Leica User Forum Robert White
Go Back   Leica User Forum > International User Forum > Digital Forum
Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras.
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Tags:
Old 07/05/08, 12:55 AM   #1 (permalink)
Erfahrener Benutzer
Default Changing Master filenames in Aperture
Not sure if this is an appropriate forum in which to post this question.
I have just installed Aperture and imported SEVERAL folders and several thousand files from my drive - referencing them in their previous location (Yes it took a while!)
Some of my files have the original names assigned by my cameras (eg "L1001684.DNG" and so on). I'd like to rename these to sumething more meaningful (like "20080618 - 001 - Coconut Lagoon Resort.DNG" etc). This is a fairly straightforward procedure in Lightroom. But there does not seem to be a way to rename the original files in Aperture.
Thanks in advance for any assistance.
vikasmg is offline   Reply With Quote
Old 07/05/08, 04:46 AM   #2 (permalink)
Erfahrener Benutzer
Default Re: Changing Master filenames in Aperture
From the menu bar;
"Metadata" heading, select "Batch Change ..."
Select the Version Name Format popup for a choice of different ways of renaming.
You can always customise by selecting the edit at the bottom of the menu.
Do one project at a time. Give Aperture some time in between renaming especially if you change your mind after renaming. I ran into some problems doing changes too quickly and had to rebuild the database. But maybe it was because the folder had a lot of files.
Hope that helps.
lxlim is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
