| Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras. |
LinkBack (4) | Thread Tools | Display Modes |
#3 (permalink) |
Benutzer
why do you doubt it? is there some hardware incompatibility? if there is then these are not "sister" cameras
i have not done this on any camera - but it sure sounds like if you could find the leica software image it could be flashed onto the lx3 camera.. |
#4 (permalink) | |
Erfahrener Benutzer
Quote:
I think the same question was asked when the LX2/D-Lux 3 was released. |
#5 (permalink) |
Erfahrener Benutzer
Don't the Leica versions have different processing parameters? This is one of teh selling points for the more expensive option. If so, it would be unlikely that they would let you do the end around and upgrade the Panny version to the Leica settings.
__________________
David http://www.flickr.com/photos/digger1914/ http://www.digger1914.com/ be kind - the blog is brand new & I am just figuring it all out! |
#6 (permalink) |
Erfahrener Benutzer
I doubt it.
Someone has again said the jpg saturation contrast and noise reduction settings might be less aggressive on the Dlux, but even if it is the case there would be plenty of overlap. The light in your shooting conditions would make more difference. Ever seen someone trying to match "white" swatches? Again I would ask prove it. That is refer to a specification or a notice from the manufacturers, not some sales rep told me. |
#7 (permalink) |
Erfahrener Benutzer
FWIW, David Farkas indicates on his photokina blog that the differences between the DLux4 and the LX3 go far beyond the JPG rendering and physical design. He says the menu layout is different, and the RAW files are different. The justification offered for the latter bit is that the RAW file from the DLux4 is supported in CaptureOne v4 (which is bundled with the camera), whilst the Panasonic RAW is not. This is clearly an easy thing to verify, although it also just as clearly doesn't decisively prove that the RAW files are different (only that they contain reference to the camera model).
Jeff. |
#9 (permalink) | |
Erfahrener Benutzer
Quote:
Yea I know Lazarus. Cant see the point myself unless it is to get raw facility in C4. Also begs the question, how many people understand their camera well enough to go tooling round with the settings based on the nuances of the light they encounter. Not many I would have thought. All the "sage" advice is "I shoot raw" hoity toity. Last edited by rob_x2004; 02.10.2008 at 01:25. |
#10 (permalink) |
Erfahrener Benutzer
Rob, I was only quoting. I'm not convinced either. It might very well be the case that the RAW files are different, but C1 compatibility doesn't prove it.
Here's the link to David Farkas' blog: David Farkas Photography Blog. He discusses the D-Lux 4 towards the end of his Sept 28 post. Here's what he says: "This is a serious compact camera for photographers. The camera ships with Capture One v4 software which allows RAW file processing. Interestingly, the Panasonic LX3’s RAW files are actually different and are not supported in C1. So, the differences go beyond skin deep between these compact camera cousins. Sure, you get a longer, 2 year warranty with the D-Lux 4, nicer styling, better accessories, and a completely different menu system, but there are differences in the image processing as well, even for the RAW files. In the past, only the JPG output was different. Well, it would appear that Leica is getting more say in the design process now as this camera feels much more suited to the Leica shooter. " David's a very reputable guy, and by virtue of being a long-time Leica dealer seems to have pretty good access. I'm tempted to take him at his word. Jeff. |
#11 (permalink) | |
Erfahrener Benutzer
Quote:
It is perfectly valid to chose your model for cosmetic reasons. Add to that, if one camera makes you happier I would think you are more likely to use it, and use it more comfortably. Does anyone have any feelings on the cameras AF? I saw someone post that he reckoned the previous models AF was better than the oppositions previous AF. Last edited by rob_x2004; 02.10.2008 at 05:06. |
#13 (permalink) | |
Erfahrener Benutzer
Quote:
What would be the point of having that menu item. I've never done it but I bet if when you insert a card with a firmware on it and the camera start up and asks "Do you want to install this firmware" and if you select NO the camera would probably say to turn the camera off. The firmware update part of the camera is different then the real startup, limiting all functions on the camera so you can undate the firmware. Having a menu item would be pointless. The camera, computer with a lens attached, has already started and couldn't do a firmware update anyway. IIRC it is the same for Nikon. |
#15 (permalink) |
Erfahrener Benutzer
The D-Lux 4 does not use an entirely different menu system. It is identical to the one used on the LX3 except it has a color scheme and some slightly altered graphics that make it reminiscent of the M8 menu system. It does look nicer.
See comparison images of the menus: LX3 -vs- D-LUX 4 (you can open these in tabs in your browser and compare them side by side) Last edited by J Mitchum; 02.10.2008 at 20:15. |
#16 (permalink) |
Erfahrener Benutzer
I don't know if it can ar can't be done, but someone on the M8 list just mentioned having bricked his camera after hacking the firmware and writing some bad code, then trying to re-install it. The repair is going to be several hundred.
__________________
Brent The hardest thing is to photograph a black cat in a dark room. Especially if there is no cat. |
#17 (permalink) | |
Erfahrener Benutzer
Quote:
The M8 users was Hans, forget his user name, and although he did modify the firmware that wasn't the reason his camera got bricked. He was loading one of his modified firmware and used a bad/corrupted SD card. That was the real cause for the camera failure. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/digital-forum/65086-panasonic-lx3-dlux4-firmware.html
| Posted By | For | Type | Date | |
| Panasonic LX3 Diary Part IV - RAWsumer | This thread | Refback | 26.01.2009 07:24 | |
| Camera Hacker Leica D Lux Raw Image Needed | This thread | Refback | 21.12.2008 05:36 | |
| Panasonic LX3 Diary Part IV - RAWsumer | This thread | Refback | 10.11.2008 19:47 | |
| Panasonic LX3 Diary Part IV - RAWsumer | This thread | Refback | 02.10.2008 02:43 | |
