Leica User Forum Robert White
Go Back   Leica User Forum > International User Forum > Digital Forum
Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras.
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old 12/05/06, 01:10 PM   #1 (permalink)
Benutzer
Tenor1's Avatar
Default Advice Needed: V-Lux and the Church Choir
What is the optimal setting to take a picture of my church choir? I'll only get one shot at our rehearsal due to time constraints. The church is not overly bright but we can still easily read the music. I'll use the self timer and run back into place.
I'm not sure how many feet back the camera will be yet. There are 4 rows of 15 people each. The church is the typical not-overly bright Catholic church, lol.
I record the concert and make CD's for the choir and want to have a choir picture on the CD. Would it be best just to use the Auto mode?
Many thanks in advance,
Carlos Marques
Tenor1 is offline   Reply With Quote
Old 12/05/06, 01:29 PM   #2 (permalink)
Erfahrener Benutzer
cbretteville's Avatar
Default Re: Advice Needed: V-Lux and the Church Choir
Carlos,
Can't you go there in advance and try some shots from the prosition you'll have the camera set up? This way you'll get some idea. The clothing of the members will have an influence, naturally, but at least you'll get some feel for what to do/not to do.
- Carl
__________________
The M8 Metadata project
cbretteville is offline   Reply With Quote
Old 12/05/06, 01:32 PM   #3 (permalink)
Erfahrener Benutzer
earleygallery's Avatar
Also, set the camera to auto bracket/multiple shots, assuming it has this feature?
__________________
Regards,
James
www.earleygallery.com
earleygallery is offline   Reply With Quote
Old 12/05/06, 02:15 PM   #4 (permalink)
Benutzer
Tenor1's Avatar
Thanks Carl and James. I can take some practice shots beforehand. The camera has autobracketing but I was thinking of using the flash. Would it be better to not use the flash?
Thanks,
Carlos
Old 12/06/06, 09:13 AM   #5 (permalink)
Erfahrener Benutzer
dugby's Avatar
Carlos, I do shoot a lot of orchestra's and can suggest, if your are the prime photographer for this shoot, then do a few test shots as previously suggested.
I found the optimum things to consider are
a) use a sturdy tripod
b) change White balance to a non-auto setting, preferable indoor or tungsten
c) experiment with ISO 200 or 400 to see if you can get an acceptable level of digital noise
d) Manual focus, do not use autofocus
e) manual aperature to maximum, (ie f2.8),
f) Avoid full wide-angle...if possible
g) if you can get the choir to stand still, non-flash digital shots can be a lot nicer looking than flash photo, otherwise diffused flash will be better than a direct flash shot. But your V-Lux1 flash may not be powerful enough for the diffused shot, so you may need to use an external flash
dugby is offline   Reply With Quote
Old 12/06/06, 09:39 AM   #6 (permalink)
Erfahrener Benutzer
Riley's Avatar
Quote:
Thanks,
Carlos
well maybe, maybe not
flash will tend to isolate the subject to a darker underexposed background, thats the sort of shot that might be better for just one or two people
if you dont use flash, spot meter faces (based on a little prior experience as mentioned) for exposure and WB (also mentioned). this sort of style will give softer images perhaps with some flow or movement
Riley
Riley is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
The merits of the M8 sensor size! andrewrossphotographs Leica M8 Forum 52 04/26/07 04:51 PM
D-Lux 2 Photos - Can there be even better? rick123 Digital Forum 47 12/05/06 11:51 PM
D Lux 3 kit and noise cobbslane Digital Forum 11 11/18/06 05:34 PM
M8 ISO Setting stan98103 Digital Forum 0 10/31/06 08:44 AM
L1 rob_x2004 Digital Forum 21 08/27/06 04:12 AM
