| Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras. |
| Advertisement (gone after free registration) |
#2 (permalink) |
Erfahrener Benutzer
Hi Jaap,
I don't know of one (other than making an action in Photoshop) but the effect certainly is reduced when using coded lenses. Just for clarity, the vignetting is actually of red and the cyan is the evidence of what's left when red levels are reduced. That's why I refer to "cyan drift" and/or "red vignetting". The second term is technically correct but the first is more visually intutive (to my mind). 1.10 should be available for download in February. Best, Sean |
#3 (permalink) | |
Erfahrener Benutzer
Quote:
#4 (permalink) |
Gesperrt
Panorama Tools ora PTCorrect (is same oba first one 8bit, secont is 16bit). This is plugin Photoshop got inside calls <<Radial Luminance>> you take <<Options>> and put inside some small negatif valuable for Blue and Grin and put <<OK>> then does softaware aftomatic take away cyan corners. No needs for layers. no need take big time. Also is best part of, this softaware do not cost nothing. If you make it Google <<PTCorrect>> you come to place where download it from.
#5 (permalink) |
Erfahrener Benutzer
Hi!
Not sure but if what you are talking about is chromatic aberration there is a filter in CS2 and 3 in the distortion sub menu and it is call Lens correction and it as a Fix Red/Cyan fringe Filter>Distor>Lens Correction hope it helps! regards,Steve |
#6 (permalink) | |
Benutzer
Quote:
#7 (permalink) |
Erfahrener Benutzer
Using the Photokit plugin select the Dodge 4 corners action which will create a layer mask that is transparent in the center with graded density towards the corners. With this layer still selected, go to the Image Adjustments menu in CS2 or CS3 and select Photo Filter. Use the magenta filter and adjust the density slider until the cyan viginetting disappears.
The complement of cyan is not magenta but red - so use a red filter and adjust the density slider until the cyan vignetting disappears. |
#8 (permalink) | |
Erfahrener Benutzer
#9 (permalink) | |
Erfahrener Benutzer
Quote:
Do you know if firmware version 1.1 will operate successfully with an unfixed original M8? I ask because I am debating when to send mine back to Solms for the fix. Thanks Woody Spedden |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Cyan Vignetting Issue | atufte | Digital Forum | 26 | 01/06/07 04:25 PM |
| eliminating cyan corners | gtmerideth | Digital Forum | 6 | 01/01/07 06:03 PM |
| Cyan Corners vith firmvare ver. 1.09 | hjernemadsen | Digital Forum | 5 | 12/08/06 11:51 AM |
| Here's what the M8 firmware does for red vignetting | scott kirkpatrick | Digital Forum | 5 | 12/07/06 08:48 AM |
| Do IR filters themselves cause cyan corners ? | freecitizen | Digital Forum | 1 | 11/25/06 07:42 PM |
