| Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras. |
#1 (permalink) |
Erfahrener Benutzer
A quick check for your M8 battery.
You need a voltmeter (get one from Radio Shack, Home Depot, B&Q etc) and some kitchen foil. Put the battery on it's back with the contact slots facing you and pointing down. There are six slots, counting from the right, slots 1, 3, 5, 6 are "populated" with a contact. Make two small "blades" out of the kitchen foil and slide into slots 1 and 5, again, counting from the right. Do NOT short the foils together, there's probably an internal fuse in there. Measure the voltage between the two, negative to slot 1. On my 4 batteries, which are known to be good, the voltage varies from 4.14 to 4.21v.
__________________
Mark |
| Advertisement (gone after free registration) |
#2 (permalink) |
Erfahrener Benutzer
My one battery is charging right now, but I'll check. How do you get 4.1-4.2 volts out of a 3.7 volt Li-Ion battery system? What do the other two contacts do and how do they do it? Usually there are only three contacts on a smart battery, and even then I have never figured out what they do. Does anyone know a website that shows how a smart battery is wired up?
The reason is that from time to time I have looked at the details of power management on interesting electronic devices (such as my E-1 DSLR http://www.cs.huji.ac.il/~kirk/Estim...onsumption.ppt ). There are some interesting lessons to be learned, that suggest best operating modes. But it gets much harder when there is no external DC power input which will allow you to operate under measured power without the battery. In my Ricoh GR-D the external power source (which I don't own) actually replaces the battery. In the M8 you would have to pretend to be the battery (and find a way to get the power cord through the base plate) to run on external power. scott |
#3 (permalink) | |
Neuer Benutzer
Quote:
Please see for example http://xtronics.com/reference/batterap.htm for nominal vs. charge voltage. Best regards, Michael |
#4 (permalink) |
Erfahrener Benutzer
The third contact is usually a monitoring point so the internal circuitry of the Li-on batteries can report back to the charger if there is a charging issue.
![]() How to rebuild a Li-Ion battery pack _mike Last edited by mike prevette : 01/21/07 at 11:44 AM. |
#5 (permalink) | |
Erfahrener Benutzer
Quote:
scott |
#6 (permalink) | |
Erfahrener Benutzer
Quote:
Most other battery systems give nearly constant output voltage under load until just before they run out, but since Li-Ion offers 3X the energy/Kg and 4X the energy/liter of the older technologies, we should be prepared to deal with a little complexity. scott |
#7 (permalink) |
Erfahrener Benutzer
The 4.1 - 4.2 was for batteries straight out of the charger. I've just measured the battery down to one bar on the display after yesterday's shooting and it's 3.77 volts but that is open circuit, would presumably fall under load.
If you measure the resistance between slots 1 and 6, it's about 11k ohms which might well be a thermistor.
__________________
Mark Last edited by marknorton : 01/21/07 at 12:44 PM. |
#8 (permalink) | |
Erfahrener Benutzer
Quote:
scott |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Selling that nasty ole M6 now that you have your M8? | robert irvin | Digital Forum | 2 | 01/01/07 04:46 AM |
| Whats your favourite settings at you M8 ? | Olof | Digital Forum | 3 | 12/29/06 04:56 AM |
| M8 battery doesn't fully charge? | Gueorgui | Digital Forum | 0 | 12/29/06 03:57 AM |
| M8 Battery Availability | photolandscape | Digital Forum | 1 | 12/29/06 03:22 AM |
| Need a spare M8 battery - suggestions? | wparsonsgisnet | Digital Forum | 6 | 12/27/06 06:23 PM |
