| Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras. |
#1 (permalink) |
Erfahrener Benutzer
The history:
--I received my M8 in mid-January. It worked for just over one day, then suffered total electronic failure. I sent it back to Solms. Leica engineers put the top plate onto a completely new camera and returned it to me. --The replacement worked for just over one week and the same thing happened. Actually, I was still able to record images, but was unable to access anything on the LCD. None of the back buttons worked. I returned it to Solms, and again the top plate was fitted to a new camera and I received it yesterday. --The second replacement worked fine for one day, but this morning has once again shut down. I am able to record images but cannot access anything on the LCD. With the previous two cameras, I did everything others recommend. I left the camera on for 24 hours, replaced the battery with a fresh one; tried different memory cards. Nothing worked. --The card I use is a San Disk Ultra II 2 GB, which is listed as compatible by Leica. --My card reader is a Promaster Universal high speed USB. --I use a PC with XP Pro OS. Does anyone have any ideas how we might go about isolating the problem? I've asked my contact person in Solms to discuss this with the engineers and let me know if they have ideas about what is going on. If it doesn't get nailed down, I'll return the camera for a refund and give up on the M8. I know there are some brilliant minds on this forum. My hope is that we can work together to solve this problem once and for all. Cheers,
__________________
Brent http://brentnicastrophotography.com/ The hardest thing is to photograph a black cat in a dark room. Especially if there is no cat. Last edited by fotografr; 15.03.2007 at 16:41. |
| Advertisement (gone after free registration) |
#2 (permalink) |
Erfahrener Benutzer
There is a suspicion floating in the air - charger?- battery? a combo of the two?? Can you charge another battery on another charger (after draining the camera) and see what happens?
#3 (permalink) |
Erfahrener Benutzer
I'm curious, Brent ... how can you confirm it's a new camera fitted underneath the same top plate? There's no way I can believe that you've got hit by three dead cameras in a row.
#4 (permalink) | |
Erfahrener Benutzer
Quote:
Did you get new charger or batteries with any of the replacements? Robert |
#5 (permalink) |
Erfahrener Benutzer
Probably not helpful, but I wonder if there's something in your set up that's causing the problem to 3 cameras.
Is your charger faulty? Is there a big static charge in your house? I almost get the impression that there are a number of users who have had problems with more than one camera. And, most, like myself, who haven't had any. A charger problem, enviromental problem, or some particular way (which should be harmless) you use the M8, are the only things I can think of, except bad luck to get three lemons. It seems like it's a mystery for Leica as well. I wish I could be more helpful. Best, Mitchell |
#6 (permalink) |
Erfahrener Benutzer
Is there any similarity in where the shutdowns occurred? Inside, outside, wherever? My one temporary shutdown happened outside in bright sunshine at 4C temperature. It got cured with camera under jacket in five minutes. And it may have been a time factor alone. I did not change the battery and it lasted for another 150+ pictures.
__________________
George |
#7 (permalink) |
Erfahrener Benutzer
Brent change the cards out and i have a extra charger if you need one brand new. 3 times in a row is just downright wrong. Change everything up . Batteries charger and cards. Until we get real answers which there working on . i would do this
__________________
Guy Mancuso www.guymancusophoto.com Upcoming GetDPI.com Photographic Workshops "It's not always about what the client will accept but about what you want to deliver to your client." |
#8 (permalink) | |
Erfahrener Benutzer
Quote:
__________________
Brent http://brentnicastrophotography.com/ The hardest thing is to photograph a black cat in a dark room. Especially if there is no cat. |
#9 (permalink) | |
Erfahrener Benutzer
Quote:
__________________
#10 (permalink) |
Erfahrener Benutzer
I had one temporary crash before the complete crash that sent my camra back to NJ, but I know one thing for sure: When I started having problems I started messing with batteries -- drained them overnight, switching back and forth, etc. (I have three of them.) I would not be surprised if battery/charger are implicated. But that's not good, because when I get my repaired camera back, what do I do? Keep using the same batteries and charger? I don't even know where I can get another charger. I would pay for another charger and batteries, if that's necessary, but without them, I might as well not have a camera.
JC |
#11 (permalink) | |
Erfahrener Benutzer
Quote:
This same problem happened with both of my 2GB cards. The other one is a Kingston and both were purchased from distributors rather than eBay. I have heard about the counterfeit problem, but I don't think that's the problem here.
__________________
#12 (permalink) | |
Erfahrener Benutzer
Quote:
__________________
#13 (permalink) | |
Erfahrener Benutzer
Quote:
__________________
#14 (permalink) | |
Erfahrener Benutzer
Quote:
My charger, I suppose, could be faulty. Each time my camera is replaced, the same charger comes back. My home doesn't have any static problem. I have humidified air throughout the heating season.
__________________
#15 (permalink) | |
Erfahrener Benutzer
Quote:
Great glad that can happen for you there. If anyone wants to buy a extra don't go to the store go to Guy's bargain basement discount house instead. ROTFLMAO If i can find it than I can sell it. I got everything. LOL
__________________
#16 (permalink) | |
Erfahrener Benutzer
Quote:
__________________
#17 (permalink) |
Erfahrener Benutzer
Brent do that and DON"T put a card in. Let's see what happens without it. Try the old process of elmination
__________________
#18 (permalink) |
Erfahrener Benutzer
The following is not meant to be a facetious post. Back in the early 70's I part owned a consultancy, which specialized in quality and reliability for the UK motor industry (we failed). During that period, I went to a seminar on quality control in Zurich. One of the speakers was from Breitling, the Swiss watch manufacturer. He said that it was well known that there were certain people on whom watches simply would not function properly and they had no real idea why but that it might be something to do with personal static electrical fields.
In that this forum has its suspicions as to the M8's vulnerability to static electricity, I just wonder if this might explain why certain members are suffering multiple camera failures and some none. Not very helpful I know but if perhaps you put a small piece of aluminium foil where the bottom plate goes over the locating tag, that might improve electrical bonding and forestall the next failure. Wilson |
#19 (permalink) |
Gast
Posts: n/a
If Leica isn't checking the chargers as step one of their root cause analysis, that would be very strange and disheartening. As much as I wish the charger were the problem, I doubt that it could be possible that such an obvious thing would be missed.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| M and R lens Character | guy_mancuso | Digital Forum | 57 | 12.01.2007 18:28 |
| How is the M8 measuring up to your Criteria? | fotografz | Digital Forum | 59 | 06.01.2007 20:14 |
| D-Lux 3 –– sharing familiarisation experiences – Macro and overall musings | macgarvin | Digital Forum | 8 | 02.01.2007 10:47 |
| Camera gamuts and the M8 | markedavison | Digital Forum | 0 | 15.11.2006 20:04 |
| Will I need my D2 Lens hood in Paris in December 2006 ? | dugby | Digital Forum | 27 | 27.07.2006 02:16 |
