Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Digital Forum
Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras.
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old 12/19/06, 09:21 AM   #1 (permalink)
Neuer Benutzer
Default M8 With Slow Speed/Metering Issue in Low Light
My recently delivered M8 (firmware 1.09) is experiencing problems w/slow speeds & metering in low light (household incandescent & halogen).
E.g., w/the ISO set to 640 & the shutter speed set to A(uto), the meter reading in my living room @ f/1.4 = 1/30th sec., f/2 = 1/15th sec., & f/2.8 = 1/8th sec., which is all good. Continuing down to f/4 = 1/6th sec., still OK. The problem is that stopping down to f/5.6 also gives a reading of 1/6th sec. & stopping down further to f/8 provides a reading of 1/8th sec. & f/16 = 1/12th sec., the opposite of what should be happening. Test shots show that the camera uses the indicated shutter speeds (I get a black frame @ f/16), so this is not a display issue.
The problem occurs w/all of my M-mount lenses (none coded), when using manual exposure as well as auto, & @ all ISO's (the "floor" shutter speed simply changes, e.g., if I set the ISO to 2500 in the example above, the lowest shutter speed becomes 1/24th sec. rather than 1/6th). The problem also appears to be independent of any camera settings (white balance, compression, etc.).
Has anyone else experienced anything similar? I was under the impression that the M8's meter was as sensitive as the M7 & MP. Any theories as to why this is happening or is this just a straight up metering problem (to be dealt w/under warranty presumably)?
Thanks in advance,
Chris
furcafe is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
D2 & LC1 in low light conditions polossatik Digital Forum 23 12/29/06 12:14 PM
M8 Light streaking test billh Digital Forum 25 12/06/06 03:03 PM
I think I have done a 360 with the M8 ... rick123 Digital Forum 20 11/30/06 04:06 PM
M8 with flash -- 2 questions lars_bergquist Digital Forum 9 11/27/06 01:19 AM
LEICA ANNOUNCEMENT: New Leica Products - LEICA M8 / M System daniel Digital Forum 199 10/01/06 03:18 PM
