| Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras. |
#1 (permalink) |
Erfahrener Benutzer
I remember a forum member have shown the spatial frequency response curve of M8's Kodak CCD sensor, leading to a interpretation that,
If the Kodak sensor really performs up to its specification, it shall be effective enough to block the majority IR and we will not have our current IR issue. ????? 1) So is Leica just received and employing a dump sensor which does not work up to the standard (a manufacturing negligence)? Or is it by design to compromise between various image quality factors (as Leica claims)? Really interested in the truth... 2) How thick is the cover glass in front of the CCD sensor? Best Matthew |
| Advertisement (gone after free registration) |
#2 (permalink) |
Erfahrener Benutzer
isnt IR a natural part of the spectrum
the coverglass is 0.5mm thick
__________________
Riley Id give my right arm to be ambidextrous |
#3 (permalink) | |
Erfahrener Benutzer
Quote:
The performance results and 'issues' of the M8 are perfectly consistant with commonly known constraints of digital sensors and lens to sensor distances. Leica did not have to deal with the digital unfriendly M mount when producing the DMR so the DMR had none of the IR sensitivity issues exhibited by the M. This has already been re-hashed adnauseum online. Of course there are plenty of internet armchair engineers who think that it should be a piece of cake to stuff the electronics from a full frame DSLR into the M. Unfortunately Leica's engineers have to produce real products in the real world constrained by the laws of physics and currently available technology within a limited budget and at a price the market will bear. |
#5 (permalink) |
Erfahrener Benutzer
The cover glass serves another purpose, that of microlenses, without it the whole thing simply wont work
The problem is that the lenses are quite wide in aspect to the register so light becomes more divergent, less telecentric. Digital film doesn't handle divergent light anything like 35mm film does. This will cause a vignetting (dark corners) or fall off. To increase the sensibility (speed) of the sensor, the pixels have to have microlenses to collect more light. Again, if the light rays will fall on the film in a non-rectangular way, less or no light will fall on the pixels at the corners of the image. Microlenses over each photosite to compensate for the fact that all image producing rays do not come in parallel to each other, but there are angular limits on this form of compensation. Another feature of the short register is that reflections off the surface of the sensor are more prominent. So light may well travel through the IRcut filter bounce off the sensor and reflect back off the IRcut coated surface. This creates considerable shifts in edge contrast of an image, greatly affecting sharpness. This it seems is also true to the AA filter. The filter combination will also break entry light rays up like a prismatic effect which also disipates sharpness. This limitation meant the coverglass could not be thicker than 0.5mm, which isnt enough to hold off IR effects. Hence an IRcut is carried externally in front of the lens. The AA filter to my knowledge is simply not included.
__________________
#6 (permalink) | |
Erfahrener Benutzer
Quote:
#8 (permalink) |
Erfahrener Benutzer
By way of some numbers, the angle from the center of the lens exit to the corner for a few camera formats is:
Nikon full frame: 24.96 degrees Nikon DX: 16.98 degrees Canon full frame: 26.19 degrees Canon APS-C: 17.05 degrees Leica M full frame exit pupil at the lens flange: 37.76 degrees Leica M8 exit pupil at the lens flange: 30.09 degrees Leica M full frame exit pupil 1cm in: 50.33 degrees Leica M8 exit pupil 1cm in: 42.06 degrees The limit for a conventional CCD with AA filter, IR filter and conventional microlenses is considered to be about 18 to 20 degrees, which is why the Nikon's, Canons's etc went to smaller CCDs. With offset microlenses and AA/IR filter probably somewhere in the low 30s, which is how Canon build their FF's. But some M lenses protrude backwards into the camera body, so Leica had to deal with the 42 degree angle, so no AA filter, minimal IR filter, offset microlenses, and software correction for remaining vignetting.... Actually, given the restrictions, the M8 is an optical marvel. Certainly not, in my view, below standard Sandy |
#9 (permalink) | |
Erfahrener Benutzer
Quote:
#10 (permalink) | |
Erfahrener Benutzer
Quote:
thats how i see it too, no-one else could have made this camera but Leica given the technical difficulties and the image quality at hand its a beautiful thing
__________________
#12 (permalink) |
Erfahrener Benutzer
When they moved from the DMR's Kodak sensor to the M8's Kodak sensor, Leica made a judgement call in reducing the IR filtration. Both systems leave out the AA filter. The specs for both are on Kodak's website, and the IR vulnerability is small but enough to be worrisome on specifications alone. Leica stumbled in thinking that it wouldn't matter. Had they paid more attention to the early experience of Kodak and Nikon DSLR's with weak IR filtration, they would have known what they were getting into.
