| Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras. |
| Tags: visoflex |
#1 (permalink) |
Erfahrener Benutzer
Will it work?
The M8 is I think 0.5 mm taller than the M7. But the Visoflex III with 90 degree r/a finder leaves a small clearance between the top of the M7 and the finder. I need to measure the gap, obviously. In any case with the vertical chimney type of finder there would presumably be no problem, and even using a Visoflex II (with vertical finder) should be no problem. I think this opens exciting possibilities. Perhaps it will even revive interest in the Visoflex. |
#2 (permalink) |
Erfahrener Benutzer
I believe that it works fine. Somebody on this or another forum who has had access to the M8 (Henning Wulff?) has reported using one of the Visoflex gizmos (presumably the III version) on the M8 without any problems.
#4 (permalink) |
Erfahrener Benutzer
Thanks for all this encouraging information. Of course, I should have checked on the German forum. Interesting thread over there. The M8/Visoflex combination seems to generate much more excitement on that side.
#6 (permalink) |
Erfahrener Benutzer
Mechanically, the Viso (all three of them) should work. However no image optimazation would appear to be available. But at 65mm plus for the lenses that can be mounted, perhaps it isn't necessary.
Jerry |
#7 (permalink) | |
Erfahrener Benutzer
Quote:
Another issue is the 90 degree viewer - the one made for the Viso III will clear the taller bodies, while the older viewer for Viso II will not clear. Theoretically, one could use a Viso III finder on a Viso II body, but you'd run into the tripping arm clearance problems again. As there is no linkage between the Visoflex I and the body, there should be no problem using it with the M8, but what a pain...... You need a tripod or at least three hands to use the Viso I on any Leica....... All the best, Jan Last edited by doubice : 09/20/06 at 11:13 PM. |
#8 (permalink) |
Erfahrener Benutzer
Like Jan said....
There's a nice Viso II nearby here for $90, but its prism (with the 'step' down between the prism and eyepiece, and the round eyepiece) won't even go on an M7. And nothing I'm interested in shooting will hold still long enough for waist-level viewing. But considering a Viso III plus an old 280 costs less than a Nikon D80 body alone, I may try to track one down once I have my M8 to check its functioning for myself. |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| LEICA ANNOUNCEMENT: New Leica Products - LEICA M8 / M System | daniel | Digital Forum | 199 | 10/01/06 04:18 PM |
| m8 or technorama 612??? | vic vic | Customer Forum | 49 | 09/07/06 04:54 PM |
| L1 | rob_x2004 | Digital Forum | 21 | 08/27/06 05:12 AM |
| Polarizer and D2 - again, but with a slant... | rob_rob | Digital Forum | 19 | 08/03/06 08:13 PM |
| Want to know your workflow with film! | martinb | Customer Forum | 15 | 07/31/06 01:10 PM |
