| Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras. |
| Tags: digilux 2 , photojournalism , viewfinder |
#1 (permalink) |
Neuer Benutzer
As the topic has changed from "Is the Digilux 3 a photojournalist's Camera?" to making the Digilux 2 workable for wide-angle black and white documentary photojournalism (see definition in previous thread), I have moved it here.....
My question was: Has anyone used an external viewfinder on their D2? The EV seems to me to have a lag in timing. And if you use an external finder, how do you deal with focusing? I emailed Stephen Gandy and he recommends the 28mm-35mm MiniFinder, as I will be using the D2 at 35mm and wider 95% of the time. I wear eyeglasses, so it would have to be a "high level" finder. Thanks for all your help and feedback. I really like the images from the D2 so far and the pop-up and tilt flash is very useful for my style of shooting. I sent for the SanDisk Extreme 2gb card and a Heliopan 69mm UV filter. |
#2 (permalink) |
Erfahrener Benutzer
I am not sure an external viewfinder is compatible with the flash - as soon as something is mounted in the hot shoe it blocks the pop-up flash. Try to get used to the EVF. Used in the manual mode with central enlargment it is quite a useful tool.
#3 (permalink) | |
Erfahrener Benutzer
Quote:
A better choice, IMO, would be the Ricoh GV-1 finder for their GR Digital camera. It was designed around the GRD's 4:3 format and has brightlines for 21 and 28mm ... a bit wider than your preference, but at least the framing will be correct. Perhaps there are other 4:3 format finders available as well? |
#4 (permalink) |
Erfahrener Benutzer
Joel, I use the Voigtlander 28mm finder, which is inexpensive and bright.
This solves the lag problem for me. If there is time to focus with the EVF, I then use the finder for composition. If the selected lens length is greater then 28, I estimate. When focusing movement, I zone focus and use a lens length wider than the desired subject area, and click away using the finder.
__________________
Bill Parsons (wparsons@gis.net), Boston |
#5 (permalink) | |
Erfahrener Benutzer
Quote:
I have a Voightlander 28/35 MiniFinder. You can see it on my avitar mounted on an M3. I'm sorry but I have to give it an F. It is very bright, clear and with a paralax line and I give an A for that. The issue it the 35mm frame. On certain angle with the light, I can't see the frame "at all". No issue with the 28mm frame. I need the 35mm frame the most so I bought a Leitz 35mm finder. I only use the 28/35 finder for my 28mm lens since the 35mm frameline is next thing to useless. Just letting you know... -Ron |
#6 (permalink) |
Neuer Benutzer
So, it seems the only option is to use the Ricoh 21mm-28mm 4:3 format finder if I want it to be a correct format. Are there any other 4:3 format finders out there (specifically 35mm equivalent)???
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Official Response from Leica on Laundry List | guy_mancuso | Leica M8 Forum | 232 | 06/02/07 03:48 PM |
| Radioaktive optische Gläser... | Olof | Leica Sammler & Historica | 24 | 03/14/07 12:19 PM |
| Official Leica Statements | sean_reid | Digital Forum | 359 | 03/05/07 11:12 AM |
| Results of M8 Lockup/Failure Survey | sean_reid | Digital Forum | 86 | 02/24/07 06:54 PM |
| By request: white balancing your M8 | Jamie Roberts | Digital Forum | 35 | 01/31/07 02:13 PM |
