| Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras. |
#1 (permalink) |
Neuer Benutzer
My camera writes 8 bit files. My Noise Software offers the option of writing an 8 or 16 bit file. Is there any advantage to writing a 16 bit file from an 8 bit file?
Thanks, Jim |
#4 (permalink) |
Erfahrener Benutzer
In PhotoShop it is sometimes worth converting an 8 bit file to 16 bit to perform adjustments and then converting it back to 8 bit.
__________________
www.dunni.co.uk |
#5 (permalink) |
Erfahrener Benutzer
As noted above, using 16-bit files gives more range for making global corrections, but has the disadvantage of taking up much more space.
I know some heavy-duty Photoshop users who use 16-bit files for all initial global adjustments, then save as 8-bit when getting closer to finished. I've also attended Photoshop seminars where we were told 'just convert to 8-bit and don't worry about it.' But David is right. Working in 16-bit is demonstrably better, though perhaps not enough so to be worth the disk space needed to store the files in that mode. --HC |
#7 (permalink) | |
Erfahrener Benutzer
Quote:
Basically, 8-bit is fine. For highest quality, stay in 16-bit as long as possible. But since the question is whether to save to 16 bit from a noise reduction program, don't bother. Just go to 8-bit. Theoretically, if working from RAW, you'd stay in 16-bit till all global adjustments were made, then move to 8-bit. --HC |
#9 (permalink) | |
Erfahrener Benutzer
Quote:
No, I don't think so. I believe most monitors and printers are fed 8-bit data anyway, or am I wrong? But I've seen it demonstrated in Photoshop that making a given change--Curves, say--will cause greater data gaps in the histogram when beginning with an 8-bit original than when beginning with a 16-bit original. In other words, if you've got more buckets to start with, you've got more room to spread the data. I've seen it demo'ed, but I've basically dropped 16-bit practice from my workflow due to file size constraints. --HC |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| M8-Test bei "luminous landscape" | Arias | Digitalforum | 25 | 11/04/06 09:28 PM |
