by giving a color lookup table where you can simply take a device R, G, B triple and look up the closest L, a, b output.
(This is a slight oversimplification: the standard allows the profile to specify separate non-linear functions to be applied before and after the matrix transform or the color look up table transform.)
Now here is the conceptual difficulty: it is straightforward to write a piece of software which examines a profile and determines the range of output values in CIE Lab space which will be attained as the input varies over all possible combinations of device R, G and B. But the problem is that not all combinations of R, G and B will ever come out of the camera. The camera does have a perfectly well defined device gamut which is a subset of R, G, B space. (The intuitive reason for this is that the camera response is limited by its responses to monochromatic light--you can't get more saturated than monochromatic. You could determine the camera gamut via the following experiment: take a tunable source of monochromatic light. For a set of evenly spaced frequencies over a range which includes the visible spectrum but extends into UV and IR, take a monochromatic beam and shine it into the camera. Record the R, G, B values attained at that frequency. Plot the percentage of R and the percentage of G relative to the total. If you look at the resulting plot you will see a curve in a two dimensional space--the spectrum locus. The camera device gamut is the set of all points in the convex set bounded by this curve. Alternatively if you have the camera spectral sensitivity curves for the three channels you can calculate the spectrum curve mathematically.)
What we want to know is the image of the device gamut under the transformation defined by the profile, not the image of all of R, G, B space. Unfortunately the camera profile does not contain any information about the device gamut, so instead we show the range of all of R, G, B space. Not surpisingly this larger range often includes points outside the CIE Lab gamut. Unfortunately this is a purely mathematical artifact and tells us nothing at all about the camera or its spectral sensitivity curves.
An example will make this clear. Suppose some clever camera company was able to construct a camera whose spectral sensitivity functions exactly matched the color matching functions specified by CIE. (This camera would be able to exactly predict the colors seen by human observers with ordinary color vision. Note that the camera would have no sensitivity outside of the visible range of wavelengths.) For this camera the R, G, B responses to the spectrum of light coming from an object would exactly match the CIE X, Y, Z values. The mappings recorded in the profile would be a 3 x 3 identity matrix (1's down the diagonal and 0's otherwise), and a color look up table approximation to the standard mapping from X, Y, Z to L, a b. If we ran gamut display software on the resulting profile, it would show that the camera gamut occupied all of CIE X, Y, Z space, spilling out well beyond the CIE gamut limits. Would we then conclude that our ideal camera has extended IR response? That it can see unreal colors?
There is a further complication: the mappings defined by camera profiles do not have to represent the result of physical profiling of the camera. They can be "renderings", i.e. mappings chosen to create a pleasant appearance in the resulting image. Thus the profile can be a matter of taste rather than scientific calibration.
A sidebar for those unfamiliar with CIE X, Y, Z coordinates. One way to think of these coordinates is that they are the raw device coordinates of an abstract camera whose spectral sensitivites have been chosen so that if two input spectra yield the same X, Y, Z coordinates, then human observers with normal color vision will identify the two spectra as having the same color. Think of it as a color camera that can always identify matching colors. (My wife wishes I had one when I pick socks.)
The whole point of color management (roughly) is to define every device you use in terms of these
CIE X, Y, Z coordinates. (I say roughly because there are further complications to account for the human ability to perceive neutral gray as a constant color under different illumination, even though the X, Y, Z coordinates of a totally gray object will slide around in X, Y, Z space as the illumination changes. This is the dread white balance phenomenon.)
For an output device like a printer the characterization problem is easy: you run through all possible input values (R, G, B triples for typical home inkjet printers), print a little patch for each triple, and then use a colorimeter to measure the CIE X, Y, Z values (under a specified illumination.) The range of all possible X, Y, Z values that you can obtain is literally the gamut of colors that the printer can achieve. The printer gamut will always lie inside the CIE X, Y, Z gamut, because these gamut values are the result of direct physical measurement. A printer can never create a color you can't see.
For a camera the problem is harder. The mapping from raw camera R, G, B values to X, Y, Z values has to be chosen by a human for a particular purpose. Do you want the mapping to produce pleasing images for an unrestricted set of photographic situtations? Do you want the mapping to produce the most accurate possible X, Y, Z values for a limited range of input spectra under a fixed lighting type? Even an accurate camera profile gamut (where you only look at the range of X, Y, Z values when the input R, G, B values are restricted to the camera's device gamut) may tell you more about the profile maker than the camera.
Cameras don't create colors. Human profile makers create colors. There can be no camera color gamut without a profile. (Of course if you set the camera to create .jpg files, the camera dutifully creates R, G, B values in a well-defined color space which has a clearly specified way of mapping from color space R, G, B to X, Y, Z. Here the camera firmware is choosing and applying a mapping from device R, G, B to color space R, G, B. So in that sense, cameras can create colors, but it is the human camera firmware writer who is deciding on the colors.)
References:
For more than you want to know about human color vision and colorimetry see
The Science of Color, Steven K. Shevell editor, Optical Society of America
This book is unique for relating psychophysical experiments (color matching) to the anatomy of the eye. For example: did you know that there are no short wavelength cones in the very center of the retina? If you thought de-mosaicing an R, G, B image from a Bayer array is tough, wait till you see the pictures of the distribution of S, M and L cones in the human retina--it just looks like random sprinkles. The book also defines CIE X,Y, Z space exactly in terms of physical measurements. The introductory chapter on the history of color science is also extremely illuminating. It took a long time for scientists to realize that the color of an object is not an independent attribute of that object, but rather a human sensation derived from light being reflected from or emitted from the object.
For an introduction to color management and profiles see:
Proviso: I am not a color-scientist myself, but I have a Ph.D. in Mathematics and have worked as a software engineer for many years, so I can read and understand the technical descriptions of color science.
Mark Davison
markedavison is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Official Leica Statements sean_reid Digital Forum 359 03/05/07 12:12 PM
M8 Impressions carstenw Digital Forum 30 01/24/07 10:55 PM
Speculating on why profiling works: impossible colors? blakley Digital Forum 25 11/14/06 10:29 AM
Is anyone cancelling their M8 because of issues? John Maio Digital Forum 66 11/07/06 11:47 PM
