Leica User Forum Robert White
Go Back   Leica User Forum > International User Forum > Digital Forum
Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras.
Register now
Old 01/20/07, 12:43 AM   #1 (permalink)
Erfahrener Benutzer
macusque's Avatar
Daumen hoch Tripod-collar for 100 Apo-Macro, 180 Apo and 80-200/4
I just received the Burzynski tripod collar for Leica 100 Apo-Macro.
I'm impressed by its quality.
Wonderfully made, very solid, much more than the discontinued STA-1 plastic tripod collar from Leica.
Smooth rotating and tight lock.
The baseplate seems Arca-style, although I don't have my B1 to check as I sent it for repair, so maybe there's no need for an additional quick release plate.
It has also a low profile which helps in making the system rock solid.
The only "drawback" is that the collar hides the dof scale, which I never use anyway...
Burzynski make it for many lenses (also Canon and Nikon) including the 180 Apo-Elmarit and 80-200 Vario-Elmar.
They don't seem to share the same model though.
The tripod mount is made of two pieces.
An external one, metal, which includes the baseplate and locking mechanism; and an "internal" one, a plastic collar which you need to lock on the lens tightening a little screw.
The metal ring then will slide on the plastic collar and you can easily remove it.
Maybe lenses that have a similar barrel's diameter where it attaches (like the 180 Apo), could share the same tripod-collar and it would be sufficient to buy only the correct plastic ring.
I'll ask them.
The tripod collar makes the aperture ring a bit more difficult to access, but overall it's not bad. I guess it would be better on the 180 Apo, because the lens has a smaller barrel just ahead of the aperture ring.
Anyway at 150 € including German VAT it is not utterly expensive, at least for Leica standards.
You can find it at Isarfoto Bothe GmbH, from what I understand the only distributor for Burzynski products: https://www.isarfoto.com/cms.php/_pi...0/Produkt.html
Highly recommended
macusque is offline   Reply With Quote
Old 01/20/07, 01:40 AM   #2 (permalink)
Erfahrener Benutzer
Default Re: Tripod-collar for 100 Apo-Macro, 180 Apo and 80-200/4
Very nice. I have the 100 and 180APO, and can use this. But the shipping cost to USA is 119EUR if I didn't misread it.
__________________
John
johnkuo is offline   Reply With Quote
Old 01/20/07, 01:53 AM   #3 (permalink)
Erfahrener Benutzer
macusque's Avatar
Ouch!
You are right John, US shipping is 119 €... maybe you could ask them for a cheaper solution, like UPS standard.
Btw, how do you like your 180 Apo-Elmarit ?
I have the 180 Apo-Telyt, but I'm thinking to "upgrade" to the latest Apo-Elmarit, which accepts the 1.4x, making for a nice portable combo when I don't want to carry the 280/4 Apo. It focusses also closer than the Telyt.
Old 01/20/07, 02:17 AM   #4 (permalink)
Erfahrener Benutzer
I am very impressed with the 180/2.8APO. The internal focus is extremely smooth, and the image quality is fabulous. I read that the optimal aperture for this lens is at wide open. It's also very usable handheld. I think mine is the older one that does not accept the 1.4x. I don't have experience with the 180 apo-telyt, but if you like your 280/4, then you will love this 180.
__________________
John
Old 01/20/07, 02:28 AM   #5 (permalink)
Erfahrener Benutzer
wparsonsgisnet's Avatar
Look how small the R9 ends up looking!
__________________
Bill Parsons (wparsons@gis.net), Boston
wparsonsgisnet is offline   Reply With Quote
Old 01/20/07, 03:14 AM   #6 (permalink)
Erfahrener Benutzer
robsteve's Avatar
Marco:
I just posted some 180mm APO comparisons in another thread. The STA-1 collar will fit the 180mm APO-Elmarit. I think the STA-1 got discontinued becase the grip on the R8 or R9 would hit it and lot allow it to spin 360 degrees.
robsteve is offline   Reply With Quote
Old 01/20/07, 12:57 PM   #7 (permalink)
Erfahrener Benutzer
carstenw's Avatar
Neat collar, but perhaps overkill for the 100. I love how that lens extends forever and two turns
__________________
Carsten
Leica M8 Lens Codes
Through the Lens Darkly
carstenw is offline   Reply With Quote
Old 01/20/07, 01:19 PM   #8 (permalink)
Erfahrener Benutzer
macusque's Avatar
John,
thanks for your feedback, do you find it balances well when handholding ?
Rob,
I read your thread about the Elmarit vs Telyt. Thanks a lot !
Carsten,
the 100 Apo balances very well on the DMR and the tripod collar is indeed overkill if maximum stability is what you are after.
But I bought it mainly to allow the rotation of the framing without touching the ball-head.
This is very convenient at close distances where changing orientation often shifts quite a bit the framing and you almost always need to compensate changing the tripod position.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
