Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum
Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras.
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old 11/14/06, 05:54 PM   #1 (permalink)
Benutzer
Default Magenta Cast workaround using C1 LE
I received my chrome M8 yesterday. Did the usual testing on many household objects and also went down the street at around 11pm with the Noctilux. As expected everything has the infamous cast in some fashion or an other.
I only had C1 LE that came with the camera, and like many pointed out it doesn't come bundled with profiles.
Keep in mind I did this on a Mac-Intel, but I would assume it should work with Windows too (maybe).
All you need to do is download the trial version of C1 Pro and install it. Doing that will place all the profiles contained in C1 Pro into the Library->ColorSync folder. That's it.
You can then delete C1 Pro and you'll have LE see and use all the profiles you may want to play with. As many already pointed out the Phase One P30 profile does the trick.
Hope this helps.
Alessandro
http://www.directlight.com
twistedpixel is offline   Reply With Quote
Old 11/14/06, 06:05 PM   #2 (permalink)
Benutzer
Default Re: Magenta Cast workaround using C1 LE
That's sneaky! I like that!!
Ed
edlbell is offline   Reply With Quote
Old 11/14/06, 06:14 PM   #3 (permalink)
Benutzer
Quote:
Ed
I hope Phase One won't come after me, after all we're still using one of their products
Alessandro
Direct Light :: Alessandro Tento :: Home
Old 11/14/06, 06:35 PM   #4 (permalink)
Benutzer
Alessandro, it takes an italian!!!
fatta la legge, trovato l'inganno...
WELL DONE
alexr is offline   Reply With Quote
Old 11/14/06, 08:04 PM   #5 (permalink)
Benutzer
Did the same test on a windows machine. Works fine. All the profiles installed by C1 Pro Trial will end up in C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\COLOR.
C1 LE will see them no problem. Although, if you Uninstall C1 Pro, it will remove also the profiles, something that does not occur in OS X.
Just keep the C1 Pro Trial and use the LE bundle
Alessandro
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
M8 Owners: M8 Enclosed C1 LE software license MP3 Leica M8 Forum 30 06/26/07 03:54 PM
Magenta Work-around for Capture One workflow Jamie Roberts Digital Forum 81 11/26/06 06:37 AM
Perhaps another workaround for magenta Jamie Roberts Digital Forum 13 11/11/06 04:21 PM
Free C1 LE copy mhoutman Digital Forum 2 09/22/06 04:18 PM
