Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Digital Forum
Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras.
Register now
Old 01/19/07, 12:27 PM   #1 (permalink)
Neuer Benutzer
Default lc1 (d2) with mz44-2 sync speed question
Hi everyone, just a quick question regarding the resulting camera sync speed when I attach my Metz mz44-2 flash with a sca3502 M4 adaptor. My Lc1 manual says that the camera sync speed changes automatically from 1/60 to 1/250. The Leica D2 manual does not mention the speed change at all. In my practical case I do not get a speed change. It remains at 1/60. Is it normal? Should I observe a speed change to 1/250? (would be nice)
Please let me know, since I get conflicting info from user manuals.
Cheers,
Gennady
gennfiks is offline   Reply With Quote
Old 01/19/07, 12:47 PM   #2 (permalink)
Erfahrener Benutzer
cbretteville's Avatar
Default Re: lc1 (d2) with mz44-2 sync speed question
Gennady,
I've never seen my D2 select anything but 1/60 in flash auto mode. I have the same setup as you and have recently started letting the MZ think for it self setting it to 'A' mode. The switch on the foot is still set to GNC. I get better results this way and the camera handles 1/250 better than in GNC mode. The camera communicates with the flas also when the flash is in 'A' mode so you get the zoom head, iso, shutter etc from the camera. Best of all, this way you loose the pre-flash.
- Carl
__________________
The M8 Metadata project
cbretteville is offline   Reply With Quote
Old 01/19/07, 01:14 PM   #3 (permalink)
Neuer Benutzer
Thanks Carl for your reply!
When you mention 1/250 speed, you are talking about forcing the camera into it? Also it´s funny that in the sca3502 manual there is conflicting info. On the one hand it says that if the adaptor is connected to the 3002 type flash, and 44mz-2 is one of them, swich positions on the adaptor are irrelevant. On the other hand in different place of the manual, it says that if you want GNC to be working the adaptor's GN switch has to be "on". Just in case I placed a switch to GN position and play both in TTL and Auto mode. I suspect that my LC1 manual mentions 1/250 speed change, because it seems that 54Mz-3 does force the speed change in camera. But, it's just a guess.
Cheers,
Gennady
Old 01/19/07, 01:48 PM   #4 (permalink)
Erfahrener Benutzer
Metz makes great flashes, but they can't write documentation worth a d**n. Most of what I've found I've either picked up here or by trial and error. And, yes - 1/250 has to be set using the shutter speed weel.
- Carl
__________________
Old 01/19/07, 06:16 PM   #5 (permalink)
Erfahrener Benutzer
Riley's Avatar
with an attached flash the sync speed is 1/60 to 1/250th in Normal Mode
with Slow Sync its 1 to 1/250th
set the speed manually
the onboard flash will go to 1/2000th TTL (i think)
__________________
Riley
Id give my right arm to be ambidextrous
Riley is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
D2 & LC1 in low light conditions polossatik Digital Forum 23 12/29/06 02:14 PM
Anyone using a neutral density filter with the D2? jp_photos Digital Forum 4 08/20/06 08:29 PM
D2 with SF 24D Flash whorg Digital Forum 3 08/11/06 11:57 AM
Super macro shots with D2 kumgak Digital Forum 18 08/04/06 05:12 PM
Polarizer and D2 - again, but with a slant... rob_rob Digital Forum 19 08/03/06 09:13 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
