Leica User Forum Robert White
Go Back   Leica User Forum > International User Forum > Digital Forum
Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras.
Register now
Old 12/07/06, 02:05 AM   #1 (permalink)
trs
Erfahrener Benutzer
Default 28mm/2.8 ASPH with M8, lens hood a must?
I have the above lens with my M8.
I notice that most pictures I see of M cameras, including M8, they don't have lens hood on. But, every M camera I see in demo, always has lens hood on.
One of the reason I ventured into M8 is for its compactness. I really like the compactness of M8 with 28/2.8ASPH with regular lens cap. In sunny environment, is the hood a must for 28mm? In D/SLR world, I always used lens hood (needed or not). It worked as protection if for nothing else and it did not really make the gear any bigger.
But, on M8, the lens hood actualy makes camera bigger. Anyway, it may sound like weird and obvious question, but I just wanted to know how you expereced M folks deal with lens hood. My guess is use it.
Currently, I using the normal cap since sun is not around and not going to be around for few more months around here.
I guess I have wishful thinking that I get the answer don't need to use it
Thank you.
-Tanka
trs is offline   Reply With Quote
Old 12/07/06, 02:52 AM   #2 (permalink)
Erfahrener Benutzer
Default Re: 28mm/2.8 ASPH with M8, lens hood a must?
I almost always use a lens hood but the best way to answer this for yourself would be to do an experiment. Shoot with and without in various lighting conditions and see what you think.
Cheers,
Sean Reid
__________________
Sean Reid
http://www.reidreviews.com
sean_reid is offline   Reply With Quote
Old 12/07/06, 03:15 AM   #3 (permalink)
Erfahrener Benutzer
baloo's Avatar
Blinzeln Re: 28mm/2.8 ASPH with M8, lens hood a must?
I never leave home without it, 1 for protection agains bad light 2 protection from chocks 3, look better, and the 3 is most important ; )
regards, Steve
baloo is offline   Reply With Quote
Old 12/07/06, 06:39 AM   #4 (permalink)
Erfahrener Benutzer
Tanka--
Another thing to consider is: There is a reason that Leica supplies a lens hood with (almost) every lens.
The hood is highly recommended in every case.
But if you don't want to use it, that's your choice.
--HC
ho_co is offline   Reply With Quote
Old 12/07/06, 06:48 AM   #5 (permalink)
Erfahrener Benutzer
Olof's Avatar
Default AW: 28mm/2.8 ASPH with M8, lens hood a must?
Why buy a cameraequippment for thousands of $ to get high quality pictures, and dont use the easiest way to get these pictures. the lenshood ?
__________________
"There is hardly anything in the world that someone cannot make a little worse and sell a little cheaper, and the people who consider price alone are that person's lawful prey" John Ruskin
Olof is offline   Reply With Quote
Old 12/07/06, 08:32 AM   #6 (permalink)
Erfahrener Benutzer
Well, this is a bit like the "Do I need a UV filter for protection and will it be detrimental to the results" discussion which comes up every now and then.
One thing is for sure, using a lens hood can't hurt. BUT, if you would rather shoot without a lens hood, my experience over many, many years shows that there are a great number of situations where using a lens hood or not will not make any difference to the result obtained. For example, if the sun (or any important light source) is in your back, the lens hood will not have any appreciable effect. Also, if the sun shines directly into your lens, such as when taking sunset shots or the like, again the lens hood will not have an effect as it can't shield off the sun anyway. Of course, if there is no sun or other strong light source at all, a lens hood isn't really needed as well.
The only situations where I found lens hoods to really improve the results are when (sun)light comes in obliquely from the front, such that the lens hood is able to shield off those oblique light rays which would otherwise enter the lens and cause internal reflections in the lens.
Most people always use a lens hood because then they don't have to think about whether it will be needed in a given situation or not, and as I said, using it sure doesn't hurt, but you can figure out yourself when you can do without the lens hood.
Cheers,
Andy
wizard is offline   Reply With Quote
Old 12/07/06, 08:36 AM   #7 (permalink)
trs
Erfahrener Benutzer
Default Re: AW: 28mm/2.8 ASPH with M8, lens hood a must?
Thank you folks. As I said, that was wishful thinking in my part to make the camera pretty compact. But, hey, it still fits in my pocket even with the hood. So, it seems that I have hood on. I just noticed my Fuji S2 with 100mm Macro and flash on it couple of nights ago and what a piece. I mean huge comparing to M8.
Fuji of course still staying for doing product shooting in studio.
And I agree that it does look much better in hood than without. I am still learning, but having a lot of fun.
Thank you again.
-Tanka
Old 12/07/06, 06:52 PM   #8 (permalink)
lct
Erfahrener Benutzer
lct's Avatar
This hood is very little actually and you will be happy to have when it rains or if you drop your lens eventually.
Did it myself and it saved my dear old 'cron 35/2 4th version.
BTW would you say it is the same hood?
lct is offline   Reply With Quote
Old 12/31/06, 04:13 AM   #9 (permalink)
Neuer Benutzer
Hi
My experience is that you always realize you should have used a lens hood too late, normally because you got away with it in every shot but the best one, when you didn't notice the flare or whatever in the viewfinder.
Peter
pvfb is offline   Reply With Quote
Old 12/31/06, 05:25 AM   #10 (permalink)
Moderator
abrewer's Avatar
Quote:
-Tanka
The advertising pictures are not representative of practice as the camera body must have maximum visibility...thus the lens hood is removed. If you notice M's in use, you'll see the hoods on, for protection against flare/stray light etc. as well as protection to the glass.
These hoods are pretty small. I carry the hood for my 35f2ASPH in my pocket until I get ready to start shooting, then remove the small flat cap and replace it with the hood. If you've got the strap around your neck (or hand-strap in use) then the minimal size of the hood should not be an issue.
Thanks.
Allan
__________________
Allan Brewer's Homepage
abrewer is offline   Reply With Quote
Old 12/31/06, 06:01 AM   #11 (permalink)
Erfahrener Benutzer
Two good rules: always use a lens hood AND also use a tripod if conditions and the environment allows.
-g
grober is offline   Reply With Quote
Old 12/31/06, 07:54 AM   #12 (permalink)
Erfahrener Benutzer
wbesz's Avatar
I don't consider it a must to use the lens hood, but it's a good way to reduce flare and prevent loss of contrast, but this is not always the case.
At times I left my lens hood off to keep the camera/lens package compact, and still managed to grab very good quality images.
wbesz is offline   Reply With Quote
Old 12/31/06, 09:18 AM   #13 (permalink)
Erfahrener Benutzer
Olof's Avatar
Thank you.
-Tanka
The Lenshood is a part of the optical system. Its very important for sharp, high quality pictures and it provides your Lens form damage.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
30% discount on lens possible with pruchase of M8 Westerwald-Leica Digital Forum 40 12/09/06 08:33 AM
Will I need my D2 Lens hood in Paris in December 2006 ? dugby Digital Forum 27 07/27/06 02:16 AM
Speculating re how M8 lens coding might work edlaurpic Digital Forum 45 07/19/06 12:10 AM
M8 lens coding the official word guy_mancuso Digital Forum 16 07/14/06 04:41 AM
M8 Viewfinder Rolo Digital Forum 86 07/12/06 05:17 AM
