Leica User Forum Classic Connection
Go Back   Leica User Forum > International User Forum > Digital Forum
Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras.
Register now
Old 04/05/07, 05:06 PM   #1 (permalink)
Benutzer
Default Replacing VC thread mount with Bayonet Mount
If I buy a Cosina Voigtlander lens with a Thread Mount and want the mount permanently replaced with an M Bayonet mount, rather than using thescrewmount to bayonet mount adapter, can I have this done? If so, who and where?
portocar is offline   Reply With Quote
Old 04/05/07, 05:30 PM   #2 (permalink)
Erfahrener Benutzer
jaapv's Avatar
Default AW: Replacing VC thread mount with Bayonet Mount
Quite an operation. Buy a mount, have a ring machined to a 0.01 mm tolerance, remove the screwmount, drill and thread screwholes and montage and check using an optical bench. I think the lens will end up costing the same as the equivalent Leica lens. And the adapter rings are so good one does not even notice the difference to a fixed mount. If you don't like the idea of a removable mount, you could use a drop of superglue.
__________________
Jaap
WWW.JAAPVPHOTOGRAPHY.EU
Skype: JAAPVPHOTOGRAPHY
jaapv is offline   Reply With Quote
Old 04/05/07, 05:57 PM   #3 (permalink)
Erfahrener Benutzer
WeinschelA's Avatar
Default Re: Replacing VC thread mount with Bayonet Mount
Quote:
I don't quite understand why you would want to go through the trouble and expense of doing his when the adapters are hardly noticeable and work just fine. You would be gaining no functional benefit at all. It would also probably cost as much as some of the VC lenses cost.
WeinschelA is offline   Reply With Quote
Old 04/05/07, 06:13 PM   #4 (permalink)
LJL
Erfahrener Benutzer
Nestor,
I am agreeing with Jaap and Alan on this. In fact, I was quite glad that I did NOT have a permanent mount on my CV 15/4.5 lens, as I was able to change the CV 28/90 mount for an older Leica 9cm LTM mount by simply unscrewing it. Now I have the option of being able to apply a coding sequence to the 9cm mount for the WATE. Had I permanently mounted a bayonet to the CV 15 from the start, I might not have been able to make this change so easily. Just worth considering. The mounts work well and are very unobtrusive.
LJ
LJL is offline   Reply With Quote
Old 04/05/07, 09:47 PM   #5 (permalink)
Erfahrener Benutzer
carstenw's Avatar
Which lens do you want? The 21/4 and one other one are coming in M-mount soon.
__________________
Carsten
Leica M8 Lens Codes
Through the Lens Darkly
carstenw is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Why I'm sticking with Aperture (rather than Lightroom) jonoslack Digital Forum 13 02/10/08 04:37 AM
Hand Coding VC21 or VC15 with Voigtlander screw mount adapter stan98103 Digital Forum 6 03/07/07 08:00 AM
Future of the R system cpclee Customer Forum 70 01/21/07 07:48 PM
Will Leica ever make R lenses with Canon or Nikon mount spersky Digital Forum 20 01/15/07 04:12 AM
Digilux 1 thomasl.se Digital Forum 32 12/04/06 05:15 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