This wasn't "internet engineers" making up instant analysis, this was the experience of photographers who had struggled with those DSLR's and real engineers who had designed technical cameras (including the people who build Leica's S-1). Leica didn't take advantage of that knowledge until too late. Then they responded quite quickly -- the marketeers with new marketspeak (e.g. the hardware "upgrade"), but the engineers with a reasonable set of workarounds. scott |
#13 (permalink) | |||
Erfahrener Benutzer
Quote:
Quote:
Quote:
#14 (permalink) |
Erfahrener Benutzer
I am sad to say that this whole thread smacks of the iconoclastic bias a few Leica users seem to have. "Kodak" appears to be almost a dirty word for some, right up there with "Microsoft" and any American car line I could think up. But Kodak appears fully competitive techonlogically with any other sensor manufacturer.
Leica's decision to use the Kodak sensor leads me to believe, not that Leica wanted a "dump sensor" to doom its flag-ship digital camera, but that Kodak was able to develop the sensor best-suited to the application at hand. |
#15 (permalink) | |
Erfahrener Benutzer
Quote:
#16 (permalink) | |
Erfahrener Benutzer
Quote:
#17 (permalink) |
Benutzer
IR is not light. Light is electromagnetic radiation which stimulates the human retina. Oddly, a science based on perception. IR is part of the EM spectrum (like microwaves and X-rays) but is outside the area we see. Sometimes I see the term "visible light" which I think is redundant - visible radiation we can see?
It may be that the magenta blacks the M8 sensor "sees" are actually "real" but our eye can't see them that way since we can't see IR. The "fault" is that the sensor sees too well. We had this problem in film photography (remember film?) using studio flash with excessive UV output - many synthetic fabrics photographed oddly since they reflected (and in some cases fluoresced) UV light we also couldn't see but which was recorded by colour films. I'm surprised this hasn't been mentioned before. (Maybe I missed it.) The solution was filters. In the case of existing flash units, we used 2B UV filters over the lights (and often over the lens as well) to kill the excessive UV. Newer flash units had UV filtering built in, so the problem went away. Also, synthetic fabric manufacturers tuned their production so that when people bought a blue shirt out of the catalogue, they weren't surprised with a purple one when they opened the package. The spectral response of CCDs is not flat by any means (nor is the human eye) and matching these are always compromises. I expect what we really need is a better IR filter glass since we know that physically there is only room for a 0.5mm glass and that this is not working. So the challenge seems to be the development of a satisfactory IR blocking glass that is 0.5mm thick or less. I suspect dichroics would not work due to the reflections. |
#18 (permalink) |
Erfahrener Benutzer
when we go through this again next week, well...
sdrawkcab etirw dluohs uoy gnileef eht teg uoy semitemos
__________________
#19 (permalink) | |||||
Erfahrener Benutzer
Quote:
There are people who can "see" outside the "visible" spectrum (Google). Quote:
Quote:
Quote:
Quote:
#20 (permalink) | |
Erfahrener Benutzer
Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Kodak sensor | bsmith | Digital Forum | 22 | 11.11.2006 17:10 |
| Sensor upgrade DMR with M8's and vise-versa | manolo | Digital Forum | 18 | 13.10.2006 13:32 |
| M8 Uses Kodak Image Sensor | Kirk | Digital Forum | 0 | 16.09.2006 17:47 |
| Sony eliminates sensor noise | like_no_other | Digitalforum | 10 | 27.08.2006 12:21 |
| The M8 sensor; a quantum leap? | Goldie | Digital Forum | 5 | 11.08.2006 23:50 |
