Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum
Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras.
Register now
Tags: ,
Old 05/13/08, 09:45 PM   #1 (permalink)
Erfahrener Benutzer
troyfreund's Avatar
Default DMR: "M" white balance with flash/strobes
Just a quick question because I'm not sure of the answer---with the DMR, can you do a pre-set WB-reading off a white-card, when working with strobes? The instruction manual states you should only use "flash" or "auto" WB when working with flash. I recently got a flexible white card and am wondering now if it will only be useful in ambient light situations.
Thank you to the brain-trust,
Troy
__________________
"Above all, life for a photographer cannot be a matter of indifference."--Robert Frank
"These are the two basic controls at the photographer's command--position and timing--all others are extensions, peripheral ones, compared to them."--David Hurn
troyfreund is offline   Reply With Quote
Old 05/14/08, 04:13 AM   #2 (permalink)
Erfahrener Benutzer
Default Re: DMR: "M" white balance with flash/strobes
Troy
Troy--yes, you should be able to create a custom white balance with flash. I've used an Expodisc with the DMR and flash.
I shoot RAW, so I can adjust WB in post, too, if I need to, but getting it right in the camera is important to me as well. I have no idea why the manual would say this, except maybe that flashes can vary a lot...
__________________
James H (Jamie) Roberts
Site: James Roberts Photography
Blog: Photography behind the scenes
Jamie Roberts is offline   Reply With Quote
Old 05/16/08, 06:50 PM   #3 (permalink)
Erfahrener Benutzer
troyfreund's Avatar
Interestingly enough, I have no problem yesterday, manually WB-ing my DMR off a grey card, but could not do it off the white card. Problem solve though--stick to the grey card.
Troy
__________________
Old 05/17/08, 10:33 PM   #4 (permalink)
Erfahrener Benutzer
robsteve's Avatar
Troy:
If you are white balancing off a white card, you need to under expose it so that it is not pure white. The DMR will give an error if the area the WB spot is on is too light.
Robert
robsteve is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
