Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum
090909 Promo
Digital Forum The Leica Digital Forum is for discussions about Leica's Digital cameras.
Register now
Old 27.11.2009, 18:49   #1 (permalink)
Neuer Benutzer
Default Digilux-2 power drain/battery sensor problem?
hi L-forum,
has anybody experienced sudden battery drain on the Digilux-2? I will charge up the battery to full, pop it in the camera, and can take 15 pics or so (JPEG) before the camera tells me that the battery is nearly empty, and then won't turn back on. I replaced the battery and same problem. When I put the battery in the charger, it charges pretty quickly, so I am leaning towards something being funny with the battery sensor and not the battery itself?? I can't imagine that there is an electrical short that would drain the battery so quickly -- the camera doesn't get hot, so where would all that energy go? Has anybody else seen this happen? Any insight?
I haven't seen other posts about this problem, but my apologies if it's already been discussed. If so, I would appreciate a point in the right direction.
Anybody have any suggestions on a repair shop in NYC that can handle the electricals?
thanks L-forum.
ndg
nabarund is offline   Reply With Quote
Old 27.11.2009, 19:09   #2 (permalink)
Neuer Benutzer
Default Re: Digilux-2 power drain/battery sensor problem?
Hi,
Lithium-ion battery have limited lifetime. (top 2-3 first years but could be 5)
Did you try some cross test with a new one ?
More on this page Is lithium-ion the ideal battery?
How to prolong lithium-based batteries : http://www.batteryuniversity.com/parttwo-34.htm
All you ever want to know about your battery, and more !
Cheer
Algo is offline   Reply With Quote
Old 27.11.2009, 22:17   #3 (permalink)
Erfahrener Benutzer
ajthornbury's Avatar
I had similar problem when my Image sensor failed. Was OK when image sensor was replaced.Could also be the battery reaching end of life, so try new battery first.
ajthornbury is offline   Reply With Quote
Old 28.11.2009, 00:07   #4 (permalink)
Neuer Benutzer
Yes, I tried a new battery and it had the same problem. Sorry that wasn't clear in my original post. So I think it is something internal to the camera.
thanks in advance for your help.
Old 29.11.2009, 02:33   #5 (permalink)
Erfahrener Benutzer
rsolomon's Avatar
sorry to say but it looks like a vist to the leica hospitial ...
rsolomon is offline   Reply With Quote
Old 30.11.2009, 15:58   #6 (permalink)
Erfahrener Benutzer
chouhsin's Avatar
If the battery have life limit, will there still be replacements in 10 years? Will we still be enjoying D2 in 2020?
Maybe this all end at 2012?
Hsin
chouhsin is offline   Reply With Quote
Old 01.12.2009, 21:02   #7 (permalink)
Erfahrener Benutzer
I should start stocking up aftermarket batteries right away!!
Hopefully by 2012 Leica and/or Panasonic will have something to show that outperforms D2's qualities.
__________________
Digilux 2 - Lumix Wide angle adapter; Elpro Macro lens; Lumix macro adapter
Digilux 3 - 14-50mm f/2.8; 14-150mm f/3.5; 25mm f/1.4; Zuiko 50mm F/2; Zuiko 11-22mm f/2.8
D-Lux 4 - Lumix Wide angle adapter
My Digilux 2 Gallery: on Flickr
carlosecpf is offline   Reply With Quote
Old 02.12.2009, 19:17   #8 (permalink)
Neuer Benutzer
Quote:
Nope Lithium-ion battery have limited lifetime ... in use or not
Hopefully, this kind of battery pack is useful for a lot of material.
It should be maintain for a long time after ...
Old 04.12.2009, 03:48   #9 (permalink)
Erfahrener Benutzer
Save your batteries even after they stop working. This model battery (and the slightly better but compatible 1700mah battery for the Digilux 3) may not be made forever, but the generic cells they contain may be. Online battery 'shops' can swap out the old cells for new ones in the containers you provide.
jrethorst is online now   Reply With Quote
Old 09.02.2010, 12:23   #10 (permalink)
Neuer Benutzer
thanks for the comments, everyone.
the camera is back from the hospital. some $560 later, they changed the motherboard, gave it a software update, and fixed a little wear and tear on the focus ring. they had to order the motherboard, and it took about 2 weeks to get it back from the time i authorized the service.
i love this camera, so the repairs were worth it. still, the repair price tag does smart!
the batteries i was using before all work fine now, so it wasn't a power pack issue.
so thanks Leica Hospital NJ. i just wish the motherboard had failed while it was still under warranty.
ndg
Old 10.02.2010, 23:05   #11 (permalink)
Erfahrener Benutzer
Digitom's Avatar
Default AW: Re: Digilux-2 power drain/battery sensor problem?
Do you use the original charger? That is recommended and my experience is to use the original charger only! 2nd idea: could be a problem with the charger itself, if also another cell failed.
__________________
Beste Grüsse und immer "GutLicht"
Digitom (Thomas)
CLICK HERE TO MEET OTHER DIGILUX 2 USERS IN THE FORUM!
Digitom is offline   Reply With Quote
Old 01.03.2010, 22:57   #12 (permalink)
Neuer Benutzer
yes, i had been using the original charger, and also the charger from my panasonic version (camera had been stolen and i was left with the extra charger). it ended up not being a cell failure or charger problem, but a motherboard/software problem. fixed now! thanks.
Reply
Bookmarks
Tags
battery , digilux 2 , power
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
