| Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras. |
| Tags: 750, epson, pro, scanner |
#1 (permalink) |
Benutzer
Hallo,
nachdem es den gut beleumundeten Minolta 5400 II nicht mehr neu gibt, bleibt einem in dieser Preisklasse ja fast nur noch das Pendant von Nikon. Oder hat jemand schon Erfahrung mit dem neuen Epson V 750 Pro? Klingt auf dem Papier ja eindrucksvoll und man hätte die Möglichkeit, auch noch MF-Negative/Dias (Stichwort Hasselblad für Hosenknöpfe) oder sogar Großformat zu scannen. Oder gibt es da immer noch erhebliche Qualitätsverluste ggü. "echten" Filscannern? Viele Grüße, Gerd |
| Advertisement (gone after free registration) |
#2 (permalink) |
Moderator
You might get a better response to your post if you make it in the German section.
__________________
Cheers, Andy __________________________________________________ ___
#3 (permalink) |
Benutzer
I'm sorry. First try, and failed.
I'm looking for someone with experience with Epson V750. Greetings, Gerd
__________________
www.dr-appel-kassel.de |
#4 (permalink) |
Moderator
No need to apologise, but most people over here don't read German.
What is the issue with your scanner?
__________________
#5 (permalink) | |
Neuer Benutzer
Quote:
It is easy to use and changes from scanning film and slides to documents or photographs very easily. It's ablility to derive correct color from a negative is impressive. Bill Yowell |
#6 (permalink) | |
Erfahrener Benutzer
Quote:
Regards Johan |
#7 (permalink) |
Erfahrener Benutzer
The photolab where I go uses one for medium and large format and they dumped their LS9000. They did say the 750 isn't that great for 35mm. They use a Flex-right or something like that. Oh, and they also said they don't use the Epson scanning program, but some other one, Scan-View (?).
#8 (permalink) | |
Erfahrener Benutzer
Quote:
No photolab I know will ever tell you semi-pro scans could do a good job : it's theirs. When looking for some tests done by non-biased knowledgeable people, the difference between a Minolta Multi Pro (1800 $) and an Imacon 848 (10000$) might be not worth the price. If they use a Flextight, it's Imacon. And the software must be Vue-scan, I guess. I saw some results with an Epson, which appear quite good to my eyes. Peter Wolff photography Cheers, Johan |
#9 (permalink) |
Erfahrener Benutzer
Hier gibt es ein vollständig "test bericht" auf Englisch wegen die 750. Er sagte, es ist fast wie die Epson 700. Die beide sind fast so gut als ein Nikon 4000 mit 35mm film und sehr sehr gut mit MF film. Die Unterschied twischen die 750 und 700 ist Software und ein Bedeckung gegen Blendlicht.
I can only imagine that there are some really awful mistakes in my German above but it was fun to try and probably funnier to read ![]()
__________________
Curiously Incongruous: A flâneur's photographic diary of London Last edited by ericperlberg : 04/16/08 at 09:39 PM. |
#10 (permalink) |
Erfahrener Benutzer
Und hier ist die Bericht wegen die Epson 700.
__________________
Curiously Incongruous: A flâneur's photographic diary of London |
#12 (permalink) |
Erfahrener Benutzer
The report I linked to above shows scans using the 700/750 and the same 100% crops from a Nikon 4000 for direct comparison. Admittedly one is going to get the best results with a drum scan operated by an experienced operator but the question asked how the 750 compared to a Minolta 5400/Nikon 4000 class of scanner.
__________________
#13 (permalink) |
Erfahrener Benutzer
I have the V700--the more basic model. I am not entirely sure what the difference is. I have used it for simple scans and it is fine, but I've tried to do more serious work on it--scanning panoramic XPan tx's for example, and I was unimpressed to put it mildly. I haven't spent enough time to know whether I am doing something wrong, whether there is better software, and a better protocol to follow, but I hope so. Maybe the 750 is very superior. I'd be interesting in knowing if it is.
__________________
See some of my images on www.pbase.com/photolandscape. And, you can see my growing collection of photo books at www.blurb.com under "plattners". |
#14 (permalink) | |
Erfahrener Benutzer
Quote:
Results I saw with Peter Wolff are quite good, especially on monochrome. My Minolta Multi Pro is really slow, any drumscan or virtual drum Imacon is not an option (cost an eye) and scans from the lab are pricey on the long run (I have thousands of negs, and adding a few dozens each month). |
#15 (permalink) | |
Erfahrener Benutzer
Quote:
__________________
#18 (permalink) | |
Erfahrener Benutzer
Quote:
__________________
#19 (permalink) |
Erfahrener Benutzer
There, some results :
epson- powered by SmugMug |
#20 (permalink) |
Benutzer
Hi,
I've just acquired a v750 for my MF film and am so far very impressed with the results. I've had a brief go with Vuescan, but find a few glitches I need to work on. At the moment SilverFast Ai is easier. I'm using the SilverFast software for best control, although the Epson Scan software works for "quick and dirty." Files of course can be huge but produce images at 48" at 240dpi (650Mb) or larger, if you have the time and storage space. Snags: film flatness is crucial and difficult with the film holders supplied. I have ordered the fluid mount adapter from Epson UK (good prompt service) and also film holder and Anti Newton glass from "betterscanning". Dust!!!!! I don't have a "clean room," but I wish I did! It can be very difficult to eliminate dust from the scanner and the film. Yes, sharpening is essential, but then it is for most DSLRs and other scanners too. Less so of course for my M8. I don't use the v750 for 35mm film and doubt that I would be happy with the results. I suspect that they wouldn't compare with results from my Minolta 5400. I'm having great fun seeing what I can do with my Hassy negs at the moment. Hope that helps. Tim Last edited by Tim B : 04/17/08 at 06:59 PM. |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Scanner: Wer kann mir ein "Testbild" scannen? | Summi Cron | Digitalforum | 31 | 12/27/06 07:10 PM |
| Leica Objektive an Epson | marc | Digitalforum | 9 | 09/06/06 02:00 AM |
| Printer Recommendations | Mami | Digital Forum | 8 | 07/04/06 06:10 AM |
