usccharles Posted January 13, 2009 Share #1  Posted January 13, 2009 Advertisement (gone after registration) hi,  do you know the filter size for this lens? and is there a uv/ir filter available?  thanks  charles Link to post Share on other sites More sharing options...
Advertisement Posted January 13, 2009 Posted January 13, 2009 Hi usccharles, Take a look here first gen 50 lux M mount question. I'm sure you'll find what you were looking for!
luigi bertolotti Posted January 13, 2009 Share #2 Â Posted January 13, 2009 E43 screw filter : UVIR filter available from B+W Link to post Share on other sites More sharing options...
usccharles Posted January 14, 2009 Author Share #3 Â Posted January 14, 2009 Thank You You Rock! Link to post Share on other sites More sharing options...
LeonardT Posted January 14, 2009 Share #4  Posted January 14, 2009 E43 screw filter : UVIR filter available from B+W  Check this thread before you buy a B+W filter for this lens.  http://www.l-camera-forum.com/leica-forum/leica-m8-forum/74720-free-filters-m8.html  According to one of the posts the 43mm thread pitch is different between the Leica and B+W filters and only the Leica is correct. I don't know if this is correct or not but it is worth checking out.  Len Link to post Share on other sites More sharing options...
Ivar B Posted January 14, 2009 Share #5 Â Posted January 14, 2009 E43 screw filter : UVIR filter available from B+W Â No, this does not work as has been pointed out by Leonard also. Due to a different thread, you need original Leica. In some cases a B + W can be mounted, but then you cannot affix the hood any longer. Link to post Share on other sites More sharing options...
luigi bertolotti Posted January 14, 2009 Share #6 Â Posted January 14, 2009 No, this does not work as has been pointed out by Leonard also. Due to a different thread, you need original Leica. In some cases a B + W can be mounted, but then you cannot affix the hood any longer. Â Right Ivar, I didn't remember it... Link to post Share on other sites More sharing options...
usccharles Posted January 15, 2009 Author Share #7  Posted January 15, 2009 Advertisement (gone after registration) whoa, ok. thanks for the update  this forum seriously seriously rocks...  thanks! Link to post Share on other sites More sharing options...
Ivar B Posted January 16, 2009 Share #8  Posted January 16, 2009 hi, do you know the filter size for this lens? and is there a uv/ir filter available?  thanks  charles  I have a new Leica E43 UV/IR if you need one. Link to post Share on other sites More sharing options...
peter_n Posted January 17, 2009 Share #9 Â Posted January 17, 2009 I have v.2 of this lens and the filter thread pitch is 0.5mm, as distinct from most other lenses which have a filter thread pitch of 0.75mm. Depending on tolerances, a 0.75mm thread pitch filter will go on the Summilux, for example Hoyas will fit, and I have a B+W UV filter on mine. Link to post Share on other sites More sharing options...
Ivar B Posted January 17, 2009 Share #10 Â Posted January 17, 2009 I have v.2 of this lens and the filter thread pitch is 0.5mm, as distinct from most other lenses which have a filter thread pitch of 0.75mm. Depending on tolerances, a 0.75mm thread pitch filter will go on the Summilux, for example Hoyas will fit, and I have a B+W UV filter on mine. Â Can you attach the lens hood properly also with the filter in place? I have found this impossible with any other filter than Leica, although I did not try Hoya. I have a v1 of the 1.4/50 and I also have the 1.4/50 ASPH LHSA which is identical in outer appearance. To obtain a filter with "modern" glass I have had to install B + W glass in old Leica mounts, as Leica no longer make UV in chrome, but the UV/IR is available. Link to post Share on other sites More sharing options...
Philippe D. Posted January 17, 2009 Share #11 Â Posted January 17, 2009 Can you attach the lens hood properly also with the filter in place?The filter for this Summilux is a slim one. Link to post Share on other sites More sharing options...
