Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum
090909 Promo
Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras.
Register now
LinkBack (4) Thread Tools Display Modes
Old 13.02.2009, 22:41   #41 (permalink)
SJP
Erfahrener Benutzer
SJP's Avatar
Default Re: Reidreviews.com on G1
Quote:
Originally Posted by sean_reid View Post
I can't seem to quote messages after this latest forum update.
click "zitieren"
or use the [ QUOTE = test1; postnumber ]test2[ QUOTE ] and remove the spaces
Quote:
Originally Posted by test1; postnumber
test2
__________________
Stephen
________________________________________________
my flickr site
SJP is offline   Reply With Quote
Old 13.02.2009, 23:19   #42 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by SJP View Post
click "zitieren"
Thanks. I did end up figuring it out after that post. Buttons in English (for this version of the forum) would be nice.
Cheers,
Sean
__________________
Sean Reid
http://www.reidreviews.com
sean_reid is offline   Reply With Quote
Old 13.02.2009, 23:28   #43 (permalink)
Erfahrener Benutzer
ljclark's Avatar
Quote:
Originally Posted by tom0511 View Post
maybe Panasonic included a software corner softener for third party lenses to make people buy original lenses
That is just SO evil! I love it!!
ljclark is offline   Reply With Quote
Old 13.02.2009, 23:39   #44 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by barjohn View Post
Sean,
The images that appear to be reversed are the pair right after the ISO heading, B&W G1 on left and M8 on right but image on right is far more magnified than one on left.
Hi John,
Thanks. I had checked all the pics in the ISO noise section and hadn't seen the error in the ISO accuracy section. I just made a new and table and appreciate your "heads up".
The core idea, however, is this: Both of those exposures were made at F/8 at 1/4 second at a nominal ISO 160. The lighting and subject remains fixed of course. Looking at the grey on the WhiBal card, there's about a ten point spread between the RGB numbers for the G1 and the M8 (as I said in the review). That's a small difference but not a major one and certainly not as pronounced as you were suggesting with the DXO numbers.
Moreover...one could argue that the slightly brighter tones (on center at least because there's also a bit of light fall-off in the G1 samples) work the camera's advantage in the ISO tables *because* each tone is coming in at a higher S/N ratio than it would have had the file been darker.
In other words, I feel the results paint quite an accurate picture of the sensitivity of those two cameras under the test lighting.
Cheers,
Sean
__________________
Sean Reid
Old 14.02.2009, 04:21   #45 (permalink)
Erfahrener Benutzer
peterb's Avatar
Just finished reading Sean R's (typically) most enlightening review.
Edge anomalies aside (for lenses the G1 was clearly never designed and as Sean has suggested this needs to be fleshed out with other lenses and other focal lengths) the bottom line is that the it appears that at $700 (with a rather nice albeit slow lens, no less) and shooting at ISO's from 100 - 800 (and possibly up as high as 1600 particularly in BW) the G1 is one helluva camera.
Peter
__________________
Life is thinking up stuff to do between meals.
www.pdbregman.com/photographer.htm)
peterb is offline   Reply With Quote
Old 14.02.2009, 11:52   #46 (permalink)
Benutzer
Leica had said that there would be no digital M since M lenses were not suited to digital sensors, and it took the Epson RD1 to force them, thankfully, to bring out the M8. All of the M8 "problems" stem fron the unsuitability of the M lenses for a current technology digital sensor, so despite the clever mods to the micro lens pitch and restriction to a 1:1.33 sensor there are the well known issues. It should come as no surprise to those who have followed this discussion for the past 8 years or so that Leica rangefinder lenses are not suitable for (unmodified current technology) digital sensors!
Having said that, hopefully the longer the lens gets the less this unsuitability impacts, so a 50 f1 may work well. I just bought a G1. When I can get an adapter I will try it with a few M lenses long and short. I am unlikely to do this in a rigorous enough way to satisfy the more pedantic on the list, so don't expect a review :-)
I am looking forward to actually viewing through the Noctilux albeit via an electronic finder.
Frank
frank_dernie is offline   Reply With Quote
Old 14.02.2009, 13:38   #47 (permalink)
Erfahrener Benutzer
I haven't seen Sean's results but I don't doubt they are valid. My own results, though by no means as rigorous, show the edge performance is not great, I'm hoping for better things with newer wide-angles which may have been designed to make life easier for the sensor.
We maybe shouldn't be surprised. When the IR problem surfaced, Leica were at pains to point out that extra layers between the lens and sensor impact the IQ so the combination of thin cover glass, no IR or LP filter and a customised microlens array were all required to knock the basic Kodak sensor into shape. The Panasonic sensor was not designed for M lenses so perhaps we are seeing (any firmware issues aside) what Leica was talking about.
Things get distinctly better with longer lenses and the interest in the G1 for me is the through the lens focussing, as well as macro. Type putting a Leica OUFRO between lens and adapter to see what I mean. It's about the same thickness as the macro adapater used with the 90mm Elmar.
__________________
Mark
marknorton is offline   Reply With Quote
Old 14.02.2009, 14:12   #48 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by audidudi View Post
I'm in the possibly unique position of being able to test a "rangefinder" design lens on a 4:3 camera other than the G1. As some here know, I have been using the (now NLA) Nikon F-mount versions of the CV 12mm and 15mm lenses on my DMC-L1 for nearly two years now and I have not noticed any of the problems Sean observed in his G1 review with either of them (provided they're stopped down to F8, that is, as there is a bit of softness in the corners when they're used wide-open). As I understand it, the optical elements of these F-mount CV lenses are identical to the LTM versions, the only difference being that they're recessed into the mount in order to position them at the proper flange-to-sensor distance when mounted on a Nikon F body.
Since the L1 doesn't (to my knowledge) rely upon RAW processing software to correct lens distortions and uses a similar sensor design as the G1, perhaps it would be possible to isolate the effects of the software by comparing RAW images shot with the same lenses on both the L1 and G1?
I would volunteer to do this myself, but I've let Mike Johnston at TOP borrow my G1, so it's out of my hands at the moment, but I may be persuaded to make my lenses available to Sean (or someone else similarly qualified) if they wish to pursue this.
Let's talk in April. That might be interesting.
Cheers,
Sean
__________________
Sean Reid
Old 14.02.2009, 14:26   #49 (permalink)
Erfahrener Benutzer
Frank
"Pedantic" seems to be becoming one of the new Internet buzz phrases. If doing testing, research, etc. rigorously is pedantic than your list of pedants is going to be awfully long. And if you ever have a major medical operation done, I'll wager you'll be glad the research that informed the procedure was done by "pedants".
__________________
Sean Reid
Old 14.02.2009, 14:28   #50 (permalink)
Erfahrener Benutzer
That's almost exactly what my sense is too and I wrote similar comments in the review.
Cheers,
Sean
__________________
Sean Reid
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/digital-forum/77719-reidreviews-com-g1.html
Posted By For Type Date
Opinion on 4/3 Cameras with M lenses - FM Forums This thread Refback 07.05.2009 01:35
Leica Lenses with G1 [Page 2]: Panasonic Talk Forum: Digital Photography Review This thread Refback 12.04.2009 05:54
Re: Leica Lenses with G1: Panasonic Talk Forum: Digital Photography Review This thread Refback 12.04.2009 00:19
Panasonic Lumix G1 with Voightlander Heliar 15mm f/4.5 lens Leo Laksi’s Bangkok And Back This thread Pingback 02.03.2009 00:45
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
