Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum
Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras.
Register now
Old 12/19/06, 10:35 PM   #1 (permalink)
Erfahrener Benutzer
hfehsenfeld's Avatar
Default M8 firmware update 1.09 ready for DOWNLOAD
This is the site to download the awaited Firmware 1.09 for M8:
http://www.leica-camera.de/photograp...ad-121_10.html
For all of you eagerly waiting for the update: you need a card reader to do so.
Very first impression: playing images much faster especially magnifying happens immediately without the pixeling…
Ciau
Holger
hfehsenfeld is offline   Reply With Quote
Old 12/19/06, 10:52 PM   #2 (permalink)
Erfahrener Benutzer
Default Re: M8 firmware update 1.09 ready for DOWNLOAD
Holger what does the PDF file say in English.
__________________
Guy Mancuso
www.guymancusophoto.com
Upcoming GetDPI.com Photographic Workshops
"It's not always about what the client will accept but about what you want to deliver to your client."
guy_mancuso is offline   Reply With Quote
Old 12/19/06, 10:57 PM   #3 (permalink)
Erfahrener Benutzer
Quote:
The most important facts are at the bottom:
purpose of 1.09 improvements -- internal process optimization
Note: firmware 1.10 will appear in February 2007 and will address the requirements of the Leica IR/UV filters recommended for use with Leica wide angle lenses "
scott
__________________
___________________
www.pbase.com/skirkp
www.cs.huji.ac.il/~kirk
scott kirkpatrick is offline   Reply With Quote
Old 12/19/06, 11:00 PM   #4 (permalink)
Erfahrener Benutzer
harmsr's Avatar
Guy - Unfortunately this kills the theory of 1.09 being related to the "hardware" fix for the 1.06 cameras.
My other concern is then that they say 1.10 is for the IR filter use.
HELP!!!!! What about the vertical banding?
Ray
harmsr is offline   Reply With Quote
Old 12/19/06, 11:02 PM   #5 (permalink)
Erfahrener Benutzer
Thanks Scot , wondering what that really means the internal processing engine.
__________________
Guy Mancuso
Old 12/19/06, 11:02 PM   #6 (permalink)
Erfahrener Benutzer
george's Avatar
Guy, I just did it. So much about our exchanges this morning.
The instructions, loosely translated, say:
Format the card in the camera.
Turn off camera, put card in cardreader.
Move the downloaded m8-1 . . etc stuff onto the second line of your card folder display - below DCIM
Put the SD card back into camera and turn it on.
Agree to have the new firmware installed.
It takes about 180 seconds.
Good Luck.
__________________
George
george is offline   Reply With Quote
Old 12/19/06, 11:03 PM   #7 (permalink)
Erfahrener Benutzer
pascal_meheut's Avatar
Quote:
Maybe you should ask the question to Leica directly instead of shouting here ?
pascal_meheut is offline   Reply With Quote
Old 12/19/06, 11:04 PM   #8 (permalink)
Erfahrener Benutzer
george's Avatar
One more thing. It says on the bottom of the German text that 1.09 is for internal process optimization. Whatever that means.
__________________
George
Old 12/19/06, 11:05 PM   #9 (permalink)
Erfahrener Benutzer
please don't brick, please don't brick, please don't brick, please don't brick, please don't brick, please don't brick, please don't brick, please don't brick,
~180 secs later~ Whew! works fine. Seems to be a little faster on the reviewing, not much though
_mike
mike prevette is offline   Reply With Quote
Old 12/19/06, 11:05 PM   #10 (permalink)
Erfahrener Benutzer
cbretteville's Avatar
1: Format the SD card i the M8
2: Switch the M8 off, place your card in your compter's card reader. A reader is required for the update.
3: Copy the file named m8-1_xx.upd to the root of the card ( as shown in the pdf)
4: Remove the card from your card reader in an orderly fashion (i.e. make sure you close the card before you remove it). Put the card in the camera and replace the bottom plate. Switch the camera on using the main switch.
5: Confirm that you wnat to update the camera to version 1.xx.
6: If yor battery isn't sufficiently charged you will be see a warning message.
7: The update takes about 180 seconds. Shut the camera off when you're told using the main switch, it can now be switched on again.
Note: In Feb07 firmware v1.10 will be availabe that handles the use of wide angle lenses and the UV/IR filters.
