| Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras. |
| Tags: announcement, leica, products, system |
#21 (permalink) |
Erfahrener Benutzer
but of course vignetting sometimes looks cool!
At least, the M8 looks to be the new monster around the block. Apart from the Epson RD1, it's the most unique kid around. Good job, Leica! ![]() |
#22 (permalink) |
Erfahrener Benutzer
AWESOME
Provided software Capture One LE Leica Digital Capture ( NOW THIS IS THE SOMETHING) Maybe the DMR also So looks like C1 is already compatable. Sounds like the same DNG wrapper
__________________
Guy Mancuso www.guymancusophoto.com Upcoming GetDPI.com Photographic Workshops "It's not always about what the client will accept but about what you want to deliver to your client." |
#23 (permalink) |
Erfahrener Benutzer
Might want to read these specs there is some extra stuff here that is not in the Leica specs
Price UK: £2990 (body only) Type Compact digital viewfinder system camera for professional use with Leica M lenses. Microprocessor-controlled metal blade slot shutter. Body material Enclosed all-metal body of highly stable magnesium alloy for professional use over many years. Black synthetic leather coating. Top panel and bottom cover are milled from solid brass and are silver or black chromium plated. Sensor 27 x 18 mm CCD sensor 10.3 million effective pixels RGB Color Filter Array Offset microlenses near frame corners No anti-alias filter (low pass filter) 1.33x FOV crop Image sizes 3936 x 2630 2952 x 1972 1968 x 1315 1312 x 876 File formats DNG (RAW) JPEG (Fine / Basic) DNG + JPEG Lens mount Leica M bayonet Identification of 6-bit coded lenses Lens system Current 6-bit coded Leica M lenses of 16 - 90 mm focal length All Leica M lenses of 21 - 90 mm focal lengths produced since 1954 135 mm lens can be used but precise framing will be difficult Lens coding 6-bit lens coding system (detection can be disabled) Reduction of edge shadowing Identification of lens (recorded in JPEG EXIF / DNG) Auto slow-sync function in aperture priority mode Incompatible lenses Hologon 15 mm F8 Summicron 50 mm F2 with close focusing Elmar 90 mm F4 with collapsible tube Lenses with retractable tubes can only be used with their tubes extended otherwise you risk damaging the camera Focusing Manual focus via lens ring Superimposed focusing system via viewfinder Exposure modes Heavily center-biased TTL exposure metering with preset aperture Light reflected from white strip in center of metal blade slot shutter Silicon photodiode with collection lens Range: 0 to 20 EV Metering range EV 0 to 20 (3D color matrix or center-weighted metering) EV 2 to 20 (spot metering) (ISO 100 equivalent, f/1.4 lens, 20 °C) Exposure compen. +/- 3.0 EV 1/3 EV steps Sensitivity ISO 160 ISO 320 ISO 640 ISO 1250 ISO 2500 Shutter Microprocessor-controlled metal blade slot shutter with vertical action Shutter action Shutter activation optimised for minimum noise development. Electric motor drive with friction wheel in the first speed build-up stage and a cam disc for homogeneous torque throughout the activation process. Shutter speed In aperture priority mode steplessly adjustable from 32 to 1/8000 sec Manually selectable from 4 to 1/8000 sec in 1/2 EV steps Bulb Shutter dial (for manual selection) "Wrong way" shutter dial (same as M6 TTL / M7) Auto shutter speed position Bulb position 8 - 1/8000 sec in 1/2 EV steps 1/250 sec indicated as flash sync Shutter release button Three position soft-touch button 1. Initiate metering 2. Lock metered exposure 3. Shutter release Aperture Selected on lens White balance Auto Six presets o Tungsten o Fluorescent o Daylight o Flash o Cloudy o Shadow Manual preset Kelvin color temperature (2000 - 13100 K) Preset white balance (immediate or from photo) Color space sRGB Adobe RGB ECI RGB Image parameters Sharpening (5): Off, Low, Standard, Medium High, High Saturation (6): Low, Medium Low, Standard, Medium High, High, B&W Contrast (5): Low, Medium Low, Standard, Medium High, High User profiles Three available Viewfinder type Large bright-line frame viewfinder with automatic parallax compensation Viewfinder optics with reduced sensitivity to scattered light and optimum visibility of the bright-line frame in all lighting situations Viewfinder specification Eyepiece matched to -0.5dpt, correction lenses form -3 to +3dpt available Enlargement: 0.68x for all lenses Viewfinder bright-line frames Automatically matched for the lens used o 24 and 35 mm o 28 and 90 mm o 50 and 75 mm Automatic parallax correction Size basis range finder Combination of split and superimposed image range finder shown as a bright field in the centre of the viewfinder image. Effective measurement basis 47.1 mm (mechanical measurement basis 69.25mm x viewfinder enlargement 0.68 x). Viewfinder information LED symbol for flash status Four-digit LED display with dots above and below Brightness automatically adjusted depending on ambient brightness Memory capacity warning when the SD card is full LED light balance with two triangular and one circular LED for manual exp Display of: underexposure by at least one aperture stop; underexposure by 1/2 aperture stop; correct exposure; overexposure by 1/2 aperture stop; overexposure by at least one aperture stop LCD monitor 2.5" TFT LCD 230,000 pixel TFT Flash control Leica M-TTL flash compatible Short calibration pre-flash immediately before main exposure