Fixed in this release is internal process optimalization
__________________
The M8 Metadata project
cbretteville is offline   Reply With Quote
Old 12/19/06, 11:06 PM   #11 (permalink)
Erfahrener Benutzer
harmsr's Avatar
Pascal,
I have asked them. Unfortunately, I have not gotten a response to the emails.
Ray
Old 12/19/06, 11:06 PM   #12 (permalink)
Erfahrener Benutzer
Ray
I never believe that the "readme" says everything that is in a firmware release. So we only know that when cameras with fixed hardware appeared they appeared with 1.09. Since no claims are made about IR filter corrections before 1.10, (probably actually a higher number, since 1.13 has been reported already), I expect that vignetting corrections are the same in 1.09 as in 1.06.
C'mon. 1.09 has been shipping for a week or two. The vertical banding has gotten focus directed on it for the past two days.
scott
__________________
___________________
Old 12/19/06, 11:06 PM   #13 (permalink)
Erfahrener Benutzer
Ray
Looks like it may have killed that theory at least it was only a theory. i hate it when the make me look bad. LOL
1.10 is to fix the cyan casts now that one i knew about. Feb. hell i could be dead by than
__________________
Guy Mancuso
Old 12/19/06, 11:08 PM   #14 (permalink)
Erfahrener Benutzer
Ray,
There is no reason why 1.10 can't fix that too, if it is at all fixable in fw. It dosen't say 'the only thing 1.10 does...'. The vertical banding thing is too new for this to have made it into and around Leica engineering, doc writing, marketing etc. etc. Let the guys breathe!
Feb07, Ok time to take a few long breaths and stick it out until I see what this does for the camera.
- C
__________________
Old 12/19/06, 11:10 PM   #15 (permalink)
Erfahrener Benutzer
Pascal,
Ray
Who did you asked ? Because I have an answer every time I ask a question.
Old 12/19/06, 11:12 PM   #16 (permalink)
Erfahrener Benutzer
Quote:
I never hear back either, your email address must be red-listed or something...
__________________
Old 12/19/06, 11:13 PM   #17 (permalink)
Erfahrener Benutzer
Good Luck.
Well George we had fun at least . LOL
Can't always be right
Well off to put filters in a air condintioner for a sick neighbor on my 10 ft ladder i will bring the rope with me and hang myself high now. LOL
Kind of a tradition in the Old West, hell they still carry 6 shooters around here. LOL
__________________
Guy Mancuso
Old 12/19/06, 11:14 PM   #18 (permalink)
Erfahrener Benutzer
jaapv's Avatar
Default AW: Re: M8 firmware update 1.09 ready for DOWNLOAD
What by, Guy? Heart attack? You of all people shouldn't be worried about cyan vignetting - I bet you can fix that within 10 secs on any file
__________________
Jaap
WWW.JAAPVPHOTOGRAPHY.EU
Skype: JAAPVPHOTOGRAPHY
jaapv is offline   Reply With Quote
Old 12/19/06, 11:23 PM   #19 (permalink)
Erfahrener Benutzer
harmsr's Avatar
Pascal,
I emailed the address that I was given for Roger Horn in the US and the Customer Service email for Leica AG.
Do you have a specific email address that I should send samples to and ask for a response?
Ray
Old 12/19/06, 11:34 PM   #20 (permalink)
Erfahrener Benutzer
I sent a message to Leica USA with a link to the "M8 1.09 & Filter PROBLEMS (Summary)" thread to make sure they knew of the issue and to make sure it would be fixed while my M8 is still at Solms. They responded that they forwarded my message to Germany and assured me it would be fixed before my camera is returned. They promised to let me know if there are updates. At a minimum, we know they are now aware of it, and hopefully can find a quick fix.
Probably the more people that they hear about it from the better.
gesper is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wunschliste M8 Firmware 1.1 b2lore Digitalforum 34 04/24/07 12:42 PM
Still ready for my M8 - and ordering IR filters wparsonsgisnet Digital Forum 16 11/09/06 06:45 PM
What is current M8 Firmware? jfaier Digital Forum 19 11/08/06 11:42 PM
What's your M8 firmware version? lct Digital Forum 1 11/05/06 07:34 PM
M8 Impressions reddawn Digital Forum 25 10/16/06 05:14 AM