Connection: M-TTL guide number control with pre-flash Flash sync: 1/250 sec Manual: Bulb to 1/250 sec Auto slow sync: 1/focal length in seconds (only 6-bit coded lenses) Choice of long flash sync times up to 1/8 sec for balanced flash in aperture priority mode Sync: 1st or 2nd shutter point (front / rear sync) Compensation: +/- 3.0 EV in 1/3 EV steps Shooting modes Single picture (one shutter button depression, one picture) Continuous (2 frames per second up to 10 frames) Self-timer (2 or 12 second delay) Play functions Image (simple) Image with histogram and information o Histogram: standard / RGB o Clipping indication: on / off o Exposure information o Can magnify and browse Image magnify up to 1:1 (can browse) Thumbnail (4 or 9 image index) Page by page (9 image index) Protect Delete Delete function Single image All images Protect / Unprotect function Single image All images Set quick access menu User profile ISO sensitivity Exposure compensation White Balance Image quality ('compression') Image size ('resolution') Languages English German French Spanish Italian Japanese Chinese Storage Secure Digital / Secure Digital HC FAT / FAT32 Connectivity USB 2.0 Hi-Speed (Mini-B connector) Provided software Capture One LE Leica Digital Capture Power Lithium-Ion battery pack (3.7 V, 1900 mAh) Charger included (also attaches to car socket) Dimensions 139 x 80 x 37 mm (5.5 x 3.1 x 1.5 in) Weight (no battery) 545 g (1.2 lb) Weight (inc. batt) 591 g (1.3 lb) Box contents M8 camera (10702 silver or 10701 black), anti-slip carrying strap (14 312), camera cover for M bayonet (14 195), lithium ion rechargeable battery (14 464), battery charger incl. car socket adaptor and 3 mains plug adapters (Euro, UK, USA) (14 463), USB connection cable, user manual, software DVD Capture One LE, software CD with LEICA DIGITAL CAPTURE and user manuals in all languages (PDF); printed user manual for LEICA M8; warranty card for LEICA M8
__________________
#24 (permalink) | |
Erfahrener Benutzer
Quote:
It went live earlier today. Enjoy! Cheers, Sean |
#25 (permalink) |
Erfahrener Benutzer
Sean your going to kill me . Need login stuff again. Sorry
__________________
#27 (permalink) |
Erfahrener Benutzer
dpreview.com made public their analysis of the camera.
http://www.dpreview.com/news/0609/06...8previewed.asp |
#29 (permalink) | |
Erfahrener Benutzer
Quote:
Actually, I can't keep track of all my passwords, etc. either. Cheers, Sean |
#30 (permalink) |
Erfahrener Benutzer
I don't get the depth - the dimensions in the specification have it about the same size as an M7, yet the pictures we've seen up to now have suggested a body which is rather thicker. Which is right?
__________________
Mark |
#31 (permalink) |
Erfahrener Benutzer
OK, I put my hands up, the photo's aren't fake
I still don't like that USB door though.But that's a very minor point - the camera and lenses will be brilliant. I just need to decide now if the M8 is right for me and figure out how to fund it...... Best wishes to Leica with it, this will be huge. |
#32 (permalink) |
Erfahrener Benutzer
0.68x vf mag, too wide for me i'm afraid.
How to focus 75/1.4 lenses at full aperture with such a magnification? Will be interesting to see this and a couple of other things like shutter lag when shooting raw but i'm sure the pictures will be outstanding and for now congrats and best wishes to Leica! ![]() |
#34 (permalink) |
Erfahrener Benutzer
I want you all to know that I bought a lottery ticket last night.
*When* I win, you will be in line BEHIND me. ... so don't get any frickin' "bright ideas".
__________________
http://shanefage.ca/ |
#35 (permalink) | |
Erfahrener Benutzer
Hi,
Well, nobody's perfect as they say... It's a nice camera, and like every thing, could also be probably a bit better. Quote:
What about a grip (14405) ? The right side have now the base-plate lock... ![]() Waiting to get it in the hands now to appreciate fully... |
#36 (permalink) |
Erfahrener Benutzer
Wow. Looks like a winner to me...
And it looks like (from dPreview) that they worked with C1 to profile the camera as well And I can't wait to see what it does with ISO 2500... Guy--I don't think therapy will help at this point ![]()
__________________
James H (Jamie) Roberts Site: James Roberts Photography Blog: Photography behind the scenes |
#37 (permalink) |
Neuer Benutzer
Hmm, I`m not usually the one drooling over reviews, but this one is one I`d like to read Sean, you should sell it standalone
__________________
_______________ Amund Blix Aaeng |
#38 (permalink) |
Erfahrener Benutzer
Yea I am screwed. No way out and i still did not read Sean's review . i am very afraid too. I been on the phone with a Colonel from Bagdad explaining how to use his DMR . nice guy to boot. LOL
__________________
#39 (permalink) | |
Erfahrener Benutzer
Quote:
#40 (permalink) | |
Erfahrener Benutzer
Quote:
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Leica launching new international advertising campaign | john_f | Customer Forum | 16 | 09/13/06 11:09 PM |
| What is Leica doing to attract ... | chrisweeks | Customer Forum | 73 | 09/04/06 12:28 PM |
| Why is there no auto-focus for any of Leica's cameras/lenses? | Robert44 | Customer Forum | 56 | 08/27/06 12:32 AM |
| Leica M8 - It's official! | marknorton | Digital Forum | 45 | 08/01/06 02:30 PM |
| Leica make other products too! | marknorton | Customer Forum | 16 | 07/24/06 09:19 PM |
